Question about Stanley Bostitch Air Nailer Trigger N60 Fn
The door in front of the driver is broken on my N60 and the part [p/n N60005 ] has been discontinued ,any ideas on where I could get one ?
    President:
  • Stanley Master
  • 1,388 Answers
This part is not a fast moving part so most likely not stocked by many repair shops, however when a part is discontinued there are still many new and used parts out there. Contact fastener dealers in your area for a new or used part or the whole gun used (most likely will sell cheap). Pawn shops / ebay etc, usually sell used nailers for very low price, most likely less than cost of part new if it were available. If you consider buying a used gun for parts, check into n59fn or n60fn, use same part. Good luck
Posted on Jan 12, 2013
Both front doors and back doors automatally lock when driver closes driver door. key will not unlock either front doors, will unlock both back doors
you will have to take door panel off to access the door locks the usual damage from a slim is the retaining clips for the lock linkages gets disconnected or broken if broken most auto stores carry a replacement
Aug 04, 2015 | Cars & Trucks
I have a really old coleman canoe & the front seat support bars are broken.Any ideas how to repair or where to find replacement parts? Coleman says its discontinued so no parts from them.
Compare with a Pelican canoe, and see if its parts will fit.
Alternatively, make something similar out of aluminum tubing or hardwood.
Do consider if the boat is actually worth fixing. A used Coleman can be found for $250-350, and if you do much canoeing a used (better canoe) can be found for $450-550 in most areas.
Jun 05, 2014 | Coleman Boating
2010 dodge journey electric door locks not working
They are known to have broken wiring in the drivers door jam the wires break from the door being open and closing ,I think there s recall for the harnesses for the front doors I could be wrong but check the harnesses on the drivers door the wires break at the connector just pull back the rubber around the harness?
Feb 01, 2014 | 2000 Ford Focus
Windows on passenger side front and rear won't work, up or down.
He could have been more helpful and explained it's likely some broken wires in the door openings. Check carefully the wire harness in the front driver's door and in the passenger front door, where wires get stressed the most when opening and closing doors. The driver's window switch is the master switch for all windows, check there and the other doors openings for broken wires. Splice back together any broken wires you find and recheck windows. Hope you find it. If not there, but somewhere else in the harness, you would probably need professional help to find it.
Feb 15, 2013 | 2004 Mitsubishi Endeavor
What type of batteries fit the nikon n60 35mm
The N60 takes two CR123A or DL123A batteries.
Feb 25, 2012 | Nikon N60 35mm SLR Camera
Power windows do not operate if driver's door is closed, if door is open widows do operate
Could be a loose connector inside the door. Worst case....a broken wire in the harness bundle going from the door over to the body. If that is the case, it may be very difficult to find. Normally the wire is broken, but not the insulation covering it, so you can't just see it.
Aug 28, 2011 | Ford Expedition Cars & Trucks
Passenger front /rear windows will not work 99 jeep gr cherokee
ill suggest theres a broken wire between the drivers door and the body in that accordian looking thing.
Sep 06, 2017 | 1999 Jeep Grand Cherokee
Bostitch N60 finish nailer. The driver will not return. into gun and blows air out by trigger. How to fix?
You will need to replace the trigger valve, the one you need is a P/N- TVA6. As far as the driver not returning, it could be a broken head valve spring,(spring in the back cap under the head valve) or possibly a broken driver blade.
Feb 03, 2010 | Air Tools & Compressors
Nikon N60 35mm camera error code FEE
Check your lens aperture ring setting. It must be set on the highest number I.E. f16,f22,f32..
Jan 16, 2008 | Nikon N60 35mm SLR Camera
Nikon N60 SLR camera
It is more likely that the tab has separated from the plate it slides on. The spring is attached to the plate with the tab sticking out from it. I have repaired these in the past by boring a small hole in the backside of the tab and use a screw to re-attach it.
Jan 12, 2008 | Nikon F60 35mm SLR Camera
Stanley Bostitch   Air Nailer Trigger N60 Fn Logo
63 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
