Question about Sewing Machines
Sewing machine not working in reverse
I have cleaned the feed-dogs and oiled the machine. When I leave the thread out of the needle, the machine works fine in reverse. When I thread the needle, the material starts to bunch and the stitches on the underside of the material has loose loops.
  • over40ty Jan 11, 2013
    I have done all of the above. The machine stitches fine in the forward position, but bunches up in reverse. It's not the feed dogs because it works fine in reverse when the needle is not threaded. I
  • over40ty Jan 13, 2013
    I will take the machine to a service technican, but at least I can tell him what i already did to try to correct the probleml.
  • Sewing Machines Master
  • 7,365 Answers
Try a new needle
try a different thread top and bobbin
try adjusting the top thread tension one number or letter at a time
higher sewing on a scrap piece of paper till the stitches look
normal
make sure the top thread does not come off the thread take up lever
Posted on Jan 11, 2013
    The tension is fine when running in the forward direction and without a threaded needle the reverse works. I have done all that you suggested to no avail.. I
  • it would be a good idea to have the machine checked to see if there is a adjustment or timing problem with the machine.
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
  • 46 Answers
SOURCE: Thread loosens underneath intermittently. Stitches not consistent.
take it to a serviceman.
Posted on Oct 24, 2008
bargainbox
  • 1388 Answers
SOURCE: on underside of material thread is loose and not catching
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Posted on Sep 02, 2009
  • 1116 Answers
SOURCE: Needle thread looping underneath, threads not interlocking at all
If the machine is now threaded, lift the presser foot.
Now, pull about 10" of thread through the needle.
The next time you thread the machine, lift the presser foot first.
When the presser foot is up, the tension control opens and allows the thread to "seat" into the control, then when the foot is down the control closes to the indicated setting.
When threading the machine with the foot is down, thread does not enter the tension control and when you start to sew, there is no tension on the thread.
No tension = loosey, goosey, loopy stitches underneath.
Because the lack of tension on the top thread, the bobbin thread cannot lock a proper stitch.
Posted on Mar 10, 2010
RichSew
  • 184 Answers
SOURCE: Singer sewing machine 6215c trouble
The problem is actually with the upper thread not having enough tension on it. Check your upper tension setting,,,it should be set about mid range of its adjustment (4,5 or 6). To see if the tension is functioning correctly thread the machine and raise the presser foot to its up position and pull thread thru the needle. It should pull easily, lower the presser foot down to the fabric and now the thread should become harder to pull. If there is no change in the pull,then either the thread is not in the tension correctly ot the tension is not working,
Doug
Posted on Aug 07, 2010
Singer touch tronic 2000 feed dog will not advance fabric
Confirm the feed dogs are raised. Make sure the feed dog teeth, area under the needle plate and the bobbin area are clean of any debris, thread, or buildup. Some machines also have a presser foot pressure adjustment that increases the pressure the presser foot applies to the feed dogs. The feed dogs could be worn (never run the sewing machine without fabric between the presser foot & feed dogs).
https://www.manualslib.com/manual/508740/Singer-Athena-2000.html
Or, the machine has not had a thorough cleaning and oiling recently and the feed dogs are sticking from old oil.
Wheel on right side that controls the needle up and down is very tight...
Jul 30, 2017 | Singer Sewing Machines
Why does upper thread snap when backstitching?
May be an issue with the feed dogs, or possibly a burr on the hook. Lay a peice of scrap material under the foot as if you were going to sew, remove needle, then run machine in reverse to see if it feeds material backwards as it should
Nov 07, 2015 | Singer Advance 7422 Electronic Sewing...
Janome Jem Silver 662 will only sew backwards. How do I adjust it so it will feed fabric correctly?
1) Check the feed dog pressure adjustment. 2) Check the feeding mechanism at the bottom. It may be too low to feed your cloth.
Feb 03, 2015 | Janome Jem Silver 662 Mechanical Sewing...
My Kenmore Sewing Machine's needle is locked down
best suggestion try inserting new needle. cotton up the top suggests needle problem or incorrect top thread tension, this would effect the feed dog. Because thread is black and most recent use was with pink, the problem thread was already there perhaps in cavity above bobbin but below throat plate. I have had this happen and nothing will move, untill needle released. The bobbin holder tension may also need adjusting after the knots of black cotton are removed.
Nov 07, 2013 | Kenmore 15516 Mechanical Sewing Machine
Feeder dog is in reverse and thread won't feed through bobbin..
it would really be a good idea to have the machine serviced at a sewing
machine shop
May 05, 2012 | Sewing Machines
I've cleaned, oiled, bought new needles new thread new bobbins held the thread away 3-5 inches tried all tensions rethreaded ect.. and my thread always breaks when i start sewing...
clean under the needle plate where the feed dogs are for lint
also clean in the bobbin area for lint or loose threads
also check for burrs on the needle plate or on the bobbin & case
it could also be out of time
Nov 22, 2010 | Brother LS-1217 Mechanical Sewing Machine
Feader dogs will not move material. thread knots up
Thread knots because the material is not feeding. Sounds like the machine has not been oil or serviced in some time and the old oil is turned into a varnish and causing the mechanisms to stick and therefore, not operating freely. I've recently serviced a machine that had been idle for quite some time and the feed dogs and zigzag mechanisms were sticking. Just a proper dissolving and cleaning the old oil and re-oiling and the machine was working like new again. A proper cleaning of lint build-up on the feed dogs under the needle plate is also a probable cause.
<Ray>
Nov 01, 2010 | Kenmore 15202 Mechanical Sewing Machine
Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Oct 06, 2009 | Kenmore 16622 Mechanical Sewing Machine
Kenmore 19153
Sounds like you need a new needle and the upper tension tightened. Try putting machine oil on the feed dogs and working it up and down until it is free again. You can take off the lower plate and clean any lint that may have collected underneath. Then make sure the thread is coming out of the bobbin correctly before it is inserted in the machine.
Zelma
Jan 18, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
111 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
