Question about Canon PowerShot SD600 Digital Camera
Dropped Canon - Display Broken
Hello! I recently dropped my Canon Powershot SX10IS. Now the display screen only works on about half of the view. Twisting the screen to rest against the camera body makes it worse, causing the entire screen to only display vertical black/white bars. The view through the eyepiece is the same as on the liveview screen. The camera still takes photos which load into the photo program and are complete images. I hope you can help us - I love my camera and miss, miss, miss using it! Thanks, Susan
  • Canon Master
  • 5,412 Answers
Repair expensive, if possible. Replacement best option.
Posted on May 25, 2017
  • 4738 Answers
SOURCE: canon powershot a60 white lcd/no photo
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Mar 11, 2008
  • 11 Answers
SOURCE: Canon showing black screen
needs to go in to a camera shop for repair, either the shutter is broken in the lens or the CCD is bad...could be more than that but, It would have to get disassembled to determine that. I work on Olympus cameras and have found that sometines it's easier to let someone with a box of spare parts fix it...
Posted on Oct 09, 2008
  • 4738 Answers
SOURCE: Lens blocked? Canon PowerShot SD1100 IS, recently water damaged
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
Posted on Jul 14, 2009
  • 89 Answers
SOURCE: Black Screen on Canon PowerShot SD750
Probably bad CCD. !!! Check if there is possibility of free of charge repair !!! Many models are repaired free with CCD broken, even warranty time is passed.
Posted on Sep 18, 2009
old marine
  • 2058 Answers
SOURCE: How do I take black and white photos using a canon powershot?
Place the camera in P, Tv, Av, M, Movie, or Stitch-assist mode. Press the Func/Set button, and scroll down to the "My Colors" icon on the left side (second or third icon down, should show "My Colors Off" at the bottom of the LCD). Now use the left/right buttons to select "B/W", and press the Func/Set button again.
Posted on Mar 16, 2010
Canon G5 Powershot LCD screen is black and will not show images in any setting.
Are you sure the battery is ok? Did you press the button display (bottom right nest to the display) several times? Next, how long did you not use this camera? If it was for long, something inside could be corroded. Did you recently drop the camera? Something more serious could be wrong. I'm not sure you can make any picture, because you don't need the screen to make a picture. You then could look is a proper picture is on the memory card. If the rest of the camera is working ok the viewing must work also. Check is the off button is moving correct. (And not blocked) Resetting could be an option, but you need the display to answer the question. This is in the user manual.
Oct 23, 2013 | Canon PowerShot G5 Digital Camera
LCD Display on camera not working
It looks like the LCD screen is the only damage. This can be fixed at your Canon camera repairer.
Apr 16, 2013 | Canon PowerShot S3 IS Digital Camera
Canon powershot sx100is. Error 24 on starting and camera turns off. Can view pictures already taken.
some dry wash lens,display & camera.mother board clean with isopropyl or" petrol.if use ******** wash very good.something heat with mobilephone work it again.harry up in one day or"So4 damage your board.
May 30, 2012 | Canon PowerShot 600 Digital Camera
My Canon powershot SX10is LCD screen does not work when it is open (extended from the camera). Is there a setting or something I need to change
Press the Disp button near the bottom right of the LCD display housing.
You may need to press it twice to switch the display back to the LCD from the Viewfinder.
Jan 23, 2011 | Canon PowerShot SX10 IS Digital Camera
View screen won't work
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Dec 05, 2009 | Canon PowerShot SD1100 IS Digital Camera
nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Oct 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Sep 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Dropped Ixus 50 in water...!
place your camera in a hot press, or where your boiler is, on shelf and it might dry out in a day or two, then try it again.
Aug 26, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Two different Canon A520 problems.
hey guys. there is no solution that you can do it for yourself. the best solution i can give for you is take it to service centre. here in india we get charged nearly 1800rupees for servicing the lens portions.
Nov 21, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
156 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
