My headphone jack does not work, sound still comes out from the speaker when i plug head phone. please what should i do?
The headphone jack isn't working. sound still comes out from the speaker when i plug the headphone
  • chy_nna
    chy_nna Jan 13, 2013
    i have tried your solution but it didn't work. it's not as if the the headphone jack stopped working all of a sudden,, but, it started after the system was reformated because of a crash. what else should i try pleaseeeeeeeeeeeeeee?
  • chy_nna
    my problem in a nutshell is that my computer does not dectect any headphone plugged into it.
  • 2,385 Answers
It shows that the headphone may gone bad, or the jack of your pc needs repair, check your headphone to some other computer if it ok then go for repair the jack from some qualified technician
Posted on Jan 11, 2013
5 Suggested Answers
clokker
  • 253 Answers
SOURCE: Audio Jack not working on my notebook
Install the sound driver from your computer.You can find it on the homepage from your pc.Re-install it.If this not helps install the ac97 driver...
Posted on Jan 16, 2009
  • 3940 Answers
SOURCE: sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Posted on Mar 02, 2009
  • 130 Answers
SOURCE: Dell latitude D620, no speaker sound
you will have to uninstall your audio device, and uninstall SKYPE and re install the audio device and don't re install SKYPE, you can do this by going to add or remove programs, and remove SKYPE first and unplug u r headset and mic, and after removing skype you can reboot the computer, and sometimes the conflict is resolved, otherwise then go into your device manager in system manager and find audio devices, unistall the driver or Update the driver, and reinstall it and the reboot, that should take care of the problem.
Posted on Jun 27, 2009
  • 5 Answers
SOURCE: speaker/headphone jack won't work
It may not be the problem of sound card,
try following:
1) try uninstalling/reinstalling the sound drivers from device manager.
2) put the laptop to sleep(standby) mode and than wake up.
Please visit http://www.fixya.com/support/t1728089-speakers_work_but_headphone_jack for more details..
Update, if the solutions work..
Posted on Jul 01, 2009
Suddenly there is no sound in the speaker but headphone works fine..laptop is Lenovo B575
If the head phone jack works its more likely to be the problem, if you use the headphone jack a lot the connections inside it can get worn or bent out of shape--engaging the headphone jack should shut the speakers in the unit off.
Other possible reason is a bad speaker or connections.
Dec 14, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
Hi plz help me i am using IBM r51 laptop which has all drivers but not able to get sound of it. but when i connect a headphone i can get sound of it. but my laptops speakers r working as i tested mt...
ibm sound card is not faulty, because you are getting sound with your head phone. The head phone jack have two functions 1. to give output to head phone 2. to disconnect internal speakers when you plug in head phone.
The jack for headphone in normal position not give connectivity to internal speakers.
SOLUTION : REPLACE THE HEADPHONE JACK.
I think it will help you.
Sep 15, 2011 | IBM ThinkPad Soundcard
Iam using ubuntu 9.04.sound card is not working.I
If you are getting sound through your speakers then the sound system is working. If you lose the sound when using the headphone jack then either the headphone jack is faulty or your headphones are...
Although, rarely, you may find that opening the alsamixer from the terminal will fix the problem as some versions of Ubuntu have a special volume control for the headphone jack....
You will need to open the mixer as the Administrator
Type
su aslamixer
If this helped please vote kindly
Oct 07, 2009 | Canonical Ltd. Ubuntu
When i connect headphone in my compaq c700 laptop the sounds came from both the headphone and the inbuilt speaker in a time. please help me.
When you plug your headphones in there is a dis connect the head phone jack should be contacting to break the circuit to the internal speakers. Try a different head phone set. If this doesn't work, the female jack is (in the computer) is probably malfuncitoning. This will require a decent repair man...
May 04, 2009 | Computers & Internet
Fujitsu T series; no sound when I plug in the headphones
I have the same problem and just figured it out. Go to the sound settings and set the earphones as the default. I just did this and it now works.
Nov 27, 2008 | Fujitsu LIFEBOOK T4010 Tablet PC
I have acer extensa 4220 laptop when i plug in head phones in the laptop the sound still keeps on coming from the built in speakers and not the head phones
khalid276,
I had this problem also on my acer aspire 5520. This laptop has 2 3.5mm jacks. It was a bit embarrassing, but I had the headphones plugged into the input jack. Make sure that you have the head phones jack plugged into the correct jack.
I hope this helps!
Airmack
Oct 11, 2008 | Acer Computers & Internet
Problem with speakers, Mac laptop MacBook 13" white
HAHA i had the same problem so here is what i did...i stuck a head phone plug in the jack and smacked it a couple times and bam it works....i would suggest doing this if your lazy otherwise go to the apple store because obviously somthings not right in your laptop.
Aug 23, 2007 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
203 people viewed this question
David Payne
David Payne
