Question about KitchenAid KUDS30IXBL Builtin Dishwasher
My kitchen aid dishwasher hi temp scrub light and cancel light stay lit and wont reset
SOURCE: Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
Posted on Jun 22, 2008
mohammed387
  • 1952 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Sep 21, 2008
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid dishwasher Child lock light on and dishwasher will not start.
if your unable to unlock the "childlock" by holding down the button, then it woud seem that theres a problem with the user interface itself
Posted on Oct 19, 2008
  • 3 Answers
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Posted on Apr 27, 2009
SOURCE: Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Posted on Aug 24, 2009
My Kitchen Aid dishwasher, model KUDK03FTSS3, is stuck in a loop of some sort. It starts, but freezes after a few minutes. Does anyone know the reset key sequence to make this go away? Kitchen Aid customer...
Hi. Pressing and holding the cancel button may reset the unit at this time,as well as, pulling the ac plug out of the wall outlet for five minutes. With that said, I will provide the proper reset sequence below. 1. Open the door of the unit slightly. 2. Within three seconds, press the following sequence in this order-high temp scrub,energy saver dry,high temp scrub,energy saver dry. 3. After the sequence, close the unit door and latch it. 4. After the door is closed, press the cancel button. This will reset the main control, unless there is major damage to the circuitry of the control board.
Oct 13, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
I can't turn on my KitchenAid Superba dishwasher. I pushed Normal and Start, and the Normal light started flashing, but didn't turn on. Pushed Cancel and now both the Normal and Cancel are...
Did you try turning off the power and then connecting it again?
If still problem is there open the door. Press the following sequence of buttons HI Temp Scrub, Energy Saver Dry,HI Temp Scrub, Energy Saver Dry. Now close the dishwasher door and latch it too and press the cancel button. This must reset the dishwasher.
Aug 13, 2011 | KitchenAid 24 in. KUDU02FR Built-in...
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
Clean light flashes
First, press and hold down Cancel and see what happens. That may reset the cycle.
or
The reset sequence is :
If clean light flashes seven times then
http://www.youtube.com/watch?v=Hv7xOaucH7I
Check this video for detailed explanation on what is the problem and how to rectify it.
It has an video for the same.
Sep 05, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen aid dishwashers model kudi1o1ilbl6 won't function. Cancel light flashes 7 times pauses and flashes 7 times repeat for ever. killing the power did not reset. Advice?
open door, press in rapid sequence the following keys: hi temp scrub, energy saver dry, hi temp scrub, energy saver dry. Close the door until it latches, then open it and depress the cancel key. The lght should clear. It's a beautiful thing.
Aug 15, 2009 | KitchenAid 24 in. KUDS25 Built-in...
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Open the dishwasher door, press in rapid sequence the following keys: Hi Temp Scrub, Energy Saver Dry, High Temp Scrub, Energy Saver Dry. Close the door until it latches and press the Cancel key. The machine should reset itself. It worked for me when I had the same problem
Oct 20, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid KUDS30IXBL Builtin Dishwasher Logo
262 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
