Question about Dell Latitude E5420 Notebook
Dell e5420 close lid power problem
I have windows7 loaded. Power settings are set to never turn anything off when the lid is closed. Sometimes when I close the lid, the laptop dies (doesn't shut down). When I open it back up, I have to press the power button and windows starts up again from scratch as if it crashed. It doesn't happen every time, but usually after a few days of running (I hibernate it overnight), it is more likely to happen.
  • Rozz Jan 14, 2013
    just to be clear, its not a Windows power-settings thing. The laptop occassionally DIES (not shutdown, sleep, or hibernate).
    New Friend:
    Problem Solver:
  • 5 Answers
DEAL WITH IT THE ONLY WAY TO FIX IT IS TO GET A NEW FLEX CABLE
Posted on Jan 11, 2013
  • Rozz Jan 14, 2013
    what's a flex cable?
4 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: Dell Inspiron 700m won't start
It sounds like there is an issue with the system memory.
Remove both the power adapter and the battery. Turn the laptop over and locate the RAM (memory) cover and remove the holding screw.
Take out the system memory and clean the brass contacts, also clean the slots that the memory sits in.
Re-seat the memory making sure it clips into place nice and tight and replace the RAM cover.
Return power to the laptop and turn it on to see if that has helped.
If it still won't boot up then you may need to purchase new memory for the laptop.
Good luck.
Posted on Sep 28, 2009
Testimonial: "leecom72, Thank you for the prompt advice. I tried it cleaning it, but still not working. I'll try new memory (wanted to upgrade anyways). Thanks!"
SOURCE: Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Posted on Oct 01, 2009
techabhishek
  • 66 Answers
SOURCE: Dell XPS M1530 Ethernet Issue
This has been a known issue with XPS M1530. You can try changing the power options for once. Try flashing your BIOS to version A12. If it still doesn't work, you may have to opt for replacing your motherboard.
Posted on Mar 19, 2010
Testimonial: "Thanks"
Laptop will not shut of after closing the lid
In Windows XP, Open Control Panel, Power Options, set to High Performance, set Sleep and Hibernate to no/never, set what to do when lid is closed. Use this procedure: http://windows.microsoft.com/en-us/windows-xp/help/setup/configure-power-management It's a good idea to Shut down at Start Menu and unplug when not in use to prevent damage due to power surges, and IF the battery malfunctions, prevent a fire hazzard.
Feb 25, 2013 | Dell Inspiron 1501 PC Notebook
What is the problem? Open Control Panel, Power settings, Advanced power settings, set to High Preformance, Set Sleep and Hibernate to Never , Set Lid close to Shut Down, adjust setting to your preference, Always shut down your Laptop, unplug when not in use. Remove battery if you use on AC most of the time, your laptop will last longer and a boot everyday resets the computer.
Jan 11, 2013 | Dell Latitude E5420 Laptop Computer
My hp pavilion dv7 keeps running after the lid is closed
Change the settings in the Power section to shut-down when lid is closed. Power Settings, Advanced Settings, Change setting to shut-down when lid is closed.
Oct 29, 2012 | HP Pavillion Dv7-6165us 17.3" Amd...
How to close PC laptop lid with external monitor
You need to change the pc power settings, so closing the lid does not turn off the computer.
Open the Power settings by clicking on the battery icon in the bottom right hand of the screen.
Save the settings and it will stay on until you press the power key to turn it off.
Apr 14, 2012 | Dell Latitude E4300 PC Notebook
I have a dell Vostro 3500 with a Kensington notebook expansion dock. How can I close the laptop but continue to work using a seperate monitor & keyboard?
Right click the desktop and go to the settings tab. then click on the power settings tab and set the option for what happens when the lid is closed and tell it not to do anything.
Mar 31, 2010 | Dell Docking Station for Latitude D600
Closing lid on notebook, Dell Inspiron 17, with OS Vista, causes screen to blank
I am guessing that you must have an external monitor attached and are attempting to close the notebook and use only the external monitor? If so, there is a setting in "Power Options" to allow you to close the lid and not go to stand-by.
*Go to your Control Panel (Start, Control Panel)
*Select Performance and Maintenance, then Power Options - or - if you are in Classic View, select Power Options
*Select the Advanced Tab
*Under the Power buttons section, select "Do nothing" from the drop-down for "When I close the lid of my portable computer"
Feb 21, 2010 | Dell Computers & Internet
My dell C610 Screen does not come back on when i reopen the lid. I turn the computer on use it then close the lid for about a min then reopen it and the screen just stays off but the computer itself is...
Known issue. The windows default settings for power saving mode tell the computer to switch it off (sleep) when the lid is closed. The sleep mode doesn't turn completely the computer, just the visualization devices (mainly screen, also some other components not required for the computer).
What I would advise you to do after restarting the computer (press on the power button for a very long time, until you cannot hear it working), is to change the power settings.
go to control panel, choose "power options", then see if you have "choose what closing the lid does". If it's not there (not all laptops show this option), choose "change when the computer sleeps", then change " put the computer to sleep" to "never".
That should do it. if you have any questions feel free to ask me.
Dec 07, 2009 | Dell Latitude C610 Notebook
I have a Dell XPS-16 and would like to use it with remote minitor and keyboard with the lid closed. How can I set up a hot key on the remote keyboard to start the system when the lid is closed?
You can caust the system to NOT turn off--do nothing--through Control Panel/Power Options Properties/Advanced tab Power Buttons section. Select Do Nothing for When I close the lid....
The remore keybaord you choose may or may not have hotkey options for turning your laptop on and off.
Nov 28, 2009 | Dell Studio XPS 16 Notebook
Software problem
Does this happen every time you download something from the internet?
Has the computer turned itself off while doing anything else?
How to Stop Laptop/Notebook Goes To Sleep or Hibernation when Closing Lid in Windows Vista
  1. Log on to your computer as an administrator. Click on Start, go to Control Panel -> System and Maintenance -> Power Options.
  2. Click on Change plan settings for the currently active plan.
  3. Click on Change advanced power settings link.
  4. In the “Power Options” dialog box’s “Advanced Settings” tab for the active power plan, expand Power buttons and lid.
  5. Expand Lid close action.
  6. Change the value to Do nothing for “Lid close action” by selecting a new option from drop down menu for both On battery and Plugged in.
740549c.jpgBased on own preference, it’s possible to set other action from the menu too. Available for selection is Do nothing, Sleep, Hibernate and Shutdown.
  1. Click OK button.
How to Disable Notebook Computer to Stand By or Hibernate on Closing Lid in Windows XP
  1. Log on to your computer as an administrator. Click Start, and then click Control Panel.
  2. Click Performance and Maintenance.
  3. Click Power Options.
  4. Click Advanced tab.
  5. Under “Power buttons” section, select Do nothing from drop down menu for When I close the lid on my portable computer option.
e461aeb.gifAgain, any other settings such as Stand by and Hibernate can be set based on own preference.
  1. Click OK button.
Let me know if this helps - if not - PLEASE, further clairify so we can continue to find a fix for your problem....
Jul 22, 2008 | Computers & Internet
Dell Latitude E5420 Notebook Logo
207 people viewed this question
Alun Cox
