Question about Bose 321 GS series II
My Bose 321 System turns red to green when playing a dvd.
Recently found red colors on dvds turning to green. Checked the connections in the back of the bose, but nothing is loose or not connected. Options?
freetek
  • 5568 Answers
SOURCE: Bose 321 won't turn on
I'm amazed at the range of comments regarding this system; they range from unbridled enthusiasm to some **** words.
Before I try to help, if I am not familiar with a specific model but have a clue to what the nature of the problem might be, I research the item to see if I find some support for my suspicion.
You might keep tabs on some comments I found relating to a possible class-action lawsuit due to the array of problems that have appeared with this system.
This link will give you a sample of them:
http://www.amazon.com/Bose-DVD-Home-Entertainment-System/dp/B0002JY6SQ
Posted on Oct 17, 2008
  • 905 Answers
SOURCE: bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: I have Bose 321 system w/ DVD player. I connected
That happened to me---there's something loose in the jacks leading out of the Bose to the TV. I thought it was just mine. You just have to jiggle them and you'll get color. That really sucks.
Posted on Jun 17, 2009
Ganx
  • 113 Answers
SOURCE: Audio problems with Bose 321 system
Hi, sounds like the centre front speaker is disconnected. Check the wiring on that, if all is good there then a fault most likely with the amp. To make sure try connecting a different speaker to the centre channel just for test purpose to eliminate a speaker/cable fault. Best of luck
Posted on Jul 12, 2009
  • 8 Answers
SOURCE: connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Posted on Sep 12, 2009
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
The color is off on my Bose 321 DVD player. Pictures have a red tinge, and seem to be missing the blue tones. The television displays great color except when playing DVDs.
I just had the reverse trouble, the people were all blue. What happened is that two of the composite jacks were reversed. Check to make sure a cable is not unplugged, and that they are all in their right spots.
Nov 28, 2009 | Bose (321GS) System
Our Bose 321 Entertainment System is only playing DVDs in black and white - no color at all.
Be sure that in the setup menu, you are selected for the correct output format (either component which is BLUE/RED/GREEN + audio or composit which is just YELLOW + audio. If that is correct, I would suggest a call to the BOSE technical support center.
Sep 08, 2009 | Bose 3 2 1 GSX System
Ipod nano connector for Bose 321 GS Series III
OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
Please take a second and rate this response
THANK YOU!
Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
My Bose 321 system wont play CDs but it plays DVDs
lasers need changing expensive £200 or more
Dec 17, 2008 | Bose (321GS) System
Hooking up bose 321 to my tv
I am about to go through the same process. I have a Bose 321, and am on the verge of getting a HDTV. From what I can figure, the Bose can play a dvd and input it to the HDTV via video and audio output plugs off the back of the Bose to the audio/video input jacks on the back of the new HDTV. I think individual cables will have to be run for each. They usually are red or white, sometimes green or blue. I am sure everyone has seen these in their life. The Bose 321 technology only had what was called an S-Video cable output for the best picture, which is how my current tv gets it's Bose signal, but now HDMI seems to have superceded S-Video. Therein lies an obstacle to be overcome.
Dec 14, 2008 | Bose 321GS Series II System
Burned dvds wont play on home player
i have begun having a problem with my  4-5 year old bose 321 system.  sometimes dvd's burned on my computer will not  play on my bose 321 system.  sometimes they will.  what's up with this?  it's not a bad media problem.  i've narrowed it to the player.  sometimes i'll play a computer burned dvd on the bose and it will play fine.   next time i try to  play it it won't any ideas? thank you in advance mike
Dec 04, 2008 | Televison & Video
CD stuck in disk tray of (original) BOSE 321
NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
Nov 23, 2008 | Bose 3·2·1 II System
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
DVD Will not play - CD Does Play
The laser is burned out. The laser is out of place. My bose has this problem.
Dec 18, 2007 | Bose 3 2 1 GSX System
Bose 321 GS series II Logo
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
