Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
Kenmore 52559100 compressor relay
Relay
Kenmore freezer overload relay went out so i fixed it for about two days . why would it be blowing the overload relay, bad compressor maybe ??
is the relay side sensitive? installed upright? what's starting amps on compressor? verify all connections tight, obviously replace start kit first but possibly compressor going bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 15, 2018 | Kenmore Heating & Cooling
I have a water leakage coming out the bottom of my kenmore refrigerator model 52559100
check your defrost drain line. can be located in freezer section. also if you have a filter at the bottom make sure the housing is not cracked. If your frig is cooling then the coil is going to be doings its job
Jun 08, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Mine is a Kenmore Coldspot. model #52559100 Serial #SL4336967. The entire door frames are extremely hot. It is coldish overall, but nothing is freezing. Is the cooling fan usually what needs fixed?
Check condenser fan, located next to compressor - is it running? If not - replace! Also check condenser coils - are they covered with lots of lint, dust and etc? If so, clean.
If the above mentioned do not solve your problem - unplug fridge, call a service technician.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC "Where Quality Same Day Service is Our Goal"
Aug 29, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Have Kenmore 106.8607913, top freezer. Not cold enough. All fans working. Cleaned bottom coils. Not ice bound. Compressor clicks on, then off about 1 or 2 seconds later. Compressor or thermostat,...
If the fans continue to run when the compressor kicks off the thermostat is functioning normal.
The problem could either be the compressor itself or more likely the start device (relay) that controls the compressor, it is an easy component to replace and mounts directly to the compressor.
The part number for the relay is 989662
If the relay is good and compressor is bad, you would be looking at about $500.00 to repair
Apr 18, 2010 | Kenmore 64802 Top Freezer Refrigerator
Both the ice dispenser and the water dispenser quit at the same time on my kenmore 52559100 refrigerator. The icemaker still functions. Possible solutions? Thanks.
Check the wiring plug where the wires connect from the fridge and the door. Sounds like you may have a bad connection or it has come unplugged.
Please rate solution
Sep 06, 2009 | Kenmore Refrigerators
Kenmore frig freezer will go to 20 degrees and stay there
sounds like either the compressor is out or the relay that starts the compressor is out. I would try replacing the relay/overload on the compressor and hope for the best. if you have a continuity tester then check from each of the 3 posts sticking out of the side of the compressor that the relay/overload push on to fo one of the copper pipes coming off the compressor..no continuity is good if you get continuity then the compressor is shorted and ruined
Jun 13, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Replacing a relay switch on a Kenmore Side by Side
The start run relay kicks the compressor on. If your compressor is running this is not your problem.
There are a number of things that can cause a fridge not to cool. A bad defrost system.. Check to see if you have ice build up in the freezer, or a lot of frost. Also a bad compressor. The relay switch sits on the compressor at the back of the fridge. If you put a new relay on and it won't start the compressor you have a bad compressor. Most compressors are warrantied through the manufacturer for at least 5 years. So if it's that call the manufacturer for replacement.
Apr 15, 2009 | Kenmore Refrigerators
Compressor will not run
mostly the relay called a PTC relay. If you have a ohm meter you can ohm out the compressor just to make sure but pretty sure the relay. ken
Jan 11, 2009 | Kenmore 50522 / 50524 Side by Side...
Freezer defrost and meltdown
may be timer defrost thermostart or heater
Oct 07, 2008 | Kenmore 53092 / 53094 Side by Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
