SOURCE: electrolux ewf1282 wont fill with
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Hi - Typically error code E10 indicates that water takes too long to fill. Contact a professional to run multiple tests to verify the incoming water flow is normal and to check the electronic pressure sensor. Depending on the results, washer may possibly have a faulty water inlet valve assembly, pressure sensor/switch or main control board.
E10/EFO error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
