Question about Fargo DTC525 ID Card Printer
Low temp error on DTC525 Laminating unit
Is the laminating unit sold seperate? or can you recommend the parts needed to repair it.Can you provide these parts and how much are they?
I believe, it is the thermocoupler. We can get you this part.
Posted on Aug 18, 2009
  • ragabm76
    ragabm76 Mar 18, 2013
    Ok, Send me its price My email ragabm76@yahoo.com
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Engraved / carved markings or scratch in laminating roller
probably will be best to junk it and get another one as the cost to repair will probably exceed the new cost.
Jul 06, 2014 | Office Equipment & Supplies
Paper **** inside
Probably rolled itself around the rollers. Got to be real careful to not have any exposed inside surface (of the laminating pocket) showing since that coating is heat-activated and sticky.
Unplug it, wait for it to cool, flip it over and remove the screws holding it together.
If the laminating pocket is just physically wrapped around one of the rollers, it will come right out. Re-assemble and go back to work being careful not to put anything through that is the least bit curly.
If the laminating pocket is stuck to one of the rollers, just chuck the thing out and buy another one. The cost of parts and repairs will exceed the cost of a new unit. To remove the adhesive, one would have to disassemble the entire motorized assembly and then heat the "offended" roller to more than 180?F to get the adhesive to soften enough to scrape it off. Then, while it\'s still hot, one has to use a solvent matched to the adhesive to remove all remaining traces (\'cause if there is any left, it will just suck the next laminating sheet right around the roller and you\'re back where you started).
Remember:
- Use only laminating pockets for that brand (different models may have different temperature ratings). If the clerk says their laminating pockets are universal, ask the Clerk to guarantee in writing on his company\'s letterhead that they\'ll be responsible for any damage / repairs / replacement. They won\'t.
- Don\'t put anything that\'s curling through.
- Don\'t put anything through where part of the inside of the laminating pocket is exposed (because as it heats up it will stick to anything and everything it touches)!
Mar 05, 2014 | Xerox Staples XRX LM1910 Laminator
Laminator 17466 I need to take my laminator apart.
Can you please provide a model and brand for the device in question?
Oct 22, 2013 | Tools & Hardware - Others
How do I remove adhesive from rollers?
I have had this issue before when the laminating sheets were put in incorrectly (open side inserted as opposed to closed side inserted). Unfortunately, the manufacturer said that the machine is not repairable, and I had to replace it.
Oct 16, 2013 | Gbc HeatSeal Ultima 65 Laminating System
Pouch stuck in laminator
Firstly switch off the laminating machine and plug out. Turning off the machine will prevent the motor from burning out. As the motor is not burnt, there is no need to repair or substitute the machine.
* When the machine gets turn off look for the damage instantly, if any. If any huge item was inserted to laminate, it might have happened that the item had stuck in the machine. First of all, try to pull out the item gently from the machine. Also, remember that thick and three dimensional items should not be laminated in the laminating machine.
Hotmail Support ' Aol Support
Apr 09, 2013 | Office Equipment & Supplies
What is laminated Floor?
Basically, laminating is the result of a direct pressure process that fuses four layers into one durable surface. The laminating technique originally came from Europe and spread worldwide in the last decade.
Jan 10, 2013 | Building Materials
Some one at work tried to laminate a card. when it did not come out she put in another sleeve thinking it would push the other out. smart uh! how do we get the 2 pages out?
If you were using GBC brand laminating pouches they don't need a carrier, if you were using another brand of laminating pouches, then a carrier is needed (something they don't clearly specify) and that's why the laminating pouch got stuck.
If you have had the laminator under a year, it should be under warranty, and you can call the company, and they will send a replacement, and they will probably then inform you of the above listed laminating pouch issue.
You may also want to try using the reverse button, but many times the pouches will get stuck between several rollers, and you risk destruction of the entire machine by attempting to take them out manually.
May 31, 2011 | Gbc HeatSeal H425 Laminator
Fargo DTC525 ID Card Printer Logo
134 people viewed this question
Top Fargo Office Equipment & Supplies Experts
pkwc
Mike Neath
Mike Neath
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
