Question about Pyle Home Pt570au 5.1-channel 350 Watts Am/fm Radio With Usb/sd Card
How to connect speakers
I have 2 Fisher tower speakers, model ST-9415/ST-9418, and I am trying to figure out how to connect them to my Pyle receiver. I tried using speaker wire because that's what the speakers require but there doesn't appear to be a place to insert the wire directly into the receiver. Do I need a different cord(s)? Also, how do I then connect them to my TV, which is a Sanyo, model number DP46849?
  • 113 Answers
SOURCE: what is wrong with my system
wiring may not be the problem but try connecting each coil to separate channel and make sure polarities are correct.
Posted on Aug 09, 2007
SOURCE: PyLE PT2000 Power Amplifier' { is it worth it??}
People talk alot of **** about Pyle amps, all I can say is that,
I have two PT-2000 & PT-1800 power amps that I have set in bridge mode, one for each speaker and they are powering two Altec-Lansing 18" inch subs, one amp per speaker, no hiss, line noise or anything and the system kicks. I tried the Pyles on a whim because I got tired the trouble I was having with the QSC and Crown power amps, could not go a year without having something go wrong always sending back to dealer for some kind of fix! So now I have 2, QSCs, 2 Crowns & 4 Pyles driving my system
Posted on Apr 30, 2009
etirbynnor
  • 655 Answers
SOURCE: Trouble connecting marine amp to stereo
Hello lizskates814,
You can use either the high level (speaker) or the low-level (RCA's) inputs to the amp, but not both. Choose whichever one sounds the best or is more convenient to install and leave the other disconnected.
Hope this helps.
Posted on May 24, 2009
audio20
  • 22 Answers
SOURCE: I have a Pyle PLD3MU
Run your 12" subs off the amp make sure to Xover for bass only.
Try running the 4 speakers direct to the stereo may not be enough power, Might have to invest in another amp and speaker upgrade to get it sounding just right.
But its a place to start.
Posted on Jul 22, 2009
  • 78 Answers
SOURCE: power in amp but no sound to speakers
you need to make sure youre getting a signal from the source, RCA's I suppose. Check for loose connections or broken wires. make sure to have 12v+ on power and remote inputs at amp...proper ground too. Lastly, check your ohm loads at speakers, maybe one is about dead. make sure crossover settings are correct.
good luck!
Posted on Sep 19, 2009
How do I run my Pyle receiver in 2 ohm
Never run an amp down to 2 ohms. Best way to cook it. If you need to drive multiple speakers, you need to network them, in a parallel/series configuration. You should always try to be at 8 ohms.
Feb 24, 2015 | Pyle Audio Players & Recorders
I want to wire my 4 ohm DVC subs to my Pyle 3000 watt home receiver amp
No you don't. You'll fry the amp. You need a low frequency processor to strip the mid and hi frequencies out of the signal applied to the subs or you'll have a full frequency sub that will sound cruddy. If your amp outputs 8 ohms the you'll have to wire 2 speakers in series or poof goes the amp. If the amp is only 16 ohms then you're out of luck unless you have 2 more speakers to connect in series to the 2 you aleady have.
Feb 19, 2015 | Pyle Car Audio & Video
How do i connect my av30 speakers to my Toshiba tv? I have tried everything and am unable to get sound from the speakers. I have 2 sets of these speakers and would love to listen to my tv with them. I also...
Connect left and right audio outputs on rear of TV to corresponding inputs on rear of your Pyle receiver. You may have to go to the initial set up procedure on your Toshiba TV to disable internal speakers and direct audio output to the Pyle receiver.
Dec 04, 2017 | Audio Players & Recorders
How do I connect my onkyo tx-sr705 to a pyle pro speaker selector? I am "not" using the onkyo for a surround sound, only for music with 3 pairs of speakers in different rooms. (CD, Sirrus...
Hi Mdensonjr, I see that this was posted in 2011 but well the speaker selector would be connected to the Front speaker terminals, Thanks, JT
May 29, 2011 | Onkyo TX-SR705 Receiver
Hi I need a owner/instruction manual for the fisher price laugh and learn jumperoo... we didn't receive it when it was shipped to us
Here is a link to Fisher Price's site to download the instruction manual: http://www.fisher-price.com/fp.aspx?st=2000&e=product&selcat=bgetn&pid=46128.
Jan 07, 2011 | Fisher Price Toys
Can I connect Pyle PDIC51RD speakers in series.
Yes, everything can be connected in series. Be sure the positive from one speaker leads to the negative of the next so they will be in phase.
Aug 18, 2010 | Pyle Audio Players & Recorders
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
Partial sound from my JBL E60 Towers
Are there 4 inputs on the back of the speakers? If so, you either need to hook up all four, or connect the upper and lower inputs to each other. The speakers come with gold plates that connect the upper and lower inputs, but you can just use speaker wire to connect them. At least that is what I did on the used set of speakers I bought when one plate was missing.
Mar 27, 2009 | Yamaha HTR-5830 Receiver
Pyle Home Pt570au 5.1-channel 350 Watts Am/fm Radio With Usb/sd Card Logo
32 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
