Question about Yamaha RX-V673 7.2 Channel AV Receiver BONUS PAK w/ Two HDMI Cables
Hdmi board replacement
Hdmi out, board replacement part number
  • Jschaffner Jan 16, 2013
    I have a YAMAHA rx-v673 and i need the service manual. The HDMI out port is burned and i need the part number. thanks a lot for your help.
My Vizio HDMI ports stopped working. It took about 3 months but each socket went out a few weeks apart from each other. The very last HDMI ports went out. What can we do to fix its. And if we need a n
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 23, 2014 | Vizio 42 in. LCD TV
Insignia NS-PDP50 Plasma tv HDMI inputs are inoperative
First of all, make sure that the hdmi BLOCK setting is correct. This prohibits both hdmi inputs and the DVI from working. I didn't even know they existed so I replaced the YSUS board and then I found the settings were my issue all along. If the settings are correct then the most likely culprit is the YSUS board part number: BR36223601. It is a compatible card for your TV. There are several suitable subs for this board and it is a snap to replace. I found a like new board that works better than my original board for only $25.00. The heck with those rip offs for prices up to nearly $300... Good Luck.
Jun 04, 2014 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Pioneer pdp-5070pu HDMI port 5 has a megenta hue to it. All other HDMI ports and component ports are fine. What board might need to be replaced?
The main board that has the HDMI ports on it. The numbers can be taken from the board itself. Once the board is replaced, you'll have to go thru all the setup menu's because the memory is on that board too.
Dec 27, 2013 | Televison & Video
HDMI PORTS DONT WORK
You will need to replace the main video logic board, its part number is either EBU60852909 or EBU60852911. These two board are direct replacement parts. There are several boards available on Ebay such as this one: http://www.ebay.com/itm/LG-46LD550-UB-Main-BPR-Total-Assembly-EBU60852909-subs-to-EBU60852911-/150895037335?pt=US_TV_Boards_Parts_Components&hash=item23220b8b97
Sep 11, 2012 | LG 46LD550 46 in. LCD TV
HDMI STOPPED WORKING PANASONIC TH-42PV500B
I had a same issue with my Panasonic TH-42PV500B plasma television. I tried everything which is written above and can be found on different websites. Finally I decided to replace the HDMI Board itself. I was able to buy a used one on ebay, it was only 13 pounds with postage.It is relatively easy to remove this HDMI Board. You should just unplug the TV and remove all of the screws form the back which are fixing the back of the TV to the frame. There are plenty of screws. You should remove all of them! Remove the backplate of the TV. After this you can remove another metal plate from inside, which covers this HDMI board - 4 screws. After you can remove the HDMI Board - only one screw holding it to the main board. Replace the new one back and put back the cover plate and the back of the TV. And it is working. 10_19_2012_3_10_22_pm.png Panasonic 42 Plasma TV TH-42PV500B Part HDMI Board Order number: TNPA3626
Apr 11, 2012 | Panasonic Televison & Video
I have a Sharp Aquos LC-26D40U. I have connected my sat box via hdmi and I get nothing. I have tried several hdmi cables and hdmi equipment nothing works.Its looking like I need to replace the HDMI signal...
Hi:
You can try partstore.com or a cheaper solution is to go to ebay and input your model number for a search, there you might find refurbished boards and new boards that shops are selling for sets that had broken PDP panels etc.. (BAD LCD SCREENS)
Dec 02, 2009 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Hdmi out [of amp damaged needs replacing onkyo tx sr605
You will need to contact Onkyo directly and request the board from the parts department. I was not able to locate a part number for this as we are usually requested to perform component level repairs for these units.
Dan
Nov 04, 2009 | Onkyo TX-SR605 Receiver
Toshiba 46H84 HDMI Card Replacement
The only thing I could recommend is to return the board and get the right board. open the set and get the part number on the board itself. You cannot modify a set to work things it was not designed for without reprogramming the microprocessor. Good Luck
Jun 26, 2007 | Toshiba 46H84 46" Rear Projection...
Yamaha RX-V673 7.2 Channel AV Receiver BONUS PAK w/ Two HDMI Cables Logo
354 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
