Question about LeapFrog Leapster 2 Learning System
My leapster middle crosshairs will not calibrate
Leapster 1
    Problem Solver:
  • 5 Answers
Clean the debris from around the touch screen with a tooth pick but be careful.
Posted on Feb 20, 2013
Kindofcheap
  • 241 Answers
SOURCE: Leapfrog Leapster doesn't read cartridges anymore?
HI my son has a LEAP frog MAKE SURE THAT THERE IS NOTHING OBSTUCTING THE CONTACTS( metal on the game and the cartdridge meet)
PLEASE RATE THIS HELP FiXYa EXPERTS HELP
Posted on Sep 02, 2008
SOURCE: Leapster 2 will shut off right after the "important" screen
Are you using it with a game? Will it stay on if NO game cartridge is in & are U able to access & play Pre-installed games?
If so, it may be the cartridge is DIRTY. I discovered this with our Leapster 2. What works for us is getting a Q-TIP & RUBBING ALCOHOL, you want to saturate Q-tip with the rubbing alcohol & clean the CARTRIDGE (NOT the Hand held ).
You want to clean the computer chip @ the bottom by inserting Alcohol soaked Q-tip on each side of contact strip (the part that inserts into the hand held) & with the dry end of Q-tip go over it again, for more cleaning & to wipe up any EXCESS Alcohol. REPEAT this process until Q-TIP comes back CLEAN.
I was really surprised @ ALL the BLACK grime that came off cartridge.
I hope this helps.
Good Luck.
-The Johnson Family :-)
Posted on Jun 18, 2009
SOURCE: My son's Leapster 2 game won't recognize the SD
Try using a smaller card. Their website says anything over 2Gig is not recommended.
Posted on Jul 15, 2009
  • 3 Answers
SOURCE: We have leapster two, we have power but the pen
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Posted on Aug 11, 2009
  • 3 Answers
SOURCE: the touch screen does not work on leapster 2
Turn off the Leapster2 and remove cartridge (if there is one).
Push and hold down the hint button (the one with the question mark) while the game is off.
Turn the Leapster on while still holding down the hint button until you see the calibration screen.
Push the "A" button to enter the calibration.
There will be a little plus sign. Touch it with the stylus and continue to touch the plus signs with the stylus until you return to the calibration screen.
Turn the Leapster off and then back on again without a cartridge. Login as usual.
If this does not work, then call customer service, depending on how old it is. I've had ours for over a year, and this still works each time.
Posted on Jan 01, 2010
Leapster2 is 2 1/2 years old. Placed brand new batteries in Leapster2. Try to power it on, screen comes up like it is going to turn on, and it turns off.
Welcome to FixYa!
Ensure NO GAME is in unit
Power Unit off
While turning Leapster 2 on, hold down HINT KEY. (Key in middle with question mark on left hand side)
Once unit switches to other menu, Hit A to begin calibrating.
Follow prompts with Sylas pen to reprogram Stylus pen.
Once you are done it will return to original Calibrating Menu.
Power Unit off Turn unit on with game inserted. Stylus pen should respond.
Do comment if it helped or not in any manner ill know.
Apr 15, 2011 | Leapster 2 Handheld Game
When the main screen comes on and says touch your name with the pen it does not resond what do i do?
It sounds like the TouchScreen needs to be calibrated.
1. Hold down the Hint button while turning the Leapster on.
2. When the Leapster menu screen appears, press the A button.
3. Touch each of the crosshairs that appear with the stylus.
4. Restart the Leapster.
Hope this helps!
Feb 27, 2011 | Leapster 2
Leapster 2 does not respond to the sylus.
I had the same problem. I tried to clean it, brush out crumbs, gently "bleed" it and so on until I saw Quebol96's answer to the same problem: www.fixya.com/support/t3077478-leapster_will_not_recognize_pen_first
Quebol96's solution worked perfectly!
From Quebol96:
Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
Feb 24, 2010 | Leapster Learning System
My daughter has a Leapster 2 that is only about 2 months old and the touch screen does not work
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
5) Restart unit
Jan 30, 2010 | LeapFrog Leapster Learning Game System
The touch pen doesn't work
Answer
5) Restart unit
Nov 28, 2009 | LeapFrog LeapSter L-Max Console
We have leapster two, we have power but the pen does not work
Aug 06, 2009 | LeapFrog Leapster Learning Game System
My Leapster 2 comes on, shows the name on screen & ask to touch my name w/ the pen; however when I touch the name, nothing happens. It keeps asking to touch a name or "guest".
Answer
5) Restart unit
Jul 28, 2009 | LeapFrog Leapster 2 Learning System
Cant sign in
Jul 02, 2009 | LeapFrog Leapster Learning Game System
Hi... I have a leapster which we purchased on march, 2008.Recently, the screen doesnot seem to respond for the stylus. but the button works well. what can we do to fix it? [i live in indonesia]
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Jan 23, 2009 | Leapster Learning System
Leapster can't read input
You need calibration
Touch Screen Calibration is as:
1.) Ensure that a cartridge is NOT inserted.
2.) Hold down the Hint (’?') button while turning the unit on.
3.) When the LEAPSTER menu screen appears, press the ‘A’ button.
4.) Touch each of the crosshairs that appear with the stylus.
5.) Restart the unit.
Dec 25, 2008 | LeapFrog Leapster Electronic Book:...
LeapFrog Leapster 2 Learning System Logo
189 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
thegtw
relojmesa
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
