Question about KOBO, INC Kobo Mini
How do I delete drawings that I have made on my Kobo Mini?
I accidentally saved pictures that I drew for fun on my Kobo Mini, and I don't want them. Thanks.
My Kobo Aura is not recharging. The charging unit seems "dead". Can the charger be replaced?
it can
Kobo Aura / Aura HD compatible Advanced Rapid Wall AC Charger ...
https://www.amazon.ca/Kobo-compatible-Advanced-Rapid-Charger/.../B00GNB08JS
Gomadic Powerful High Wattage wall charger for home or travel use. Customized circuit design is based on the latest in power regulation and is tailored to the ...
Kobo Aura One Charger, BoxWave® [Wall Charger Direct] Wall Plug ...
https://www.amazon.ca/Kobo-Charger-BoxWave®-Direct-Touch/dp/B01MA3NLF8 Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc 7 10 HD; Kobo Touch Glo Mini Aura Hd Ebook Tablet.... ... HQRP Micro USB Charger / AC Adapter for Kobo Arc / Arc 7 / Arc 7HD / Arc 10HD / Mini / Glo / Touch / Aura / Aura HD / Vox.... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid ...
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones ...
https://www.amazon.ca/Kobo-eReader-Glo-USB-Cable/dp/B00AXZVE48 Rating: 4.7 - ‎11 reviews
Kobo eReader Glo USB Cable - Micro USB: Amazon.ca: Cell Phones & Accessories. ... Cable for Kobo eReader Kobo Mini, Kobo Touch, Kobo Aura & Aura HD... ... Pwr+ 6.7 Ft 2A AC Adapter Rapid Charger for Kobo VOX eReader; Kobo Arc ...
Chargers & Cables - Electronics: 146 products available ' chapters ...
https://www.chapters.indigo.ca/en-ca/electronics/chargers-cables/500151-cat.html Results 1 - 24 of 146 - Shop Online at Chapters.Indigo.ca for a wide selection of chargers & cables products, 146 items available. Enjoy free shipping on orders ...
kobo aura charger Google Search
Sep 24, 2017 | Tablets & eReaders
How to delete some contacts in the Kobo arc
Simply go to the Contacts app, click a contact and press Delete. If there is no delete, it might be under the menu button, which is 3 dots
Mar 17, 2015 | Kobo Arc
My kobo is frozen on starting sync won't turn on or off
Note: If your Kobo device has been physically damaged, it is no longer covered by Kobo's limited warranty. On a Kobo eReader, a physically damaged screen will look like it's been shattered, or you may see vertical or horizontal lines on the screen with a frozen image. If you haven't dropped or damaged your Kobo eReader, but are experiencing issues, try the steps below in the order suggested.
  • Turn your eReader off and then on again.
  • If your screen is frozen, slide the power button to the right and hold it for 10 seconds. Your eReader should turn off.
  • Turn your eReader off and charge it for at least four hours. Note: Your computer should be turned on while you are charging your Kobo eReader.
  • If your eReader isn't charging, try using a different Micro USB cable or a different USB port on your computer. Note: If your eReader's battery is completely drained it can take up to 15 minutes before it reacts to being plugged into power.
  • If you're having trouble while reading a book on your Kobo Aura H2O, Kobo Aura, Kobo Aura HD, Kobo Glo, or Kobo Mini: tap the centre of the screen to bring up the Reading Menu, tap the > Home icon to return to your Home screen, then open your book again.
  • If you're having trouble while reading a book on your Kobo Touch: press the Home button and open your book again.
  • Try a basic reset.
  • If you're still having issues, consider a factory reset.
  • If you're unable to reset your device, please contact Kobo Customer Care
Mar 14, 2015 | Kobo 6" eReader Touch Edition
Problem with internet connection says when I connect my KOBO to computer and cannot sync any books. Kobo charged and can't access KOBO on computer
It could be several things. But you may need to delete Kobo and reload the app. I have had to do this on some of my programs. Your books are on the net, so they won't be lost.
Aug 02, 2014 | KOBO, INC Kobo Glo
Sync kobo
You may need to delete KOBO and re-install the app. Your books will be saved because they are online.
My kobo wont open the book, keeps loading but does not open
Does your Kobo turn off and on normally? Or is it stuck loading the book and totally not responding? If so, reset your Kobo. Look on the bottom edge of the Kobo - see the little pinhole? Stick a paper clip into there until you feel it push against a little switch. Remove the paper clip.
Is the Kobo working, but simply can't open a book? If it's only affecting a particular book, try deleting it and downloading it again.
Dec 27, 2013 | Kobo Arc
Mini usb port on kobo arc is broken. Where can I get parts?
Hi i managed fix my usb port , open the kobo and remove the usb ribbon, the usb port is glued at the rear , you will see a black blob od adhesive at back of port , this comes unstuck if it gets a knock , i gently lifted this slightly then slid some super glue underneath and then applied pressure on top of the usb port to ensure the port was contacting the ribbon again until the glue set, my kobo is back in action again , hope this helps someone
Jun 20, 2013 | Kobo Arc
I don't have a password
''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''ab
Mar 22, 2013 | Kobo Arc
How do i change font size on my kobo mini
while in a book, tap in the middle of the page, the second to last button on the bottom of the page - (looks like four directional arrows) then the bottom of the screen will change and you will now see a slider bar on the left with plus and minus sign- Tap on either to change the font size.
Jan 18, 2013 | KOBO, INC Kobo Mini
I want to download books onto my cruz but everytime I try to sign in it wont let me. do you know why??
Did you make the account on your computer or on the device? If on the device try logging in on the computer. If it doesn't log in on there then attempt to recreate the account. If you cannot I would suggest contacting customer service.
If you are unable to log in to either service and you can log in online you may want to delete them and go back into the market to download them again. Obviously make sure you are connected to the internet.
A generic fix that should be done is to restart the device.
Finally I would look into rooting the device and flashing the ROM so that you can try some other software for reading. Although both KOBO and Borders are nice alkido reads all formats including PDF's.
I personally don't use kobo or borders but you may need the desktop versions installed to have them link to your account.
Hope something here helps, you can follow up with some more information or troubleshooting you've done which will help the community in assisting you.
Nov 06, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
KOBO, INC Kobo Mini Logo
115 people viewed this question
Top KOBO, INC Tablets & eReaders Experts
Are you a KOBO, INC Tablet and eReader Expert? Answer questions, earn points and help others
