Question about Maytag Dependable Care LAT9416
Replace belt on g.e.model wsm2420 - Maytag Dependable Care LAT9416
What is the recommended mileage for replacing the timing belt on eurovan gls.
Timing belt intervals for Volkswagen - One Stop Auto Shop
www.onestopauto.com/Timing-belt-intervals-for-Volkswagen.htmlOn 2000-01 1.9L TDI engine, w/manual transmission, replace timing belt every 60,000 miles. On 2000-01 1.9L all TDI engine, replace timing belt tensioner every 105,000 miles. On 2002 models, replace timing belt & tensioner at 80,000 mile intervals. On 2003-06 models, replace timing belt & tensioner at 100,000 mile ...
Service Schedule
2003 volkwagon eurovan gls service schedule Google Search
Mar 11, 2018 | Cell Phones
What belt do I purchase for eureka whirlwind litespeed
If you have the exact model Eureka that this repair was listed under, model 4388 then please find a link to the belt you need below. If you'd like to verify the model number, please check the back or the bottom of the vacuum for a sticker that also will contain the serial number, and look for the word Model Number. If you don't have the 4388, please just add a comment with the model you have and I'll be more then happy to verify these two models take the same belt, or give you a link to the belt that goes to your model if they are different.
Here's a link to the exact belt called for on the model 4388:
Eureka Extended Life Style U Belt, Part 61120
Here's step by step instructions on how to replace the belt:
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor pulley when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor pulley.
6. Place belt around brush roll pulley.
7. Align left end cap with square in base. Push
end cap into place; see left side view.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
I hope this information was helpful to you in changing the belt. If you have any questions about how to change this belt, please just add a comment here on the repair page of Fixya, and I'll be happy to answer any follow up questions you might have. If you found this helpful, please be so kind and rate my repair helpful and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Eureka Whirlwind 4388 Bagless Upright...
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Belt broke how do i fix it
To my knowledge model F7220900 SteamVac doesn't require a belt. Are you sure that is your model? If you have a different Hoover model you can get a replacement belt here:
http://www.vacbelts.com/
Oct 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
BELT TO THE BRUSH SEEMS TOO LOOSE EVEN WHEN REPLACED
Hoover U6437-900 U6439-900 Upright
LOOSE BELT. THE BELT IS STILL LOOSE EVEN AFTER REPLACING
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The reason it seems like the belt is too big is probable correct, you may have the wrong size belt for your vacuum, use genuine belts – your particular model is a self propelled model and takes two (2) belts and they should stretch on very tightly and snug and it is smart to use the genuine belt package for the model that you have and we Recommended the belt change for flat belt(s) are 4 to 6 months for better cleaning
They should be tight on the belt pulleys in order to do the best cleaning – use genuine belts
http://www.hoover.com
Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Apr 03, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Washing Machines Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
