Question about HP Photosmart C6180 All-In-One InkJet Printer
Can't print I have been printing on my wireless network for many months. Today it won't print and when I do a "Wireless Setup Wizard" it requires a WPA Passphrase". When I get the data from Linksys router, it tells me that the Passphrase is N/A. How do get past this?
    Scholar:
  • 97 Answers
WPA keys is security key for ur network and when u run the wireless setuo wizard, use the key pad on the printer to punch in the WPA or WEP key.......
or
if u were using ur printer before wirelessly, then u should still have the ip address stored on   ur printer,
1) print network configuration by setup menu of the printer (setup>>network>>veiw network settings>>print network configuration page)
2)it will print out, in that u will have ip address.
3) go to priner and faxes, right click on the printer icon and go to properties and under ports tab, click on configure port and change the ip addres for the ip address wat u have if that doesnt work, click on add a port and select standard tcp ip port and new port at the bottom of the window and entry the ip address and proceed with that,,,,,,,,,,,it should resolve ur issue....
Regards,  raj_p5983
Posted on Jan 22, 2009
I have a HP officejet 8500 wirelsss. It had worked finme since we nought it abiout 4 months ago. Now we can't print from any PC...says "disconnected. We did have a TWC technicina in to replace the...
If they installed a Modem/Access point that the computer talks to via wireless than this has become the new "hub"You may need to tell the printer the new settings so it knows to go through this "hub" 1. Press Setup 2. Scroll Down to network, press OK 3 Scroll to wireless network setup (could also be named Automatic Wireless Setup or Wireless Setup Wizard). Press OK 4. Highlight the Wireless Modems name, it will ask you for a password that the TWC man advised you, or you have set up. 5. It should connect to this and hopefully resolve your printing issue.
I hope this helps, if so please rate this response below Thank You for supporting the FixYa Community Regards GM
Apr 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Hp photosmart 7200 and hp laptop are not communicating. wierless signal strengh is excellent. cancelled , documents cancelled and error message appears.
Click on the link to resolve printing issue on wireless network -> Link
Click on the link to find out if the HP Printer is on wireless network on not -> Link
To Setup the printer on wireless network, follow the steps below
1. Press the SETUP Button printer front panel
2. Scroll to Network - Press OK
3. Scroll to Wireless Setup Wizard - Press Ok
The printer will start searching for wireless router.
Choose the SSID ( Network ) and enter SSID ( network key if setup ) and Press OK
You should get a message as Printer Wireless Setup complete.
Run the HP Printer Software Disk and Choose Add a printer and Choose Wireless Installation and follow the instructions on the screen to complete the setup
You are ready to Print and Scan
Oct 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
D-Link DPR-1260 print server setup problem
Try admin for logon & password.
Sometimes it is user ......
Feb 01, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
My printers that are on my wireless network won't print
Did you define the printers and printer ports to the laptops?
On the XP laptop go to network connections in the control panel and use the network setup wizard.
Jan 01, 2010 | NetGear WGR614 Wireless Router
Can't get 6310 to find laptop and allow wireless printing
you have to setup the network on the printer first click setup then go to network then wireless setup wizard once you do that insert the cd and add a device if that doesn't work it may be a firewall issue disable every firewall on your pc if it still wont find it it may be the firewall on your router
Jun 17, 2009 | HP Officejet 6310 All-In-One InkJet...
HP C4380, Wireless Printing Problem
Do you have other printer drivers installed, if so thre may be a driver conflict. wireless printing requires network connection and also printer drivers. This appears to be a driver issue since the printer shows up on the network. I would try reinstalling the drivers.
Aug 27, 2008 | Office Equipment & Supplies
Unable to connect through a N1 Wireless router with more than one user using a IPsec connection. Only one person can cannot and the other gets a timeout.
in order for the laptops to see each other and allow you to work one with the other a network has to be installed and a work group formed.
1. Choose Start --> All Programs --> Accessories --> Communications --> Wireless Network Setup Wizard.
The wizard shows its splash screen.
2. Click Next.
The wizard asks you to type in a name for your network.
3. Type a name for the network.
The name of the network is used for the wireless router's SSID (Service Set Identifier), which the wireless box typically broadcasts to make it easy to connect. The SSID is the name that appears when you try to connect to a wireless network. Each wireless router has a default SSID: tsunami, wireless, and linksys are all common default SSIDs.
4. Unless you already have a network key that you absolutely must use, select the Automatically Assign a Network Key radio button.
5. If your wireless base station and all the wireless cards on your network support WPA (if you have 802.11g, they may or may not; with 802.11b, it's unlikely), check the Use WPA Encryption box.
There is a performance hit for using either WEP or WPA encryption. Your network will run slower — but your neighbor won't be able to look at your files. Fair trade, eh?
6. Click Next.
Behind the scenes, the wizard generates all the information it needs to set up a secure wireless network.
The wizard asks if it can use a "key drive" (USB flash drive) to set up the network.
7. Select the Use a USB Flash Drive radio button.
Select this button if you meet the following requirements:
• You have a key drive (USB flash drive) handy
• A free USB port is on every computer on your network
• All of the computers on your network are running Windows XP Service Pack 2 or later
• Your wireless router has a USB port and it understands WSNK (check the manual)
If you don't meet those requirements, then select the Set Up a Network Manually radio button. Then click Next.
• If you click the first button, the wizard takes you through the steps to transfer the settings to all the other computers on the network, as well as the wireless base station. Basically, you schlep the key drive to all the PCs, and they set themselves up.
• If your hardware isn't quite up to the **** Tracy stage yet, the wizard shows you its final instructions.
8. Click Print Network Settings.
The wizard doesn't actually print them. Instead, it opens Notepad and sticks the relevant settings in a new text file.
9. Print the text file and follow the instructions to transfer the settings to each of your wireless devices manually.
It isn't as bad as it looks. See the next section.
Making manual changes So you're stuck with entering wireless network security information by hand. Be of good cheer. The Wireless Network Setup Wizard (see the preceding section) does all the heavy lifting. If you're running Windows XP Service Pack 2 or later, it's pretty easy:
1. Enter the new settings in your wireless router or access point.
Unfortunately, each one is different. You may have to dig into the router's manual. Usually, once you get inside the router, making the changes is easy. The key you need to enter is the one that was generated by the Wireless Network Setup Wizard.
2. Make sure you update/apply/save the changes to the wireless router before leaving.
Many routers require you to save the changes manually, so they'll be around if the electricity goes out.
3. Choose Start --> All Programs --> Accessories --> Communications --> Wireless Network Setup Wizard.
You see that really confusing splash screen again.
4. Click Next.
The wizard asks for a network name.
5. Type the network name precisely the same way that it appears in the printout from the preceding section.
6. Select the Manually Assign a Network Key radio button and click Next.
The wizard asks you to type the key.
7. Click Next.
You end up at Step 7 in the preceding section, from which point you can print your settings or just close down the wizard.
8. Repeat Steps 3 through 8 on each computer in your wireless network.
Jul 15, 2008 | Belkin Computers & Internet
Cannot configure the wireless USB Print Server
first delte all the programs that u have installed about the print server and the printer.then connect the print server on ur laptop and run the installation .search for the wireless netwrk and connecting to it using the wpa key.After tats done connect the print server to the printer and run the printer installation ,,hope that shud resolve it,,best of luck
May 06, 2008 | Port Incorporated Wireless 11Mbps...
NetGear PS121 Print Server Problem
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
For the print server setup, please follow the steps below:
Note: Before setting up the print server, make sure that you can print when printer is connected directly to the computer.
1. Wire the print server to router. Check the lights on it. It should have the ACT light on and the Error light off.
2. One way to test if the printer would work with the print server is to reset the print server for 3 to 5 seconds while it is powered on and after you release the button, the printer should automatically print the IP address of the print server.
Note: If the printer did not print, there is a possibility that they are not compatible. However, you may still continue to try to set up the print server.
3. Install the PS121 software.
a. Power on your computer, let the operating system boot up completely, and log in as needed.
b. Insert the Resource CD for the PS121 into your CD-ROM drive. The CD main page shown at the right will load.
c. Click Install Software.
d. Click Next and follow the software installation utility prompts to complete the software installation.
e. When prompted, restart your computer to complete the installation.
f. When your computer restarts, click Finish to run the Print Server Setup Wizard.
4. Run the Print Server Setup Wizard to Set Up a Fixed IP Address for the PS121.
a. The Print Server Setup Wizard screen should be displayed.
b. Click Next to proceed. The Print Server Wizard will now search your network for the PS121. If the Print Server Setup Wizard cannot find your PS121, check the network connections and status lights on the PS121.
c. The “Server Name” and the “IP Address” your network assigned to the PS121 are displayed. Click Next to proceed to the device name screen.
d. You can enter a descriptive Device Name and Domain Name or accept the defaults. Click Next to proceed to the IP Address configuration screen. The Print Server Wizard displays a recommended static IP address setting for the PS121. This is usually fine.
e. Click Next to proceed.
f. Click Finish to exit the Print Server Setup Wizard. This completes the configuration of the PS121 for operation on your network.
g. Click Yes to run the Add Printer Port Wizard. Follow the instructions in the next section for using the this wizard to set up each computer to use the PS121.
To set up each computer to use the PS121, please follow the instructions below:
1. Use the NETGEAR Add Printer Wizard to set up each PC to use the PS121.
a. When the Print Server Setup Wizard finishes, you are prompted to run the Add Printer Port Wizard. Click Yes to proceed. Alternatively, from the Windows Start menu NETGEAR Print Server program group, you can run the NETGEAR Add Printer Wizard.
b. After a short delay while the software searches the network for your PS121, the Printer Select window opens and displays the PS121 you have set up.
c. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
2. Set up the correct printer driver for the printer port.
a. Click Next to proceed to the Port/Printer name screen. Take note of the printer model number listed.
b. Click Next to proceed to the Select Printer screen. If you see the exact printer model number listed as the printer model number from in the previous screen, click it to select it from the list.
c. If prompted, print a test page to verify operation of the printer and the PS121. Then, close any remaining Add Printer Port Wizard or Windows Add Printer Wizard windows.
Use the NETGEAR PS121 Mini Print Server Resource CD to run the Add Printer Port Wizard to set up each PC on you network that you want to use with the PS121. Select the port you added
You may also use the links below as your guide to troubleshoot the print server:
http://kbserver.netgear.com/kb_web_files/n101269.asp
http://kbserver.netgear.com/kb_web_files/n100033.asp
However, if this does not resolve the issue we will need to get some additional details from you to be able to assist you further. I have summarized my questions below:
1. Model number of router
2. Model of printer
3. Operating system of computer/s
Apr 26, 2008 | NetGear PS121 Print Server
HP Photosmart C6180 All-In-One InkJet Printer Logo
171 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
