I have an older model flat screen tv. I would like
I have an older model flat screen tv. I would like to know what I can do about this cloudy picture? If I could get it to play clear and with more color I would be totally with the amount of space it takes up. I say the age is about mid 90s. Phillips 50 0r so inches. Nice sound but the screen is playing very foggy.
  • 14,378 Answers
Check your cable connection at tv.
Posted on Jan 11, 2013
  • 3 Answers
SOURCE: Picture is off center to the left by 9.5 inches
you need a new light tunnle cost about £70 but whoever you get to replace it wil charge about £140 labour
Posted on Sep 30, 2007
  • 579 Answers
SOURCE: Philips 46PP9302 46 in. Rear projection -
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Posted on Jan 22, 2008
SOURCE: Phillips Magnavox 60 inch Projection Tv
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Posted on Sep 19, 2008
Ecollier2012
  • 3459 Answers
SOURCE: 61 inch phillips magnavox tv with no picture or sound
Its a common problem with this model.
Goto www.TvRepairKits.com and get their kit + instructions for the shrinking video problem.
Posted on Jun 21, 2009
Slinteriors
  • 8617 Answers
SOURCE: We have a Magnavox Model 55P8288A Projection tv
Replace the CRT coolant. You can get the phillips CRT coolant replacement kit at the following link. The kit contains the coolant and the CD with instructions.
http://servicemanuals.vstore.ca/
Posted on Sep 23, 2009
How do uou fix. A. Emerson flat screen television the screen wont play a picture it just keeps changing colors
your TV is in test mode , Google your TV model number and the word test mode or let me know your model number to help you out bostonrecycling.net
Dec 25, 2013 | Televison & Video
Colour settings lg 50pc60
the settings are by how you like to see your picture. play around with the settings and see how you like it. an older tv is going to give a bit different picture then a brand new tv, so the settings may be different.
Mar 05, 2013 | Televison & Video
No picture on my flat screen sony. got sound. remote works. no picture. can it be fixed?
Sounds like an older tv---to help I need to know the model number (KV or KP?)
Mar 31, 2012 | Televison & Video
My TV has gradualy developed a blurred picture over the last month and now is unwatchable, is it worth fixing. It is 8 years old
guessing this is a rear projection tv. You did not provide a model number. Check the CRT fluid to be sure it is clear and not cloudy. Since you mentioned the problem was gradual over time, I'm guessing it is the fluid. This would be more obvious if you were seeing like a frosted look to the picture or dark areas and bright areas, which are caused as the fluid clouds up.
Your alternative is to try adjusting the focus of each bulb on the focus block of the tv. I think with an older Philips the focus block is in the back of the tv.
Feb 20, 2011 | Philips Televison & Video
Cloudy picture on rear projection tv
Your picture guns and mirror is dusty. You can try cleaning yourself if you know what your doing, but I would let a qualify tech to do it.
Nov 20, 2009 | Philips Televison & Video
Blurred picture, after some warm-up it back to clear picture
If the problem doesn't return after the picture becomes normal, then it could just be due to the electron gun taking longer to fire up. I don't know how old your TV is, but TVs older than ten years typically take longer to warm up than more modern sets.
Jun 02, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Hi my picture is not as clear as my friend's tv. My screen seems almost cloudy.
It depends upon the room size and how you have placed the tv. if u position it in a proper manner then you will have a clear view.
Jan 01, 2009 | Sony BRAVIA KDL52XBR2 Television
My HD TV is no longer showing a clear picture
Sure sounds like the CRT fluid is cloudy and needs to be replaced.
If its not the fluid the convergence chips are bad.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Aug 03, 2008 | Philips 51PP9100D 51 in. Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
