Question about Mammut Pulse Barryvox Avalanche Transeiver
Change language on Barryvox Pulse - Mammut Pulse Barryvox Avalanche Transeiver
How to change Windshield Wiper Motor Pulse Board on 2005 chevy impala
Change the wiper motor, and you replace the pulse board.. You can not buy the board separate from the motor.
Aug 07, 2014 | Chevrolet Chevy Cars & Trucks
Pulse
. Press and hold the dial/menu button until "Options Menu" is shown in the display.
2. Use the up/down buttons to scroll through the options below, and press the dial/menu
button to select the desired option you wish to set:
• Set Language
• Local Area Code
• Set Time/Date
• Set Flash Time
• LED Contrast
• Set Tone/Pulse
• Exit Options
3. Use the up/down buttons to adjust the setting, and press the dial/menu button to confirm
and set.
NOTE: It is important to set the Area code so that the telephone can distinguish local or long
distance calls when dialing from the Caller ID list.
NOTE: Time and Date will automatically set when you recieve the first or second Caller ID
Nov 08, 2012 | Emerson EMSEM2646WH Phone
My Kodak Pulse for some reason is in a language I dont speak. And now my mom wants me to set it up and put in all the pictures, the question is "How will I set it up if i dont know the language"...
Is this Pulse frame brand new out of the box (ie never been set up), or has it previously been set up and somehow got switched to a new language?
If previously set up, log into your kodakpulse.com account, and click on the "Frame Settings" tab. From there you can switch languages, and the frame will update to your desired language after a few minutes.
If the frame has never been set up before, you can reset the frame to a default language by simultaneously depressing both buttons on the back of the frame and then touch the "Trash can" icon (ie the "reset all" icon). WARNING - THIS WILL RESET THE FRAME TO THE FACTORY DEFAULT OUT OF THE BOX SETTING AND DELETE ALL PICTURES AND WEB SETTINGS, so only do this IF THIS FRAME HAS NOT BEEN PREVIOUSLY CONFIGURED.
Aug 16, 2011 | Televison & Video
I bought a Garmin Nuvi 1350 GPS. How do I change the language into English?
. Setting the Languages Voice Language--change the language for voice prompts. Touch tools > Settings > Language.
text Language--change all onscreen text to the selected language. Changing the text language does not change the language of user-entered data or map data, such as street names. Keyboard--select the keyboard for your language.
Touch Mode on any keyboard to change the keyboard language.
Sep 02, 2010 | Garmin GPS
Changing to pulse
Enter SetUp. Look for Global setup. You have the options Area code, Dial Mode. This last option is the one that allows you to change between Pulse and Tone dialing.
Dec 30, 2009 | Uniden DECT 6.0 Cordless Phone ID
Canon JX200 language reset
Press the dataregistration button to display -usersettings-Press the # button 1sssw will display scroll down with the arrow buttons untill clear is display press ok and do printer clear.It will do a start up and ask for language reload all your default settings.Make sure your tone and pulse dail is set correctly.
Aug 17, 2009 | Canon FAX-JX200
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Set time and date
I picked up a cid 244w phone at goodwill because it will work with the power out. With a lot of fiddling around I found that if you push the erase button and hold it, then push the review arrow down button the menu starts. It starts with Contrast then to language, area code, date and time, and lastly tone or pulse.Set it to tone,Pulse is the old rotary dial phones. You scroll through the menu by pushing the erase button and change things with the review up and down buttons. If you wait too long to change something the menu automatically advances. If the item you want to change passes by just start over. Good luck, I hope this helps
Mar 15, 2008 | Conairphone CID 244
Dialing mode option change.
Program --> Auto --> ** --> Program (Pulse to DTMF)
Program --> Auto --> ## --> Program (DTMF to Pulse)
Jul 30, 2007 | Panasonic KX-TGA101S Cordless Handset
GE 29439GE2
Copy directly from the manual: TONE/PULSE Your phone is set to TONE at the factory. Set the TONE/PULSE selection to PULSE if you have pulse (rotary). If you don't know which type of service you have (pulse or tone), check with your phone company. To program TONE/PULSE for all 3 lines: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press TONE To program TONE/PULSE for each line individually: 1. Press STORE/IN 2. Press 0 for PULSE or Press 1 for TONE 3. Press STORE/IN 4. Press LOWER 5. Press line number (1, 2, or 3)
Jan 11, 2007 | GE 29439GE2 Corded Phone
Mammut Pulse Barryvox Avalanche Transeiver Logo
106 people viewed this question
Top Mammut Sport & Outdoor - Others Experts
Bill Eager
Are you a Mammut Sport and Outdoor - Other Expert? Answer questions, earn points and help others
