Question about Dryers
70 Series Dryer will not start. Checked breaker box. Unplugged unit and checked connections and cleaned out built up lint dust. Door is sealed properly and light inside dryer is still on when door is
  • bud park Jan 16, 2013
    if the door switch works check the thermal fuse on the duct housing (skinny white fuse) if the fuse is bad replace the thermostat also
  • Thomas Perkins
    Thomas Perkins Jan 16, 2013
    Your button you push to turn on could be loose remove cover to see if the connector didn't come loose.
    Genius:
  • Dryers Master
  • 1,669 Answers
Check the motor for a blown fuse or circuit breaker attached to it, maybe a wire is disconnected from it. Another thing to look at is the actual switch on the top. Is it making good contact? Does it have a fuse or circuit breaker attached? Is it getting power?
Posted on Jan 11, 2013
    Problem Solver:
  • 6 Answers
If the light is still on when the door is closed it thinks the door is open and will not start - check the door switch - make sure you here a click and the light goes off when you activate it manually
Posted on Jan 16, 2013
  • 14,338 Answers
Could be braker is bad,get meter and check if power is there.
SOURCE: Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Posted on Oct 07, 2008
Oceti
  • 51 Answers
SOURCE: DRYER
The thermal cut-out is located on the side of the heater housing assm. To gain access you need to use a putty knife to depress the two spring clips between the top and the front panel and raise the top. The heater is on the back wall. The part number for the t-stat and thermal cut-out kit is LA-1053 and is about $20.00. Don't forget to clean your vent, and check your blower assm. Either one could have caused the problem.
Posted on Jan 10, 2008
IFIXALL
  • 868 Answers
SOURCE: Kenmore 80 series dryer won't start
Look for a bad thermal fus0526080941.jpge pix below.Straight wire to test it.Replace if the dryer turns on. 2nd. Test the door switch.
Please rate This !
Posted on Jul 09, 2008
SOURCE: Whirlpool duet electric dryer, not getting any power
Mine shows a faint light behind the control locked indicator and the timer is dimly lit on the two middle horizontal bars (middle of the eights). They go off by pushing various button combos. If I unplug it for a week I can get the control to work for a few minutes.
I replaced the control board, it worked for 5 minutes, then back to nothing. I want to replace the interface but would rather not waste any more money.
I dont want to check every wire for continuity. If someone has fixed this problem, please let me know.
Posted on Aug 15, 2008
  • 1122 Answers
SOURCE: kenmore dryer series 70 won't turn on
most of the time it is the door switch that goes bad,also you can check the main fuse inside the dryer on the blower box,and always make sure your dryer vent and wall vent are clear to vent,let me know what you find-mike
Posted on Oct 29, 2008
Started drying load, dryer shut off. won't turn on. checked door, changed thermal fuse, checked breaker. still doesn't work. light also not on.
If this is an electric dryer, you may have lost half of the power supply to it. Unplug and remove the little cover plate above where the power cord enters the dryer. Look at the 3 screws holding on the power cord for burned/black looking or loose connections. If nothing wrong there, shut off house breaker and remove cover on house plug where you plug the dryer into and look for same type of issues.
Mar 17, 2015 | Kenmore series 70 80 90 Dryer Motor...
Maytag 5000 Series Washer won't start. Door lock light won't come on. No function will start.
Hi Al....sounds like you checked just about everything.
However.... I am going to throw one last check your way.
Blown fuse or tripped circuit breaker. Good luck.
Regards,
Denis
Oct 21, 2014 | Washing Machines
My Whirlpool gas dryer is not working
Instructions
Check that the dryer door is closing completely. Remove anything that blocks the dryer door from closing.
Ensure the "Start" button is pressed firmly to start the dryer cycle, the dryer is not overloaded and the clothing is not balled up. Any of these things can prevent the dryer from operating and/or drying the clothes.
Use a level to confirm your Whirlpool dryer is sitting flatly and evenly on the ground. Adjust the dryer as necessary for it to be level as the dryer will vibrate and make unnecessary noise when sitting unevenly.
Examine the inside of the Whirlpool dryer drum and in the space around the drum for loose change, pens, hair ties and other items that could have been left in the pockets of clothing. These items will cause noise and potentially cause the dryer to become inoperable.
5
Examine the Whirlpool dryer's lint trap for excess lint. Remove any lint from the trap and place it back into position. Always clean the lint trap between dryer cycles. Inspect the area around the dryer and in the ventilation and exhaust systems. Remove any built up lint and clean the area thoroughly. Built up lint is a fire hazard and can cause operating issues.
6
Check the gas shutoff valve if your Whirlpool dryer is gas powered. Ensure the shutoff valve is turned all the way to the "On" position.
7Check the electric plug and ensure it fits securely in the outlet.
8
inspect both the fuse box and circuit breaker for any electrical problems. Replace any blown fuses, if necessary, and reset the circuit breaker if it has been tripp
Jan 09, 2013 | Whirlpool Dryers
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The fuse probably blew due to a blockage of some sort. Check your ventpipe. It may be full of lint. The fuse is a small white part held onto the blower housing with 1 screw. It usually can be found under the dust cover on the rear of the dryer.84a81ce.jpg It has 2 small wires hooked to it and it is wired in series with the door switch. When the lint gets built up and dryer over heats and fuse blows. The result is just as if you opened the door.1d45fbe.jpg
Dec 16, 2008 | Whirlpool LER4634J Electric Dryer
Apr 29, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
