Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Rear projection tv wont stay on
Power went out at my house for about an hour and a half. When it came on everythig came on except my tv (Pioneer rear projection). When I go to turn it on it trys lasts about a second and then off. Anyone know what this is and will it cost alot. Thanks Jeff Maxwell
  • 32 Answers
It is a great chance Jeff that your Power Supply Board (specially the FlyBack) could not hold the voltage requirement to let your TV set on. When local Power Utility supplier is shutdown for whenever reason, this kind of situation occurs. Voltage spikes, voltage outage, voltage drop and dimming are common things. You could replace the FlyBack and then check out if the TV stays on. This will cost you from $60.00 to $80.00, but it will not guarantee that it was the only component that suffer the shutdown. I really suggest you to replace the main power board (from $175.00 to $250.00 - with core exchange). It is something you can do on your own and I'll recommend you to check on the following site (my favorite to buy parts): http://www.vancebaldwin.com/ SithPitt
Posted on Jul 03, 2007
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer PDP - RO6U Plasma: Says starting up, please wait when turning on. Can't get past this screen. I have tried unplugging and plugging everything back in and am still getting the same error. Are...
unplug it from the power for one hour. Than Press and hold the power button on the on the TV for 20 seconds(It wont show anything. Than Release the power button....
After that plug the power and check the same...
Sep 14, 2008 | Pioneer Televison & Video
Accidently pushed a button and then the tv went fuzzy so i pushed standby but nothing worked, then i pressed power and it keeps clicking on and off and wont stay on
Check power supply board located on the Right bottom board,in the middle is a 6amp Fuse it could be blowed.
Located on the Left Hand side should be the Big Black ICs will have part number on them STK392-110 ,Bad STK ICs can cause this also.
Mats Electronic Parts 1-800-628-1118 they will have ICs ,ect...
Jul 20, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv wont turn on
awesome tv's but by now would have connection troubles look around on the main board for bad connections, use a magnifier for best results
Jun 21, 2010 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
Infocus 61md10 wont boot up
Unplug it from power source for an hour to two hours reconnect and turn on
Aug 16, 2009 | InFocus ScreenPlay 61" Rear Projection...
Pioneer 50 inch projection tv won't turn on
I only fine 5 fuse where is the 6 fuse locate? Please help I found the 5 on the power board... is the 6 fuse somewhere else not with the power board?
Mar 15, 2009 | Pioneer SD-P50A3Q 50" Rear Projection...
PRO 510HD PROBLEMS
if you know anything about the tv, take off the back and remove the power supply board. Reflow or resolder the solder points, takes like 2 hours, but is well worth it as my tv works fine now. make sure to use rosin core solder and good luck
Sep 11, 2008 | Pioneer PRO-510HD 53" Rear Projection...
Sony tv not turning on
I would need the model number to look service codes
Feb 24, 2008 | Televison & Video
Pioneer PRO-710HD 64 in. Rear Projection
could be your projection lamp.. check the manual for how to check
Oct 01, 2007 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
60 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
