Question about Westinghouse WWBD2400HW 24 Inch Built-In Dishwasher
Water stays in dishwasher - Westinghouse WWBD2400HW 24 Inch Built-In Dishwasher
  • Westinghouse Master
  • 17,130 Answers
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Posted on Jan 11, 2013
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
Dishwasher stays on, no water going in and dial not turning. Thank you.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 08, 2011 | Hotpoint Dishwashers
Bosch logixx dishwasher draining constantly even with door open
there is a leak . when the unit stays in drain mode that means there is water at the bottom of the base. The float switch stays in drain mode untill the water is removed. you must take off the side panel to remove the water,let me know what happens.:)
Nov 08, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Water does not drain completely,water from sink backs up in DW
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jan 31, 2009 | Caloric 24 in. CDU510C Built-in Dishwasher
Some water stays in dishwasher (beau mark portable dishwasher
The manual says that's normal: "A small amount of clean water around the outlet on the tub bottom at the back of the tub keeps the water seal lubricated."
Dec 14, 2008 | Dishwashers
Dish washer problem
Please check the water supply is turned on before proceeding.
If it is, the supply to the internal water valve needs to be checked, and the valve for correct operation.
The machine will pause untill it has enough water in it - no water , and it won't advance.
Check out the water supply side of things to get it going again.
Thanks for using Fixya
Sep 30, 2008 | Crosley 24 in. CDU600 Built-in Dishwasher
Won't drain
The drian could be plugged or the pump could have an obstruction. Did you just install a garbage disposer? If you did you may need to knock out the plug in the disposer. Hope this helps
Jan 12, 2008 | Westinghouse 24 in. MDB421 RF Built-in...
Westinghouse WWBD2400HW 24 Inch Built-In Dishwasher Logo
118 people viewed this question
Top Westinghouse Dishwashers Experts
JonSnell Electronic
JonSnell Electronic
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
