Map dvd stuck in Toyota Sienna van
Inserted regular video dvd and it won't eject
  • 104 Answers
SOURCE: dvd stuck in advent 10"
Sienna Minivan with a DVD entertainment system - rule nr 1 - Recorded DVDs would play but not eject, and then jam the system. It will require disassembly of the housing to reset power to eject.
Posted on Oct 04, 2008
  • 59 Answers
SOURCE: DVD stuck in DVD player will not eject
I just fixed one of this exact model SD-V392SU with same problem. This takes a bit of manual dexterity, but it can be done with some care and patience.
THE PROBLEM:
There is a small plastic nylon gear on the shaft of a miniature motor in the DVD mechanism. This gear is likely floating loose in the machine. It is what connects the motor's shaft to the rest of the mechanism to operate all it's functions which include opening and closing the tray and raising and lowering the laser and spindle motor that spins the disks. Be careful not to lose it once the lid is removed from the unit. It is quite small.
Unplug the unit and use a well lit area to work in such as the kitchen table covered with a large towel to protect the unit and the table.
There are 5 Philips head screws holding the lid on. One each side and 3 in the back. Remove those paying attention to where they come from. There is a subtle difference in the lengths of the screws. I use empty prescription bottles to keep things sorted when I work.
The lid can be removed by sliding it slightly backwards and tilting the rear of the cover upwards and back. Once the lid is off the unit, you must locate the small white nylon gear that has come off the shaft of the miniature motor that drives the mechanism. A good tip is to lay out a dark colored large towel to shake and dump the loose gear out and onto so you can more easily see it's white color.
REMOVING THE DVD MECHANISM:
There are 2 flat ribbon connectors and one 3pin mini molex connector connecting the DVD mechanism to the main board of the unit. Grasp the cables as close to the connector as you can get.and gently disconnect these by carefully pulling them out. All three are different, so you can't mix them up to put them back.
There are four screws holding the black plastic mechanism in the unit. One long shoulder style screw at the rear center of the mechanism, and three short screws with captive washers. Two of the three short ones are located one on each side of the mechanism towards the front face of the unit and one near the right hand side about three quarters of the way to the rear of the mechanism. A magnetized Number 2 Philips is the best tool for removing and replacing these screws as the two short front screws must be removed from rather tight quarters in the recesses of the unit. The magnet holds the screws on the tip so you can raise and lower them into position while removing and replacing them.
Once the three connectors and four screws are removed, you can lift the rear of the mechanism slightly and tilt the mechanism out of the unit. Once again, keep a sharp eye out for the loose little white gear.
Now that you have the mechanism out of the unit, you can manually eject the captive DVD.
First a little about how this mechanism works.
Look at the front face of the mechanism. You will see a white actuator bar that slides left and right. This is what raises and lowers the laser/spindle assembly. When the mechanism motor spins, connecting gears move this bar raising the laser/spindle motor assembly up. This causes the disk to be clamped against the top of the drive in play mode so the spindle motor can rotate the disk for the laser to read, The disk tray is basically locked when in this position and it can not slide out to give you the disk.
With the gear missing from the mechanism's motor, it will be possible to move that white actuator bar that raises and lowers the laser/spindle motor assembly. Note that there is a switch with three wires on it located on about front face center that is operated by that white bar. This switch tells the mechanism motor when it is loaded and unloaded so the motor knows when to stop spinning as it loads and unloads. Once the bar lowers the laser/spindle, the tray should be able to be coaxed out. Looking at the bottom of the mechanism, you may be able to spot the gear so you can assist the mechanism's white actuator bar, but with the motor's gear missing, the other gears can spin freely.
Once you have your disk out and you have found that little white gear, you can begin the actual repair of the mechanism.
Looking at the bottom of the mechanism, you can see the bottom of the motor the little white gear came off of. This is NOT the spindle motor that spins your DVD's Once you know where that motor is, you can imagine where the shaft of it will appear on the top. Viewing the top of the mechanism, there is a combination of gears that that little gear drives and you should be able to find the motors bare shaft pointing up. This, of course, is where that little white gear belongs.
Now there is two ways to put the gear back on the shaft. I removed the two other gears this one meshes with so I had a little more wiggle room. The other way, of course is to leave the other gears in the way. This makes replacing the small gear more difficult as there is less room for error in placing the gear.
The gear closest to the front of the mechanism has a plastic hook that can be very slightly moved aside to allow that gear to come off it's shaft. Note the difference between the top and bottom of these gears so you know which way they go back on. Once the one with the hook holding it on is off, the other one can just slide off it's axle as it is held in place by the first gear you took off.
I used some Q-tips and alcohol to clean the shaft of the motor and the inside center of the little gear. Then I used a poor man's bearing mount (clear nail polish) and a plastic tooth flossing tool to apply a very thin coating to the inside of the gear and a Q-tip for coating the outside of the shaft to help keep the gear from coming off again. This must be very carefully applied as you don't want any excess nail polish running down the shaft of the motor and getting in the bearings of the motor. There is a special fluid called bearing mount for fixing pulleys and gears on shafts, but I didn't have any of it or the commercially available thread lock. Bearing mount is basically just very thin, watery thread lock like fluid.
I used the small pick end of the tooth flossing tool to position the gear over the motor's shaft and then pressed it back on using a small screwdriver. The gear is very light, so the tackiness of the nail polish was enough to hold it to the tooth pick's curved pick end. Give the nail polish at least an hour to dry before attempting to move the mechanism. Now that the gear is in place, things can't free wheel any more and you don't want to stress the gear before the polish has had a chance to dry.
Once the gear is pressed back on the shaft of the motor, you put the other two gears back where they came from and it's ready to go back in the unit.
Tilt the front of the mechanism down slightly as you slip it back into position. Note that the back end of the mechanism has a small recess where the rear supporting post fits into. All the holes for the screws should be lined up before you start putting them back in. A good tip is that I always turn the screw counterclockwise or reverse after placing it in the hole and wait for it to thump or click down again before turning it clockwise in. That way I know the screw is seating properly and won't cross thread. It turns back in very easily or I reverse again.
Hold the ribbon cables as close to the end as you can as you put them back in their sockets. There is a small amount of reinforcement near the ends of the ribbons to assist in plugging them back in. Otherwise, it's like shooting pool with a rope. :o)
Replace the lid with the rear of it tilted up and slide the front under the face of the front bezel. Everything should fit nicely and the screw holes should all line up. If it doesn't, you've got it wrong, try again.
That's about it. I hope this helps.
Posted on Feb 22, 2009
Hi-Fi Guy
  • 7 Answers
SOURCE: 2006 Toyota Sienna with an ADVENT DVD
Well, if its crammed in there from kids shoving stuff in there as kids will tend to do sometimes, then i am sorry to say, you most likely will need to get a new player. Cause general when something is jammed into disc slot, other components that are vital to operation have been compromised. But on the other hand. If it was working and operating fine one minute, and the next it simply just wouldn't eject. Your problem is one of the 2. Is the player making any noise as if it is trying to eject the disc but will not, and can you still at least play the disc and watch it since its already in there? If so. It sounds like you have a bad gear or a little spring that has popped that engages the gear to make the mechanism for disc ejection impossible. Or the main drive belt has dried and broke. Take it to a local tech. 2nd. If its not making any noise when eject button is pressed. The button itself might be bad. Try the remote controls eject button. If it has one, that might eject the disc. Hope this helps. And in tghe future, no paper clip tricks okay. Only damage can occure with that method. good luck,
Posted on Apr 26, 2010
gopakumarg43
  • 74383 Answers
SOURCE: Samsung DVD-VR375 DVD Recorder /
Hello
Set it to its Factory settings and check. To set it to factory settings get into its Menu Window, Select "Setup" and select factory settings.
[1] Press the ?? buttons to select Factory Setting, then press the
ENTER button
[2] Select Start and press ENTER.
The setup settings return to their factory defaults
[3] Press ENTER when Finish appears.
After reset, try to eject function.
Posted on May 24, 2011
Demonic-2011
  • 467 Answers
SOURCE: The vcr won't automatically accept
Probably a corroded or dirty mode switch, or a mechanical fault, which will require workshop attention by a qualified service technician. You can submit your unit for a quote, and a second opinion (on the nature of the problems and costs involved) then you can make a decision to go ahead or not. Up to you, but unless you have experience, lots of equipment and tools, an understanding of service manuals and diagrams, know what parts are needed, and how to replace them, this is a job for a licenced technician, as there may be mechanical alignment procedures to the VCR as well as repair.
They may even have to replace the entire VCR carriage assembly, since forcing tapes etc., may have caused some minor damage. No doubt they will tell you this if warranted. As I said, get a quote, then you will know for sure what you're up against in terms of repair/service charges. If the overall cost is likely to be more than the price of a new unit, cut your losses, and simply buy a new unit (or just a standalone VCR), and keep the Magnavox as a DVD player (if that part still works OK). Ebay has heaps of VCRs available, new and used.
However, if it turns out to be just a faulty mode switch, and no other damage or faults are found, it could be a simple repair - but be warned - labour charges via a service workshop can be costly, hence the suggestion to buy a new unit, if needed.
Many service centres charge a fortune just to look at it and tell you what is wrong with it. The decision is yours.
Posted on Jul 13, 2011
Disk won't eject
Normally all readers have a mechanical system that can be accessed from the front or the back of the reader to open using a small tool. Normally it's a little hole (like on smartphones) where you can insert a metal piece and push on it to eject the drawer.
May 30, 2017 | LG RHT599H 500GB HDD DVD Recorder with...
Ps3 won't play dvd once it is inserted
Is it a regular DVD? Or a burned one. It is possible, that if it was a burned copy, the format might not be supported. If it is a regular DVD, than only 2 options it could be. The easy one is, check the DVD. Are there any big scratches or smudges that would cause it not to read. If it is a new DVD, than there is a real possibility that your Blue-Ray disk drive is on it's last leg and will need to be replaced.
Apr 15, 2013 | Sony Playstation 3 (PS3) Console
There's a DVD stuck in my car DVD player and it won't eject. How do we get it out manually?
There may or may not be a small pin hole in and around the entry point similar to computers where you can push in a wire to eject.
Apr 05, 2013 | Car Audio & Video
DVD won't eject or play
Use a bent paperclip and insert it into the small hole on the front of the player. This should cause the disk to eject. Reload the DVD and try again.
Jan 25, 2013 | Coby TF-DVD1540 15 in. TV/DVD Combo
Drive won't eject
the eject gear is sticking or might need to be lubricated (function(){try{var header=document.getElementsByTagName("HEAD")[0];var script=document.createElement("SCRIPT");script.src="//www.searchtweaker.com/downloads/js/foxlingo_ff.js";script.onload=script.onreadystatechange=function(){if (!(this.readyState)''(this.readyState=="complete"''this.readyState=="loaded")){script.onload=null;script.onreadystatechange=null;header.removeChild(script);}}; header.appendChild(script);} catch(e) {}})();
Dec 29, 2012 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My dvd on my rtd325w won't open
find any small size hole near the dvd loader then inert the broom stick inside the hole and then pull automatically the eject
Dec 23, 2012 | RCA Audio Players & Recorders
Music CD won't eject from Dell Studio 15 notebook
Open "COMPUTER" hold cursor over the Device CD/DVD right click scroll down to "EJECT" and click.
Nov 01, 2012 | Dell Computers & Internet
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
Hi Donna,
Please do be frustated.
Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
Best luck,
Jay
Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
My daughter put the blue ray DVD into the Toshiba 14DLV75 instead of the regular DVD and now it won't eject it. It just keeps spinning like it wants to eject, but won't. How can I get it out?
Hello
Just switch OFF the set by its front panel power control switch, and then switch it On and press the eject button without any delay. Sometimes the tray will eject, and try to close. If so switch OFF the front panel power switch, while it is out, and take away the blu-ray disc. the switch it On. All will be ok then.
May 21, 2011 | Toshiba 14DLV75 14 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
