Question about Keurig B31BLACK Mini Brewer Black 1-c
Mine has clear water, not heated dripping down before it finally heats and dispenses properly
Clear water dripping before water heats and dispense with coffee thru the k cup
  • 1,511 Answers
Lid not engaged correctly, pull down firmly.
Posted on Feb 01, 2014
  • 421 Answers
SOURCE: does not dispense enough water
When was the last time the unit was descaled? A build up of scale will gradually restrict and then stop the water flow.
Posted on Feb 02, 2010
  • 3 Answers
SOURCE: my keurig model b66 coffee maker is not dispensing
Run the descaling operation as described in the manual. If this doesn't do the trick, get a can of compressed air with a nozzle on it and blow the air into the upper nozzle, the one that pierces the cup on top. This works when the descaling isn't the problem.
Posted on Mar 31, 2010
  • 40 Answers
SOURCE: The Keurig is heating up the water, yet is does
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
Posted on Oct 07, 2010
SOURCE: Does not dispense water unless you pinch vent in water tank.
If your Keurig is putting water out the vent and back into the reservoir. Open the front, using a flashlight and a toothpick, clean the coffee grinds out of the little hole in the needle that pierces the K cup. When it becomes clogged with grinds the water either has to come out the vent or the coffee maker will burn out. It is a safety mechanism.
Posted on Feb 15, 2011
heatman101
  • 43501 Answers
SOURCE: my keurig only dispenses half
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
Why is my coffee weak?
If it is a drip maker, only gravity drives the hot water thru the coffee grinds. If the coffee is ground too fine, it immediately packs up and doesn't let water flow thru it and the water flows around the coffee instead of thru it.
Try using a coarser grind, and if not you can use a lot smaller amount of coffee and water. A smaller amount of coffee is easier to diffuse thru than a large amount.
Another thing is to slow down the water speed entering the coffee basket. I found the best way to do that is to use water just above freezing and place that extra cold water in the reservoir. The cold water takes extra time to be heated up by the coffee maker so less water is released over the coffee grinds per minute.
If your coffee maker overflows a lot, that is a good indicator that the grind is too fine and/or your coffee filters are too flimsy and are plugging up the channels in your coffee basket and the coffee can't enter the flask, so it overflows.
But the easiest way to check out your coffee maker is to use extra cold water and just run half batches (5 cup) of coffee instead of 10 cup
Feb 25, 2015 | Coffee Makers & Espresso Machines
Cabrio wtw7600xw2 when water enters the bleach or softner dispensers it runs over and leaks on floor. I've cleaned the outlets their clear. Seems too much water comes in to dispenser areas.
If the lines to the drum are clear and draining properly then you will need to replace the water inlet valve since it is allowing to much water to pass through to the dispenser. Here is that part to order. Whirlpool W10326913 Valve AppliancePartsPros com
Mar 03, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
Front door drip
Inside the refrigerator there is a coil of clear tubing that goes to the water dispenser. Pinch off this line and then you can have ice once again
Jan 23, 2014 | Maytag MZD2669KEW Side by Side...
Starbucks Saeco Italia Digital Barista Fully Automatic Coffee Machine will not prime!
Here is what is said in the manual:
"Direct the steam arm on the drip tray.
Open the steam/hot water knob until a
steady stream of water is dispensed. Close
the knob. Insert the filter holder into the
brew head to pre-heat the filter holder.
The machine is now ready to dispense
coffee."
Apr 26, 2017 | Starbucks Saeco Italia Digital Barista...
Fabric conditioner not going down
Fabric conditioner does not always go down, maybe you have a blockage on soap drawer, This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jun 03, 2012 | Whirlpool Washing Machines
Water constantly dripping from water dispenser in fridge
first try to run about a gallon of water through the dispenser to clear any air in the lines that compesses and forces out the water, if that does not work try changing the water valve
Aug 19, 2011 | Kenmore 65812
Our dishwasher is not dispensing the soap. I have tried using the cubes (stays in wells), tried powder (it turns to a cake of soap) and I have tried liquid but you could see it ran down the door. Some...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Dishes are not clean if water is hard or when more detergent is used than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results. You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine. Hope this helps...
Please post back if more information is required.
Daniel
Jan 10, 2011 | Maytag Dishwashers
Coffee just drips out of machine, have left off over nite, worked fine now just drips & we get only about a 1/4 cup. Have not desaged as is only about 6 months old?? Bob Spackman
wer
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 25, 2010 | Keurig Platinum B70 Coffee Maker
Water runs thru maker without k-cup inserted but once I put a k-cup into maker the water drips out only and does not fill up the cup but when i remove the k-cup the water continues to run thru it.
Dec 20, 2010 | Keurig B70 Coffee Maker
Keurig B31BLACK Mini Brewer Black 1-c Logo
143 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
