Question about Panasonic Workio DP-190 Multifunction Laser Printer
When faxing a 401 error is reported
Fax is not going through to receipient...a 401 error code is coming back on the print out
  • Anonymous Feb 26, 2009
    I have the same problem I am trying to send an e mail and it rings that a fax machine has picked up but then it stops and the error message is 401 - how can I solve this problem
    Sergeant:
  • 284 Answers
Error 401 means that your number is not programed in the machine you are trying to , so it blocks it
Posted on Jan 22, 2009
The printer wont printer and displays "Unable to Print. See Troubleshooting and Routine Maintenance Chapter in Users Manual"
Unplug the printer for about 15seconds and then plug back in and power up.......this should reset the error code! Test print and you should be good to go!
Oct 05, 2014 | Brother Mfc9420cn Mfc-9420cn Fax Modem...
We have a seiko precision clock in / out machine model QR- 375 which is displaying error 38. plz help me to fix it
Hi it means that print head not going back to home position to complete it's process. Need to contact service center to repair and get the machine serviced on 1300 136 401 Australia wide.
Mar 28, 2011 | Office Equipment & Supplies
Fax wont' go through. Plugged phone jack into phone line and when I try to fax it doesn't connect. Any suggestions? Thanks
Can you receive any faxes. Run a Fax Test from the Tools menu. Is the problem with only one fax receipient? (Check the phone number and make sure they are set to receive. I have dealt with one fax receipient where the call-waiting service caught the fax call.)
Does the Fax see a dial tone? If there is no dial tone, use a single line phone (corded) to listen for a dial tone at that jack. If there is no dial tone, check the incoming service for a dial tone. (If you have no dial tone at all, contact your service provider.) Try a new phone cable (2-wire RJ-11) Try calling the number from another phone line with the single line phone attached. If the phone doesn't ring with a new cable, check your wiring and then contact your provider. Is the signal analog or digital (the all-in-one is designed for digital)?
Go back through the fax settings and set it as directed in Step 2 here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458259&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3643612 . You need the fax error reporting setting.
Disconnect any items that are plugged into the 2-Ext port.
Try reinitializing the unit. Unplug the power cord with the unit on. Make sure that the phone cord is fully seated in the 1-Line port. Then reconnect the power cord.
Try resetting the all-in-one, this may require 2 people. With the printer on, unplug the power cord and wait at least 20 seconds. Press and hold # and 3 while plugging in the power cord. Release the buttons after the unit starts up.
If none of these steps help the unit may need service.
Jun 27, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
How to print to fax using the canon imagerunner 2020i
On the installation cd's of the machine there is a fax driver if you install the fax driver the fax is showing as a fax in the printers and faxes in the controll panel.If you print to the fax a window will open where you tipe the name and number you want to send the fax to.There is also a option if you want to add it to the addresbook.After editing the info add it to the receipient list and send.Your document will faxed from your computer via the IR machine,if your machine is connected to a fax line.
You can edit the address book easy by logging to your machine via your broser tipe the ip address of the machine in your browser and press go.If the machine is connected via local LAN.
Nov 16, 2009 | Canon Office Equipment & Supplies
Status Code 19
Look in you menus. Your log print out is probably set to on and set to print out way to frequently. You can turn that feature off.
You can go to Xerox.com, click on Support and drivers. In the search box type in 116 then go to support and then type in Log, There should be an answer there as to how to shut off log printing. You cold also type in code 19 when you get to the support page.
May 05, 2009 | Xerox FaxCentre F116 Plain Paper Laser
Copier 212 error code U4
That is a fuser code. May be a bad heat rod or just need reset.
Here is how to reset it.
Enter diagnostics, Here is the procedure.
To enter diagnostics:
Hold down ‘0’ while turning on the Power the console will light up. Press ‘Stop/Clear’, the lights will shut off & --- will appear in the display Wait 30 seconds for the optics to complete a self-test before you enter any diagnostic test codes. Never turn off the power before the optics stop moving (or you’ll get a U2 code & possibly some unpleasant noises from the Scan Drive Motor).
Next setp is to use the code to clear the U$ code.
*To clear a fuser code:(401)
Enter diagnostics, wait 30 seconds for the optics to initialize, enter ‘401’ followed by ‘Print’, then shut down the power & wait 10 seconds before switching power back on.
That will normally clear that problem. Often times when a machine has set for a long time they wont warm up right and pop that code.
Another thing, if you can get the machine to warm up and come ot ready then it pops up a U4. Open that right side door. You will see this silver, looks like a small saw blade. It should be silver, but it will have a lot of ink built up on it, take a soft brush and clean it with that.
Let me know, if hte code 401 doesnt clear it, then the heat rod would have to be replaced. If that happens please let me know and we will procede from there.
Jan 29, 2009 | Xerox 212 Laser Printer
Error 401 & 634
error 634 is an indication that the line was either busy, or there was no answer on the receiving end.
Jul 23, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Printer error 054
That's because you need to take out cartridge and put it back! See is there any jamed paper inside!!! Error 054 is about cartridge!! Can't read that cartridge is inside the printer!!!
Feb 07, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Panasonic Workio DP-190 Multifunction Laser Printer Logo
1,426 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
