Question about Xerox Phaser 8500/DN Printer
ERROR PROBLEM The printer was working fine and all of a sudden the following error code appeared on the display: 09,037.45:14071 What should I do to correct this problem? Please help.
I changed the maintenance kit and now it says
Printer error 09,037,45:41334
Posted on Mar 18, 2009
Do not use the ink sticks if they have a hairline crack in them. They eventually crack and jam the printer. So far I've only noticed this with the black ink sticks. ERROR PROBLEM - 5a7294b.jpg
Posted on Mar 10, 2009
    President:
  • 2,072 Answers
One of our ink sticks has not advanced down in the ink loader.
Check your ink sticks for cracks, being twisted, or just stuck.
'One of the ink sticks is not moving all the way down to the bottom of the ink loader.
Posted on Jan 22, 2009
How do I clear error code sc542 on model 3510sf
go to maintenance mode. press clear/stop press 1 0 7 and start key(hold) until maintenance mode is displayed. look for fuser SC reset.
Sep 18, 2014 | Ricoh Aficio SP 3510SF
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Error Code E000302-0004 IR3320i
STOP: 0x000000F4 (0xF4) is a critical error message that appears when Windows is forced to terminate abnormally due to a kernel problem to prevent further damage to your computer. That is why STOP: 0x000000F4 should be fixed as soon as possible.
If you are not a PC expert use the following first-aid solutions:
(only REAL working solutions, no useless "registry cleaners"!)
for more hrlp visit https://cbrtechsolutions.net
Jan 23, 2014 | Canon Office Equipment & Supplies
Error code 55.4k
This error 55.4k appeared in printer hp color laserjet 5550. The following trouble shooting did. Orignally my printer fault is display blank.Then i replace dc board with formatter board. blank is gone dueto new ram.Machine display showed the memory process. but immediatly the error 55.4k appeared on display.The reason for this error is, communication failure between formatter and dc board.The dc board which i was replaced by old type one.Then i found exact same dc board, replaced. Error was gone.Machine came to normal status , working fine.
Oct 01, 2013 | HP LaserJet 5550dtn Printer
03130031-2F52 error
my printer suddenly stopped working and is showing the following error code 03130031-2F52. If anybody know how to fix it, please email me at alaevphoto@yahoo.com. thank you.
Oct 21, 2012 | Canon imagePROGRAF iPF8000 Printer
Cartridge Error - see user manual
It seems that you have tried most of the troubleshooting steps to identify and fix the problem. But try to replace your black cartridge with a new genuine Lexmark cartridge to determine if it's a faulty cartridge issue.
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 24, 2012 | Lexmark X4650 InkJet Printer
I have a HP 6180 all in one printer power error code
Read through NINETEEN(!) other FIXYA "solutions" for the '83C00020' error: http://www.fixya.com/tags/83c00020
Pick the one that works for you.
Jul 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Code 36.1
If powering Off & On didnt work.
Than we need to reseat the HDD.
Follow the steps mentioned on the link:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=384,E=0000000001218712366,K=3033,Sxi=8,Solution=obj(6029)
Feb 04, 2009 | Xerox Phaser 8560MFP Laser Printer
Error on the display -
I had the exact same issue with one of these printers. 83C00020 on the display with a blue background. printer will not power off.
Try this - Press and hold the OK button then press the power button to reset the printer .
I did this and it powerd on ok and is now working fine.
Apr 18, 2008 | HP Photosmart 2575 All-In-One InkJet...
Xerox Phaser  8500/DN Printer Logo
154 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
