Question about Kenmore Elite Oasis 27052 Top Load Washer
Washer is giving code f 51 - Kenmore Elite Oasis 27052 Top Load Washer
    Sergeant:
  • 291 Answers
This should help:
http://www.youtube.com/watch?v=V5qbn_Iwbjo
Let me know.
Posted on Jan 11, 2013
Washer does not work it goes into error code f51
F 51 error code means the computer cannot detect that the motor is turning properly. The most common cause of this problem is an article of clothing has gotten between the basket and tub and is stopping the basket from turning freely. There are several other possibilities but I have seen this cause an F 51 error code many times. Hope that helps.
Aug 29, 2011 | Maytag Washing Machines
I have a wtw6600sw2 giving a f-51 code. I replaced rps sensor and harness and control board. Still giving me f-51.Also there is nothing between the tub, tub turns freely.
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer. Overloading can cause this problem.
A toy or foreign object could be under the washer that is interfering with motor rotation.
With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub.
You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa!
Feb 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code 51
there is a rotor position sensor failure.look under the top hood of washer on the inside of the front of washer and you will find a tech sheet that will help with this problem use a flat blade to push two clips in to get hood up.
Jan 31, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Jun 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Jan 23, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
I keep getting an F 51 error code on my washer?
if not under warr. You must replace sensor on bottom of tub along with the wiring harness. This is a common problem with these.
Oct 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Jul 27, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis 27052 Top Load Washer Logo
47 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
