Question about Rowenta Power Duo Iron
One of the two switches at the back of my Laurastar G1 iron has come out. Looking at it, it seems that the inner part of the switch has come lose from the iron housing. I feel I should be able to reattach it if I could open the iron. I can remove the two screws at the power cord, but can't work out what to press, squeeze, etc to separate the bottom from the top of the iron. Can anyone advise
SOURCE: Replace power cord
Sears has the tamper proof torx bit sets that you need to remove the screws. Unfortunately they are sold in sets only and are about $25.
Butch
Posted on Feb 11, 2008
SOURCE: rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Posted on Jul 31, 2008
advacak
  • 125 Answers
SOURCE: Where to get a special torx screw driver,
you can get them at most auto parts shops
Posted on Dec 03, 2008
  • 43 Answers
SOURCE: Rowenta model dm 860 loose power cord
Most high end appliances (like Rowenta Irons) are made so repairs like that can be done. I haven't played with that model, but I did replace a cord on my Norelco. The torx screwdrivers you are looking for can be purchased, and are often found at either specialty electronic stores (not the average Radio Shack), automotive stores and quite readily online. They are also known as Torx Security bits or Torx Safety bits. Most appliances are made with those screws to prevent the average person from having a go at trying to fix it, but, if you feel comfortable enough with the electronics (even just to look for a loose connection), the bits are available and usually at a fairly decent price.
Posted on Jul 22, 2009
SOURCE: Rowenta Iron-Professional Luxe The power cord
I drilled out the nubs in the center of the screws. removed the screws, and took off the back plate. The problem is that the cord seems to be abraiding when it swivels, and eventually wears thru. It seems like a fire hazard and should be looked into by Rowena. Anyway, I cut out the damaged cord and reattached it. Problem fixed..
Posted on Dec 19, 2009
How can i dismantle a laurastar s4 iron?
not really-- use the correct iron cleaner and if that doesn't work, the damage done dismantling the iron will require a new unit any way
May 11, 2016 | Irons
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
I have a lauraStar Magic Evolution and Steam is escaping around the filling cap. Alot What do I need to do
rubber fittings destroyed in internal compartment,ervice by expert professional
Jan 12, 2015 | Irons
I have had a laurastar iron bought from John Lewis on the. 16/01/10, it has just exploded on me, please let me know if I Can get in touch with someone to repair it ? I live in glasgow, thank you look
cannot look into your wallet ...but i would just get a new one or secondhand these things are so sensitive with their water connections once you take it apart you cannot get it together again without leaking...
Nov 11, 2014 | Irons
Its a Miele Rotary B890D model, when appliance is switched on the heater plate moves up and down (automatically)without the foot pedal being pressed, seems to be that the foot pedal is stuck in a pressed...
I am by no means an expert. I have an electronic background. I have been looking at my mother in laws iron and noticed a few things about it. Check the foot pedal switch. it is easy to acess. Lay machine on its back and remove the two screws and the cover. If you have a continuity test just make sure the switch changes states when you push it. Hope this helps
Mar 03, 2014 | Miele Rotary B890 Iron
My Laurastar Premium Steam Iron is letting out lots of water with the steam Why/
see this steps and fix it. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 14, 2012 | Irons
Dz9030 no power
i think its main internal connection maybe lose
Feb 23, 2012 | Rowenta Irons
My new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
Nov 13, 2009 | Irons
I have Laurastar steampump model 01-0165. How
Vinegar and water mix (about 1 to 4 ratio) and run through. Use distilled water only thereafter--rinse through several times to clear out vinegar.
Aug 01, 2009 | Hamilton Beach Steam Excel 14770 Iron
Auto shut off
either the element is faulty or the switch you turned to give the diffrent tempreture has solder, if it is lose then your iron can repair if it is the element then you have to buy a new iron.good luck.
Sep 06, 2006 | Tefal UltraGlide plus 1656 Iron
Rowenta Power Duo Iron Logo
20 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
