Usb error in tajima
Error BC 3 when using USB
2 Suggested Answers
99rannellis
  • 12002 Answers
SOURCE: HOW ARE YOU TAJIMA TEAM, how do i fix error bc3 on tajima embroidery machionery, we dont know if its software problem or usb port need to be replaced
May be some help here:
Tajima Error
Posted on Jan 17, 2018
How do you correct/fix a 316 error/main shaft motor error on a Tajima 2 head embroidery machine
I hope this link will help.
http://www.digitsmith.com/tajima-tmfd-g1220-type-2-error-316-a-31639.html
Sep 28, 2017 | Sewing Machines
Tajima embroidery machine
Hello, Error 225 Travel outside the set embroidery area
( When the software frame limit is set, or
on cap machines) Here is website for all the errors:
May 17, 2014 | Sewing Machines
Work around for USB Device Software for Compaq nx6110, Windows xp SP 3. my laptop some times refuse to detect and read the USB devices like : flash disk, external hard disk, modem,... it use to write that...
first off why run XP the Virus magnet?,Microsoft and hp dropped
support on this 3 years ago,,
not only that XP does not support most USB devices.
sure some old devices, but not new ones. (unless maker says otherwise and offers software to run on XP)
you are direct connected. to USB to external HDD.
That external disk, my guess has no external supply right?
that means it will overload many Latptops
the power spec, on USB varies, by different ports used and maker of the laptop...
I solve that horror by only buying external HDD what have wall power pack connected, mine is 12vdc 2amps, and will work on any PC made , ANY !
it uses its own power, so never overloads that weak PCs USB port.
here is the USB spec from WIKI page "USB" 0.5amps is gutless.
  • 0.5 A (USB 2.0)<<<<<<<<<<<<<<<<<
  • 0.9 A (USB 3.0)
  • 5 A (BC 1.2)
  • 3 A (type-C)
  • Up to 5 A (PD)
0.5 amps that is, 500mA, about 1/2 what hdd needs. to be happy.
yours is the first one, the weakest they made.
that is not enough current to spin up any HDD, from dead start.
cures: (all)
  1. get an external SSD drive,
  2. use and external case on external drive with its own powerpack
  3. buy and an EXTERNAL USB powered hub that is USB3 rated and it might run your drive connected to it.
  4. get newer laptop, one with USB 3 and runs w7 or newer.
Jun 27, 2017 | HP Computers & Internet
How can I fix this error 3D7 in tajima
how to remove error 3d7 for tajima tmfd machine
Oct 27, 2010 | Tajima Drills
Cannot find my instruction manual. can you charge the battery on the computer using the usb cable?
No, the battery cannot be charged using the USB cable. You need the supplied battery charger. If you've lost it, you'll have to buy a BC-CSK or BC-CSKA charger from Sony.
Jan 13, 2010 | Sony Cyber-shot DSC-W180 Digital Camera
What is a 211 error code on a tajima 2 head emb machine
A 211 is generally caused by the degree wheel not resting in the "red" zone. This zone indicates the machine is in a ready state to start or shift. Look at the degree wheel and manually move it to the zone (around 100-110 degrees). If this doesn't work it will need repaired. It usually takes 1-3 hours depending on what is involved.
Sep 30, 2009 | Tajima Drills
FY100
From all the info I can get it is the same chassis as a brother PE100. It used custom eeaprom cards and read .PEC or .PES files.
It could also be like the Bernette Deco 500 or 600 series. I have also seen a modification of this chassis called the EM10 by Husqvarna and it is USB direct connect and comes with software that outputs .HUS files.
Jan 29, 2008 | Sewing Machines
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
