Question about Sharp LC32D62U 32 in. LCD HDTV
Color lines running down the screen
I have a sharp LC32D62U TV, starting yesterday i am seeing yellow blue and red lines running down all along the panel. My extended warranty ran out in 2011, and I have already done all the standard no duh checking. Switched cables, tried different systems, PC, PS3, TV, when its on a blank channel/input there are only blue lines, anything else i see the lines running down the screen. What should I do?
  • Sharp Master
  • 8,617 Answers
That can be caused by either the Tcon or the panel itself may have an issue. The TCon is most likely though. Your audio works correct right? I would try a new TCon you can get them from www.tvrepairworld.com
Posted on Jan 11, 2013
  • 9 more comments
  • Nabeel Akhtar Jan 11, 2013
    Im not familiar with what a Tcon is exactly? But you are correct the audio itself works perfectly fine. I will contact them and see how much it will run me. Will report back when its solved. You wouldnt happen to have a link handy about changing a Tcon? I will Google it too. Thanks again
  • Nabeel Akhtar Jan 12, 2013
    So someone from tvrepairworld corroborated what you have told me that it sounds like a TCON board issue. I am asking for specifics as to model, serial, etc that i need to ensure that match my TV. If so then i will order it and try it. If it solves the problem i will update here. Thank you again for pointing me in the right direction.
  • Sonny Berry
    Sonny Berry Jan 12, 2013
    I would match the numbers directly from the circuit board itself as various Tcons were used based on the panel used in your version .
    You have been a great help. I have located the part number/serial number off the TCON board, found some websites that are selling it online. I am waiting until tvrepairworld returns with a price for me. Thanks again...will keep you posted.
  • Sonny Berry
    Glad that I could assist with th issue
  • Nabeel Akhtar Jan 19, 2013
    So I received the new TCON board today and promptly went to install it. I went and installed it. Secured everything exactly the same way as before. The TV now turns on, solid green power light for about 5 seconds or so then shuts off. I get three blinking lights on the OPC, then the power and OPC blink three times in sync repetitively.
    Okay update, now the power and OPC lights blink twice, followed by the OPC light blinking 3 times
  • Nabeel Akhtar Jan 21, 2013
    Update: The rep from Tvrepairworld just emailed me asked me to reseat all the cables attached to the tcon board and anything else that i may have missed. Going to do that now and update once its done.
    Update: I put my old TCON board back in to make sure the cables arent the things that are messed up. The TV turns on fine, and stays on, no blinking lights or anything.
  • Nabeel Akhtar Jan 28, 2013
    Anyone?
  • Nabeel Akhtar Feb 19, 2013
    Just an update for those following. Sonny has been insanely helpful at trying to troubleshoot this problem. Unfortunately the tcon board didnt work and i have shipped it back. I reached out to Sharp themselves, and they referred me to a local repair shop. I dont know how much it'll cost though as it is 50 just to have it looked at because it is out of warranty.
  • 71 Answers
SOURCE: Sharp Aquos Color Variations
Put the OPC off and check the conection for Pb signal.
Posted on Dec 06, 2007
  • 14 Answers
SOURCE: green vertical lines
Possibly needs a new control circuit board or lcd panel
Posted on Jul 25, 2008
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Posted on Aug 23, 2008
  • 346 Answers
SOURCE: Blue horizontal and vertical lines
poor convergence
Posted on Nov 12, 2008
DRebel
  • 19 Answers
SOURCE: Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Posted on Apr 03, 2009
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Mitsubishi tv model wd 73727 and how to take tv apart to clean marrow
my mitsubishi 73" set is 4+ years old. all of a sudden the color is all wrong. after a couple of minutes of clear picture the colors change--blue is green and red is yellow. a little while later everything has a red tint to it and there is a line going down the center of the screen. to the left the picture is still relatively sharp, but the right hand side is terrible. I'm hoping this is just the lamp.
Rick
Woodland Hills, Cal.
Apr 12, 2009 | Televison & Video
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
Plasma TV technical difficulty
if you can still see the picture its most likely the control board that's going bad, you will still need a tech out to fix the issue.
May 19, 2008 | LG 42PX5D 42 in. Plasma HDTV
Mitsubishi convergence Problem
You only have 3 colors Red, Blue, and Green. No black or yellow. I would say look for self test diagnosic on here or other sites.
Jan 13, 2008 | Mitsubishi VS-60607 TV
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
Sharp LC32D62U 32 in. LCD HDTV Logo
249 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
