Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
Fax problems when i try to send a fax the cover page usually goes through but the rest of the pages get stick. and after dialing for a long time the fax says "comm. error press stop" and the fax doesn't go through. it also says that it needs an ink cartridge but i don't think it has anything to do with sending faxes because sometimes sending a fax works. any suggestions? thanks!
  • 328 Answers
Hopefully it is still under warranty. That model has a problem with printheads. Best to check with Brother for warranty center in your area.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 09, 2007
SOURCE:
HOW CAN I SEND A FAX WITH CANON SUPER G3
Insert the fax. Prepare the documents you need to fax. Place the original paperwork face down with the top edge first in the Automatic Document Feeder.Set up the cover page. Press the "Menu" button, and then press "2," "2," and "8." When "Next Fax Only" appears press the "Set" button. Use the arrows to select "ON" and then press "Set."Select a cover page comment. The comments available for the fax receiver to view include, "Please call," "Confidential," and "Urgent." Use the arrows to select a comment and then press the "Set" button. Input the number of pages you are sending and then press "Set" again.Enter the phone number. You can store phone numbers in your system under the one touch dial or speed dial options. Use One Touch, the key pad, speed dial, or search to enter the phone number you would like to send your fax to.Send the fax. Once the document is inserted, the cover page is set, and the phone number is entered press the "Fax Start" button located in the bottom right corner of the control panel. Your fax machine will then dial the number and proceed with sending your documents
Apr 16, 2011 | Computers & Internet
NEED 2 PROGRAM COVER PAGE
Cover Sheet
You can have the fax machine generate a cover sheet and send it as the last page of your fax transmission. The cover sheet includes the date and time, the receiver's name and number if a Rapid Key or Speed Dial number is used, the sender's name and number, and the total number of pages.
? Your name and number must be programmed in order for them to appear
on the cover sheet (see page 49).
? To have the recipient's name appear, you must dial using a Rapid Key or
Speed Dial number with the name programmed.
1 Load the document(s).
• SEND READY will appear in the display.
• Press RESOLUTION and/or CONTRAST to set the resolution and contrast if needed.
Press Cover Sheet. (Flip up the Rapid Key overlay if it is down.)
• The display will briefly show COVER SHEET MODE ENTERED and then
revert to SEND READY.
• To cancel the cover sheet selection, press STOP.
3 Dial the receiving party and transmit the fax.
If desired, you can set your fax to automatically send a cover sheet with every
transmission (you do not have to press COVER SHEET each time). This is
accomplished by setting Option Setting 10 (Auto Cover Sheet) to YES as
explained on page 125.
Jan 17, 2011 | Sharp FO 5800 Fax
Fax sends certain pages in duplicate
If it only happens with that one vendor, the problem is almost certainly either on their end or somewhere in the interaction between the two fax machines.
The most likely answer is that their fax machine has a problem receiving some pages (either because the line is noisy or for another reason) so it has to reprint them. You could tell your vendor to try turning off error correction on their fax machine and see if that makes a difference.
Hope that helps.
Jul 05, 2010 | HP 920 Plain Paper Fax
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Laserjet 3015 will not fax more than one page a time
Open up the document feeder and clean the roller and pad with alcohol.
Jun 08, 2009 | HP LaserJet 3015 All-In-One Printer
Forgot how to send a Fax
Place your document(s) face down in the feeder, dial number, and press "start". That's it.
*Please rate me
Mar 26, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Sending fax
If you sending the fax over the memory, fax can scann doc. while dialing, or in the same time, but if you sending directly (on-hook dial) fax is sending the document while beeing reeded.
You may try to check the phone lines, browse the documents before sending,clean the original document feed rollers,...
if fax sudenly stops and wrinkle the orig. documents there is problem in scanner area
Jan 16, 2009 | Canon FAX-JX200
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 07, 2008 | HP Officejet 4215v All-in-One Printer
Storing Outbound Faxes not sending.
if you print a tx journal does it have an error on those you tried to send
Mar 19, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Fax sending problem
It sounds like you have a few problems. First, the comm error usually means there was a problem communicating with the other fax. This maybe caused by a phone line issue, or a bad connection. You will have to replace you ink but that does not have anything to do with your sending issues. As far as the pages getting stuck, the separation pad under the top cover should be cleaned. If you lift up the cover where you load your pages to be sent, and look in there(on the backside of the keyboard)you will see a flat square rubber piece. Clean it thoroughly with a rag and some rubbing alcohol. Also clean the rubber rollers as well. Good luck John
Jul 03, 2007 | Brother IntelliFAX 1840C Plain Paper...
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
79 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
