Question about Maytag Dryers
Gas dryer replaced flame sensor and still not getting hot
We replace the flame sensor and the flame turns on but the dryer does not stay hot
    President:
  • Maytag Master
  • 1,922 Answers
Replace the gas valve coils on the top of the gas valve they get weak from the heat and can't keep the gas valve open
Posted on Jan 12, 2013
SOURCE: Gas Dryer Problem
I would change both coils anyways,they can go bad after they heat up.
Posted on Nov 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: samsung dryer smells like gas
Replace the operator coils. They are intermittant. Typical operator coils look like this:
Posted on Dec 16, 2008
onthejob5130
  • 640 Answers
SOURCE: GGW9868KL0 SENSEON GAS DRYER Flame comes on but clothes not dry
since you know your stuff and our exhaust is clear correct,,,change your gas vavle coils ..if weak they will shut unit down in a couple of mintues..
Posted on Dec 30, 2008
  • 17 Answers
SOURCE: Gas dryer flame won't stay lit
Check for a blocked vent.
Posted on Mar 12, 2009
SOURCE: maytag gas dryer not heating
You may want to disconnect the vent from the back of the dryer and try it. Flame rollback will cycle the burner off by the high limit.
Considering what you have already done to it, if the problem still exists you probably have bad coils on the gas valve. make sure you replace them as a set.
The thermal fuse is a one time device. If it opens, the burner will not come on at all.
Posted on Apr 29, 2009
I have a model LGA30AL gas dryer. It will start up occasionally but will only stay lit for a short time. I have already replaced the Igniter. And found a small leak in gas line. I replaced that also. What...
The gas assembly consists of: The ignitor, the flame sensor, and the solenoid coils. The ignitor and flame sensor are either going to be good or bad no in between. The only thin in there that can get intermittent is them solenoids. They get hot and quit but after a long while they cool back down and work another time. themobilian_2450.jpg
Amana service Manual
Jun 14, 2011 | Amana Dryers
Dryer starts, runs 10 min. flame shuts off, ignitor comes on again, but gas value does not open. i have replaced the flame sensor, but still will not open gas value.
What's happening is them solenoids are getting hot and when they get hot they fail if they are a bit aged. Replace em and party on.
May 13, 2011 | Amana ALG866SB Gas Dryer
Dryer starts , the gas lights and stays on for about 30 bseconds and turns off the dryer stays running without heat. How can I fix this?
Hi and welcome to FixYa, I am Kelly.
This is usually caused by a failed flame sensor PN 338906. Loss of a flame sensor signal (open) will cause the gas valve to shut off in 30 - 42 seconds
How to test the flame sensor:
  • Remove the front panel
  • Open the top panel
  • Leave the drum & belt the way they are, work around them and be careful NOT to get the belt idler pulley disconnected
  • Disconnect the wires from the flame sensor
  • Set your multimeter to read ohms
  • Take a reading between the 2 terminals on the sensor.The reading should be close to 0 ohms but for sure under 1,600 ohms 3 wire type and 500 - 600 ohms for the 2 wire type.
  • If the reading is infinity, the sensor must be replaced
If you can reach the flame sensor through the gas burner access (if so equipped / depending on model) it is even better because you don't have to open the dryer up.
Just note there are 2 types of flame sensor out there. One has 2 terminals and one has 3 terminals. the links below are for the 2 terminal flame sensor.
Sources to purchase the flame sensor:
http://www.appliancepartspros.com/part_details.aspx?part_id=2910747&pn_=338906
http://www.repairclinic.com/PartDetail/Flame-Sensor/2681
http://www.searspartsdirect.com and enter part number 338906 search top of page
Video on how to replace the flame sensor
Thanks for choosing FixYa,
Kelly
Feb 27, 2011 | Maytag Dryers
The igniter wasnt igniting.. i changed it. it ignites and gets hot for a few seconds then goes out. may have put the thing back together wrong. help
The problem is either the flame sensor or dryer coils. First check the flame sensor also called the radiant heat sensor for continuity. If it has none replace it. If it does have continuity the dryer coils need replacing. They are easy to check and replace. Here are a few links that should help
Replacing the dryer coils
Flame sensor replacement
Troubleshooting a gas dryer
Oct 22, 2010 | Dryers
Gas dryer is not getting hot. ignitor replaced. gas line replaced.
It is either the 2 gas coils on top of the gas valve in the dryer, or the flame sensor on the side of the flame tube. If the ignitor lights, but no flame, it is the coils.
Jan 14, 2010 | Washing Machines
Dryer won't get hot
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Aug 12, 2009 | Dryers
Maytag DG482 Dryer Won't Heat
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor
a%20igniter.jpg Ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils
part# 279834
The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks. SOURCE
Jul 07, 2009 | Maytag Dryers
Won't stay lit
You ignitor is working and sensor is working because it will fire up. so those pesky coils are intermittant because they get hot and quit cool off and work some more . replace them
cc8e664.jpgHere is a little ditty I wrote some time ago about this subject
INTERMITTANT COILS
Mar 07, 2009 | Maytag MDG6000 Dryer
Kenmore gas dryer not heating up
ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Nov 27, 2008 | Dryers
Gas dryer with no heat
check the ignition might be a glo-bar element or a maintained high voltage spark module. once there is a pilot a flame rod or a millivolt generator opens the main valve for fire.
Sep 03, 2007 | Whirlpool LGR7646E Dryer
Dryers Logo
381 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
