Question about Solar 2-wire Pull Chain Light Switch For Ceiling Fan Lights
2-wire pull chain switch wiring in a ceiling fan light kit
1 blk, 1 wht wire coming down thru fan to 4-light kit - replacing 2-wire pull chain switch, but (dummy me) removed old b-4 noting how wires were connected - 2-blk wires off switch: if 1 goes to blk (hot) from fan, where do I put the remaining switch wire?
  • ndcsbc Jan 22, 2009
    problem is that when i put 1 switch wire to the (hot) blk fan wire & the other switch wire to the neutral (wht), i think it shorted out the light kit - only 2 wires (blk & wht) coming down to light kit & therefore avail. for the switch - guess now i have to replace the light kit fitter?
  • 10,865 Answers
If you removed a switch there should be two wires. Connect one of the wires to each of the switch wires or screws. good luck
Posted on Jan 22, 2009
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ... > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ... Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
Ceiling fan model 1660
Always write down which color wire goes into which slot on the pull chain switch before removing it. All I can tell you is the black wire usually goes into the L. The others you'll have to play with. Also, just because the switch looks the same on the outside doesn't mean it's the same on the inside.
May 26, 2013 | Dryers
Hunter bay with lights model: EF200DA-52 I get the wht goes to the white blk goes to the blk what does the Blue from fan go?
The blue wire is for your light kit. Tie it in with your black wire if there are only a black and a white.
Aug 17, 2011 | Hunter Ceiling Fan Control Switch
Old fan switch has 4 wires, new one has 3. A Ceiling fan light switch is for the fan, not the light, correct?
You have 2 questions:
1) Pull-chain Switch question:
You need a fan switch with 4 wires.
Your pull-chain switch has one wire that connects to Hot from wall switch. And then one wire for each of the 3 speeds.
Best way to start is to test the old switch with continuity tester.
Compare results with following image of 3-wire switch for general reference:
2) Ceiling fan pull chain switch is for the fan only.
Jul 18, 2011 | Westinghouse Electric Ceiling Fan 3-way...
twist the 4 black wires from the lights together and use a wirenut to either connect them to one side of the switch or to a pigtail that will go into one side of the switch. The other side of the switch will be wired to the hot wire coming from the fan meant for the light kit. All of the whit wires get twisted together and connected to the neutral light wire coming from the fan. If you've already connected it that way and it doesn't work, the switch may be defective.
Jun 26, 2011 | Westinghouse Electric Ceiling Fan Light...
Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
May 24, 2010 | Westinghouse Electric Westinghouse...
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
52in nassau indoor/outdoor fan 129-909 floor model no instr
white definately goes to white. however you configure the red, black and blues will only determine which switch on the wall controls the fan or light. as for the bare copper, the fans typically come from the factory with a green pigtail screwed into the top of the downrod
Aug 17, 2009 | Hampton Bay 24002 Ceiling Fan
Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
Mar 12, 2009 | Hampton Bay 24002 Ceiling Fan
Ceiling fan pull chain switch replacement
OK, this is easy, it just seems hard. First off, take all the white wires from the light fixture's clusters, and hook them to the white feed wire. Now take the black side of the cluster of wires, and attach them to one side of the switch. It does not matter which side. The other side, goes to the feed wire that is black or what ever feeds the light. The switch only acts as a valve for one side of the loop. I could explain why some switches have a black and white, but I will leave that alone, so I do not confuse the issue.
Jan 22, 2009 | Solar 2-wire Pull Chain Light Switch For...
Solar 2-wire Pull Chain Light Switch For Ceiling Fan Lights Logo
640 people viewed this question
Top Solar Electrical Supplies Experts
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
