Question about ASUS Transformers Pad Infinity TF700TWIFI 64GB, 1 Yr Int. Warranty
My Asus Transformer Infinity suddenly stopped charger and shut off instantly. I then noticed a burning smell coming from the charger. Please help!
In addition, I unplugged the tablet and replugged it again. It still would not turn on. I then unplugged it again. And that was when I noticed the burning smell.
    Genius:
  • 1,669 Answers
If it is still under warrantee, return it. If not you need to replace the power supply.
Posted on Jan 11, 2013
  • Remilee Montalbo Jan 11, 2013
    Thank you for your quick response.
  • Leigh Perlmutter
    Leigh Perlmutter Jan 11, 2013
    Please send a recommendation and good luck!
I replaced the battery it comes up but will not shut down??
Does it shutdown if you hold in the switch? If yes, most likely the issue is with the operating system not the computer.
Feb 09, 2015 | ASUS Transformer Book T100
Need user guide for infinity android 10.1 8gb
For the ASUS Transformer Pad Infinity TF700T? If so, the link to download the manual is below:
http://dlcdnet.asus.com/pub/ASUS/EeePAD/TF700T/e7048_Ttransformer_TF700_emanual.pdf
Sep 02, 2014 | Tablets & eReaders
Why will my Asus transformer tf101 not boot up can it be fixed ?
Three possible solutions, from mild to drastic--hope one of them can help.
1) In my experience, the battery can drop below a threshold voltage quite suddenly and cause the boot-up to freeze, or not start at all. Before you do anything else, be sure it's *fully* charged by leaving the tablet switched off and plugged into the charger for at least 12 hours. Then try starting it normally. If it still doesn't start up,
2) Try holding the power button down for a long press, at least 10-15 seconds. Sometimes this is enough to kick it into action. If not, you could try the nuclear option--
3) --a hard reset, which could be achieved by pressing a straightened paper clip into a small hole (*not* the headphone socket), or by holding down the power button and pressing the volume-up or volume-down button and then following on-screen instructions (check your manual). Note that this will erase all your user data and you should back up everything first, but if you can't boot I don't see how you could accomplish this.
Aug 11, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
Jul 20, 2014 | ASUS MeMO Pad HD 7
My tablet keep come on and off
If the tablet power off by itself suddenly, it might be the hardware issue already.
Please send to the service centre if it is under warranty.
Jul 01, 2014 | ASUS 32GB Transformer Pad Infinity TF700...
How to restart steps in starting up newinfinity tablet
Asus tech support phone number: 1 (812) 282-2787 or you can do a live chat: ASUS Service North America Just pick your product and you can chat with Asus.
Jun 24, 2014 | ASUS 32GB Transformer Pad Infinity TF700...
My asus transformer pad isn't charging ?
IF cable is not an fault, try to replace the power adapter, even if fails try in the desktop or laptop rear USB ports. Hope this may helps U
Feb 28, 2014 | ASUS Transformer Pad TF300 10.1" 32GB...
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
My brand new asus transformer pad tf700 will not charge just flash twice
I had this problem, then I disconnected the two black plastic parts of the plug, and there were two steel pins in there, I thought they were leaning in a bit, so I just bent them away from each other, put it all back together and my charger has worked fine ever since.
Sep 19, 2013 | ASUS 32GB Transformer Pad Infinity TF700...
ASUS Transformers Pad Infinity TF700TWIFI 64GB, 1 Yr Int. Warranty Logo
307 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
