Question about Maytag Neptune MDE5500AY Electric Dryer
My Maytag Neptune dryer suddenly quit working. The light comes on inside, but it won't start.
    Problem Solver:
  • 18 Answers
This could be several easy fixes. Check to see if the door switch is working if it is not clicking when pushed this could be the issue. try resetting the breaker, if it's not getting both legs of the 240v it won't start. or the start button could be defective. This is where I would start (and most of the time finish) looking. With some common tools and an ohm meter you should be able to find the problem.
Posted on Jan 21, 2009
Why would my older Maytag Neptune Electric dryer suddenly quit? Interior light comes on when door opened, but when I press start, it shudders but doesn't tumble or start?
if thermal fuse ok you may have a problem with your interface board. Check thermal cut out, door switch and thermal fuse before suspecting board. Obviously need model to give you more accurate info.
Oct 30, 2014 | Maytag Dryers
Maytag neptune dryer won't start has power lights will come on but ut won't run flashed PF before it quit
Hello & Welcome to FixYa
PF error code means power failure and is displayed when the circuit board also known as the electronic control board goes bad and needs a replacement. Before replacing the control you can also check the thermal fuse which is inside the rear panel on the blower wheel housing and replace if it reads no continuity. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag mde6800ayw dryer. no power at all. light works inside and im getting 220v. im told that there was a power outage and when it came back on the dryer was dead. im guessing the control board.
your guessing right then,,,
often if the power is cut off when its restored the sudden punch of power can blow the bords chips up,
its nothing new,, if they has a soft start it would not happen to them,,
sorry you need a new program bord
Oct 31, 2009 | Maytag Neptune MDE6800 Electric Dryer
Is there supposed to be a hole on the side of my dryer
Well, though it be simple, you might clean the lint filter everytime you use it. Over time a dryer even with lint filter cleaned will still collect small amounts of lint inside it. You shouldn't worry much but you could call the maytag man to come and take apart the dryer and clean the inside. <;O)
Sep 07, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer
is the drum light on while the door is closed?? look on the teck sheet found in the lower front panel for a wiring diagram momery servers me there is a thermal fuse chances are this is bad if you cant find this tech sheet I will look in my invoice book and see if I can find the sheet for it good luck let me know what you find out
Dec 23, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
244 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
