Question about Cycling
Mongoose 2.1 ledge rear suspension diagram - Cycling
3 Suggested Answers
billie17
  • 84 Answers
SOURCE: Adjust front suspension on a Mongoose XR-75
i dont think you can......because these bikes are made for confort at a cheap price..........
higher value bikes can be adjusted....they have special shocks and you can adjust on either soft or stiff ride.....
Posted on May 13, 2009
  • 1138 Answers
SOURCE: adjust rear suspension on Mongoose XR-Comp
Here is a good source of info:http://www.bikewebsite.com/suspension.htm Let me know if this helps.
Posted on Jan 18, 2010
What is a decent replacement rear derailleur for a Mongoose 26" Ledge 2.1 Mountain Bike?
Get the kind that has a lever shift instead of the grip shifter. The plastic part that holds the spring breaks easily. The lever shifter has been going strong on my bike for 6 years without a problem
Aug 31, 2016 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
My chain is sliping on my26" Mongoose Ledge 2.2 Men's Mountain Bike
Its usually a bad freewheel. Its a complex operation to replace, contact local bike shop for assistance
Jul 15, 2014 | Cycling
Mongoose Ledge 2.1 pedal thread size
Measure the threads on the crank. Use or borow a pair of calipers. Measure with two threads as the outside edges to get proper diameter.
Apr 17, 2014 | Cycling
Tighten front suspention on a Mongoose 26
Look for knobs on the tops of the suspension fork legs that will probably have a + and - sign on them. Turn them in the direction of the + (usually to the right) until you are satisfied.
If you have already tried this or it doesn't give you adequate results; you may be stuck. You can occasionally find stiffer springs to put inside; but this is sometimes more costly than is desirable and a little more mechanically difficult to do on your own if you're not comfortable with disassembling and reassembling the fork.
Just a guide though: ideal suspension firmness allows for some movement when you get on the bike and will use all of it's travel on the biggest bump you encounter.
Oct 08, 2012 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
Mongoose mozo m30 forks are sponggy
Change the spring to your load.
Adjust Mozo M30 Fork Suspension - Beckman Du-70 Forum
efratoium.xyz/Adjust-Mozo-m30-fork-suspension/
Results 1 - 15 of 15 - Mongoose XR 150 mozo m30 front forks rebuild. A quick ...Mongoose mozo m30 forks are sponggy on my XR150 mongoose mountain bike.
mozo??- Mtbr.com
forums.mtbr.com/shocks-suspension/mozo-167281.html
Feb 20, 2006 - 15 posts - ‎6 authors
... of a mozo m30? is it the junk im assuming came on my mongoose? ... into a halfway decent bike. and all i can get off the fork is mozo m30 ...
Mongoose XR250 Suspension Upgrades ' Bicycling Magazine Forums
forums.bicycling.com/topic/54635607127666779
Sep 30, 2012 | Mongoose Exile 26 Men's Full-Suspension...
I have a Mongoose Dual Suspension Mountain Bicycle 26 inch that I purchased approx. 2007 and I need the rear wheel axel and bearing assembly. Where would I be able to purchase these parts?
It's prabably easier to buy a whole new hub. And for ablout another $20 you get a whole new tire. You should do that. Have a bike shop do it because it can be tricky.
Jul 24, 2011 | Mongoose Domain Dual Suspension Mountain...
Hi I have a problem, I've just recently bought a new mountain bike from eBay. It's a mongoose, can you tell me how to tighten the suspension, so it's for road use not cross country. I deflated the air...
Since you've let the air out of the shock you need to go to a Bike Shop for a refill anyway because a normal pump doesn't reach the pressures supplied by a shock pump. While you're there, have them set the bike up for your preferences and instruct you in shock operation.
Aug 18, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Where can I find a drawing of a 21 speed 26" mongoose duel supp rear deralier so I can see how the cable runs?
http://www.amazon.com/gp/product/images/B000B8IDS2/ref=dp_image_text_0?ie=UTF8&n=3375251&s=sporting-goods If it has a Shimano Altus rear derailleur, you can look here:http://bicycletutor.com/adjust-rear-derailleur/comment-page-3/ or here:http://www.parktool.com/repair/readhowto.asp?id=76
Oct 16, 2009 | Mongoose Sector 26 Men's Full Suspension...
Removal of sprocket and gears from rear tire for replacement
A special sprocket removal tool is required usually only $20 to $30 bucks at a decent bike shop.
Jan 29, 2009 | Mongoose Exile 26 Men's Full-Suspension...
Cycling Logo
163 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
