Biostar H55HD after booting message scan device please wait
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: need beep codes for biostar h55hd
you will nee to check every device on your computer
all electrical and data connection points at every device
motherboard to hard drive leads make sure secure dust free connections
make sure your ram modules are dust free and securely seated
the same with cmos battery though some motherboards cmos batteries are soldered in
check cpu central processing unit for dust free sure seating and thermal paste
hope this helps
Posted on Dec 07, 2011
Why i cant ditect my dvd rw in windows 8?
Hello download the manual here:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=473#dl
You need adobe reader, to read content.
Look in the bios setup, for basic boot settings for the drives.
The dvd drive, must be the first boot device, so the pc can boot from the windows disk.
The harddrive, must be the second boot device.
Good luck
Jan 21, 2013 | Biostar H55 HD Motherboard
Need beep codes for biostar h55hd
hope this helps
Dec 07, 2011 | Biostar H55 HD LGA 1156 Intel H55 HDMI...
My LaserJet 3055 All-in-one can print, fax and copy, but can not scan, when run the scanning software, the scan pub can move but when scanning data send to pc, the display of printer show "cannot...
"Power off" printer > Press & hold 'ENTER' > 'Power on'. Continue to hold 'ENTER' key only till "Program storage intt." (or similar nsg.) appears.
Wait & Let the unit boot to "Ready" message in the screen. Reload PC with device driver. Try to scan. If error persists Formatter PCB may need replacement.
Jan 25, 2011 | HP LaserJet 3055 All-In-One Printer
Hi my LT Aspire 5536G turned off itself when I was using it. Now when I start it the screen is black with this message - Base Code PXE-2.1 v1.0 PXE-E61: Media Test Failure, check cable PXE-M0F:...
The message you are getting is the laptop telling you it cannot find a boot device. The Broadcom message is the last option in the boot sequence (network boot).
I'm not sure what OS you are using, so the following is loosely based on a standard recovery, PLEASE don't just award a 1 thumb if this does not solve the issue, rather don't leave feedback.
First of all: Boot and press F2 or F10 or del to access the Bios, see that the hard drive is actually seen in the bios, if it is NOT, please repost, this points to HDD failure
Secondly, if it is, in the Bios, set the 1st boot device to DVD Rom. Insert the Windows Disc and IF using XP, wait until it finds the old OS and do a recovery. IF using Vista or Windows 7, its more or less the same, run a repair and if you get the OS back up and running, download a comand line virus scanner such as DRWEB Cure it and run a thorough scan for viruses on the hard drive.
Before condemning the hard drive, try removing it and re-inserting it, see if the bios recognises it.
I'd also advise downloading a disc checking utility to make sure the hard drive is still workable
Jan 22, 2011 | Acer Computers & Internet
Intermittent failure to boot up does not detect
hi.. have some idea on that... when you try to format your computer.. pls make the SATA as "first boot" or "second boot" then try to boot again your computer.. thank you very much...
Jul 08, 2009 | Biostar G31-M7 TE Motherboard
Disk boot failure insert system disk
Is it recognises Hard disk or not?
reply
i will try to solve u r problem
Jun 25, 2009 | ASUS K8V-MX Motherboard
Windows xp won't load on new biostar motherboard, please help
go to biostar web sight and download sata driver. You may need to run disk that came with motherboard first. Driver may be located on the disk. if not get it from biostar.
Jun 21, 2009 | Biostar K8M800-M7A Motherboard
Biostar P4M900-M7 SE BIOS ROM Checksum Error
The bios upgrade procedure stopped at half , leaving the bios corrupted. The computer now cannot do a regular boot procedure, this is the reason why it cannot recognise some device. If you are still able to boot from floppy, you can restart bios upgrade procedure from floppy. Just download floppy version upgrade and re do setup. Even if you do not find latest bios version, just download a floppy upgrade that is working, so that you can restart your machine regularly , and then do the update to latest version.
If you are not able to complete the bios setup, the only way to fix your motherboard will be flashing the CMOS chipset with a chip programmer device that will reinstall bios straight into cmos chipset.
You can have this done at the service point, in this case consider also replacing your motherboard.
Regards
Apr 03, 2008 | Biostar P4M890-M7 Motherboard
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
Computers & Internet Logo
180 people viewed this question
David Payne
David Payne
