Question about Emerson MS3100 3-Disc CD Changer
I have an Emerson PD5098 Cd Player with radio. When I load a disc, it spins around and then stops but will not play. What is wrong?
I used a cleaner Cd thinking something was wrong with the lens. I push the pause, play and stop buttons and I have used several different Cd's but nothing seems to work.
5 Suggested Answers
SOURCE: CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
Posted on Jul 04, 2007
  • 93 Answers
SOURCE: Emerson PD6560
Is that happens with all CDs? Is CD goes in and out normaly? Maybe laser lens are dirty.
Posted on Oct 01, 2007
  • 21 Answers
SOURCE: Emerson 3 Compact Disc Player
Hi
If the machine cant read the table of contents of a disc this would suggest either the lens of the optical pick up is dirty or the optical pick up has failed completely or something directly relating to the optical pick up i.e the spindle or stepper motor, if you can easily acess the optical lens you maybe able to clean it using a cotton bud and re-test, just try this with a dry contton bud to begin with if this gives an improvement you may wish to use a cotton bud with a alchol cleaner like I.P.A,
make light circular movements over the lens. If this makes no difference the machine requires repairing, so consult a local service engineer.
regards
TechSupp12
Posted on Dec 11, 2010
  • 6771 Answers
SOURCE: emerson dvd player won't read disc. makes spinning noise but nothing happens. disc display sometimes show spinning. only get blank screen . used cleaner disc. work at first now cleaner won't
The DVD laser pickup is at the end of life, replacement of assembly the only option, cheaper to replace the combo unit.
Posted on Jun 24, 2012
My dvd player has just stopped playing disc's? I insert a disc, it loads up as the little circle comes up, saying loading. Then it says bad disc.It stops. Does anyone know what could be wrong here?
Couple things could be. I've found : the disc can be dirty, wipe it off. Or if its damaged the lens won't read it.
What usually helps the most is to put a lens cleaner in the player. they sell them. I only have a CD cleaner ( prob called lens cleaner). It still fixes it for me.
Jul 20, 2015 | Televison & Video
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
Cd's won't play
Its dirty, try a disc cleaner, (brushes not solution) and if that does not work, its time to replace, (unless the radio is all ya want).
ALSO- if you are trying to play burnt discs, (cd-r, mp3 discs etc) than that could be the issue as not all indash cd players support non store bought cds
Aug 16, 2009 | JVC KD-S640 CD Player
CD player stopped working on Sony ICF-CD831 PSYC Clock Radio/CD P
I've been able to prolong the life on mine by doing this:
Insert the disc, then spin it by hand and quickly close the door and hit play.
It's always worth using a laser cleaner first, as it may just be dirty and stops spinning because it cannot read the disc.
Apr 26, 2009 | Sony PSYC ICF-CD831 Clock Radio
My top loading cd player
It sounds like either the laser is wearing out or needs a clean. Put a lens cleaner in it, ensure there's no dust on the lens. Has the unit not been used for any length of time?
Aug 14, 2008 | Audio Players & Recorders
Wrong disc
If this model displays Wrong Disc even when you play all kinds of CDs, you may want to buy a CD/DVD laser cleaner for it.
Does this solve the problem?
Aug 03, 2008 | Coby TF-DVD7005 Portable DVD Player
Stopped playing...all DVD/CD
TRY CLEANING THE LENS WITH A SPECIAL CD LENS CLEANER.. YOU CAN BUY IT WALGREENS OR WALMART
Mar 07, 2008 | Mintek MDP-1020 Portable DVD Player
CD's won't play
I know that Panasonic provides chips, optics (laser),etc. to Emerson. I am familiar with the problem you've experienced because I've had a Panasonic CD Player. If the disc doesn't spin (as you said), the problem must be that your shelf system probably has an optical problem (laser problem/pickup problem) and will need to be serviced.
Apr 22, 2007 | Emerson MS3103 Shelf System
Emerson MS3100 3-Disc CD Changer Logo
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
