Question about Nintendo 64 Console
Nintendo 64 expansion pak
I purchased the expansion pak on ebay. I try to insert into the slot on top of machine, jumper pak said "do not remove" I did anyway and inserted the expansion pak and nothing is showing on TV but blue. I put jumper pak back in and still nothing is showing on screen of TV just reamins blue. Please help!!! My six year needs his fix of Diddy Kong!!! Thank you.
  • gerbelle Nov 12, 2007
    I purchased an expansion pak from ebay, but have no idea where in the console it is supposed to go. I was going to rip of the pink sticker that says "do not remove" pull out the little cartridge which is in there and then try pushing it in. Reading other comments on this board, this doesn't seem the way to go. Can someone please give me some specific instructions on how to insert the expansion pak then I don't wreck my console. My son would greatly appreciate it as we have purchased two games which will only work with an expansion pack.
  • maxpowers67 Jan 23, 2008
    Oh man, I have the exact same problem. I also bought my expansion pak off of ebay and now my n64 doesn't work. Even when I put the jumper pak back in. I did everything I was supposed to. I had everything turned off when I replaced it and I've been searching the internet for hours trying to find solutions.
Hay docstrang u have it wrong it is the outher way around the exp pak was for the 64DD not the jumper pak
Posted on Jul 17, 2008
  • 32 Answers
Barb3: The Jumper Pack (JP) is a bypass for the expansion cartridge. You were supposed to turn off the equipment remove the JP and then use the expansion cartridge. Your N64 Ram it's probably gone for good. Is either replace the RAM, which is hard to find or replace the N64. Sorry for that.... SithPitt
Posted on Jul 04, 2007
  • 22 Answers
Well, it said "do not remove" and sadly you removed it. The "JP" was made for the N64 Disc Drive, which never came out in America (seeing as it flopped in Japan). The N64 when it goes on, has to check if everything is there. Either the N64DD or the Jumper Pak must be or the N64 is pffft. Sorry, but you haveta get a new N64. I've never heard of this "expansion cart" but is sounds like it was a save game pak. Those go on the bottom of the controller.
Posted on Aug 23, 2007
Dids you unplugged the N64? If you didn't, you damaged the system and there's nothing you can do about it. You supposed to turn off and unplug it before you do anything. You can gave me the expansion pak, since you can't use the N64 anymore if thats alright with you. I need it to play "Perfect Dark."
Posted on Jul 29, 2009
SOURCE:
My n64 powers on but no picture
Nintendo 64 - Blank Screen Troubleshooting
Quick Tip: If your system is connected using AV cables and you cannot see the game on your screen, it is likely all you need to find is the input select on your TV or VCR. Link here for help.
  1. Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
  2. Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
  3. Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Lightinstructions.
  4. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
  5. Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
If the above steps do not resolve the problem you are experiencing, there may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (how to buy replacement parts). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If this does not resolve the problem you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here.
Feb 25, 2014 | Nintendo 64 Console
No video signal
  3. Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Light instructions.
Oct 08, 2011 | Nintendo 64 Console
I have all the wires hooked up right, yellow to yellow, red to red and white to white..the N64 powers up just fine, I have it on the AV setting, but I still can't get any video or audio. it's...
  1. Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
  2. Make sure the system has power. If you don't see the red power light when you turn your system on, go to the No Power Light instructions.
  3. Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position. (Inserting the game with the Power ON will result in a blank screen.)
  4. Check under the Memory Expansion door (on the top of the Control Deck) to verify that the Jumper Pak or Expansion Pak is still inserted. If one is not inserted, slide the Power Switch to the OFF position, insert the Jumper Pak or Expansion Pak and slide the Power Switch to the ON position. Simply pressing reset will not solve the problem. You must turn the power off and then back on.
If this does not resolve the problem you are experiencing with your system, your system may need to be replaced. For more information on what options are available, please click here. It might be broken like it sounds like a power supply issue or and a laser assembly failure then.
Sep 03, 2011 | Nintendo 64 Console
I have an old N64 and to play majora's mask it says i need an expansion pak so i ordered an expansion pak but when i replaced the jumper pak with the expansion pak the system still turns on but for some...
If your Nintendo 64 console operates without error when the jumper pak is installed, but fails to function when the expansion pak is installed, by process of elimination this most likely means that the expansion pak you purchased is defective.
However, prior to purchasing another expansion pak (or attempting to exchange/get refunded for it), make sure the contact points on both the pak and the console slot are free of any dust, dirt, or other contaminants. Use a lint-free, dry cloth to do this. Water and/or cleaning products can further damage the system.
If, after cleaning the contacts, it still fails to function, seek an exchange or refund.
Mar 03, 2011 | Nintendo 64 Console
Ok so when i turn on my N64 the power light comes on but the screen stays black (Blue for some tvs).I unplugged everything cleaned it with a Q-tip made sure there was no cuts in the wires.I then plugged...
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Feb 08, 2011 | Nintendo 64 Console
The red light is on but nothing shows on the tele
Feb 06, 2011 | Nintendo 64 Console
The red light comes on but the picture and sound doesn't show up. what do i do?
Quick Tip:
Quick Tip:
Feb 01, 2011 | Nintendo 64 Console
When I turn it on a red light comes on and nothing comes on my tv.
Jul 01, 2010 | Nintendo 64 Console
My nintendo 64 saids i need an expansion pack but its in there
remove the stiker and push it and check if its firmly inserted
Apr 28, 2010 | Nintendo 64 Console
Donkey Kong 64 & Expansion or Jumper Pack
Search inside Nintendo 64 Console Knowledgebase
Apr 19, 2008 | Nintendo 64 Console
Nintendo 64 Console Logo
3,535 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
