Question about Pure Digital Point and Shoot Video Camcorder
Cannot get camcorder to download video
I have a digital point and shoot model 225. I worked great. I downloaded the camera with no problem. I bought my daughter one. She brought it home on vacation and we downloaded it on my camera and now I cannot download mine. Hers is a newer model than mine. My camera has tried to install the software unsuccessfully. It worked at one time How can I fix it? I have a Dell Inspiron 5150/Windows XP.
  • 1 more comment
  • jaunita_ann Jan 22, 2009
    I tried moving it to the other usb port. No luck. It is trying to re-install the software. It says that the software failed to install.
    This camcorder has a built in usb no removeable cable.
  • jaunita_ann Jan 23, 2009
    I went to My Computer and brought up the Point and Shoot. I ran the install exe. file. It said that the version that i had was a newer version (from my daughters camcorder). I assume that her camcorder had upgraded my software but it was not compatible with my camcorder. I uninstalled the newer version and now my camcorder is working again.
  • Pure Digital Master
  • 19,396 Answers
You can fix the problem by doing system restore to a date before the problem started.
After doing system restore, you may need to reinstall device software.
System restore it is often the first tool to solve problems on your computer.
Each time you do an update, or install a new software, system settings will be modified, sometimes this can cause Windows operative system malfunctions.
System restore to a date before you had the problem can repair most Windows faults.
Here is the how to:
Before starting System restore close all this running applications.
You can start System restore from start menu:
1.
Click Start.
2.
Point to All Programs.
3.
Point to Accessories.
4.
Point to System Tools.
5.
Click System Restore.
6.
Follow the instructions on the wizard.
You can also start system restore to create a restore point before making an important change to the system.
For example you can decide to create a restore point before installing a new anti virus, or downloading Internet Explorer update.
Posted on Jan 23, 2009
  • 13,433 Answers
You will need to remove both cameras from the computer and the softwares that came with them, then install the software for the camera you want to use with the computer and only use that camera with that computer. It should solve the problem but let me know if it doesn't we can look into it together over remote support even..
Posted on Jan 22, 2009
  • 8,197 Answers
Try to reinstall the software. you might have a bad file
    Sergeant:
  • 378 Answers
Unplug the device from the computer and reconnect it and check out if its showing new hardware detected that means its been detected by the computer.but if not such messages its the cable faulty issue replace the cable and try again.the cable will cost you $2 for replacement/new.
Posted on Jan 21, 2009
    Sergeant:
  • 221 Answers
Check out the usb wire which connects between camera and the pc/laptop if that is faulty or not connected.try connecting the usb wire in another slot of your pc/laptop and check it may start downloading.
Can't download to my new macbook
with the camera plugged in, open iMovie. it should initialize the camera automatically. if it doesn't, go to file>import from camera.
Feb 27, 2011 | Pure Digital Point and Shoot Video...
Software will not download on mac.
Unfortunately, there is no easy fix for this, as the software is built-in to the camera. The only thing I can suggest is that you take it back to the store that you got it from, and inform them that the software for your product doesn't work. They should replace your camcorder, or refund your money...depending on what their return policy is.
Dec 08, 2010 | Pure Digital Point and Shoot Video...
It wont take pictures
Determine how the camcorder works. There are 3 basic modes of capturing stills with a camcorder. Read your instruction manual for specific information.
  • Step 2 Understand freeze-frame stills. The most common and least effective method is a "photo mode." Basically, the camcorder will simply freeze a frame of video for a few seconds, which can then be extracted later as a still.
  • Step 3 Use editing software to capture stills. This method is similar to the first, and can be done with any camcorder. Download an editing program or use the camcorder's bundled software. Then transfer the video over to your computer and use the software to pull out stills.
  • Step 4 Understand built-in digital cameras. This is a more expensive option, but results in higher quality photos. These cameras have built-in memory cards and function basically the same as a stand-alone digital camera. Refer to the manual to switch over to digital camera mode, then point and shoot. The photo quality is usually a bit lower than from a stand-alone camera.
  • Step 5 Compare specifications. Understand that specifications for high quality video don't necessarily translate to high quality stills. CCD determines the quality of video, while megapixels determine the quality of stills.
  • Step 6 Consider the value. Whether or not a combination digital camera and camcorder is best for you depends on how you'll be sharing your photos
  • Mar 18, 2010 | Video Cameras
    I have a pure digital camcorder model # 225 and I see a slot on top of the camera and I'am wondering if this is for any sd card ? can you let me know about this , please thankyou , Rafael
    I have a pure digital camcorder2_bing.gif model # 225 and I see a slot on top of the camera and I'am wondering if this is for any sd card2_bing.gif ? can you let me know about this , please thankyou , Rafael
    Feb 05, 2010 | Pure Digital Flip Video Camcorder
    Hello, my pure digital model 225 is now recording and showing in LCD a semi-distorted technicolor mess. The recordings I have on it from the past play back perfectly normal. Any help?
    Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
    Meggita
    Sep 27, 2009 | Pure Digital Point and Shoot Video...
    I NEED SOFTWEAR FOR MY VIDEO CAMERA
    how to conect jvc GR-850AG Mini DV digital camcorder
    Oct 16, 2008 | JVC GR-D370 Mini DV Digital Camcorder
    Point & Shoot video camcorder
    I used Windows Media Player 11. Do I get paid for this info, or am I screwed for giving it before payment?
    Ha! Ha!
    Jul 03, 2008 | Pure Digital Point and Shoot Video...
    Pure Digital Point and Shoot Video Camcorder Logo
    71 people viewed this question
    Top Pure Digital Video Cameras Experts
    Rommel Balcita
    sharky633
    sharky633
    tomikles
    Level 1 Expert
    Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
