Question about Fujitsu Plasmavision 42" TV
Fujitsu Plasmavision 42" TV Pixelation
I received this monitor a month ago from a friend and they said that there were horizontal green lines in the picture. I took the monitor home and did not have the same issue. Instead when hooked up a computer, or Xbox the screen would act strange. It will look okay until something moves across the screen. It appears the problem happens at certain points in the screen. if the window/ icon moves through this section the screen will go black or pixelate (making a great majority of the pixels cyan or magenta). When the picture goes black the screen is still on and if I move around the picture will come back.
  • cheesecake_n
    cheesecake_n Jan 11, 2013
    After a bit of testing I found that The problem seems to be connected to the colors in a general area. If point 300x100 is blue (for example) the screen will freak out.
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: Has anyone seen this problem in a Fujitsu PDS
Hi
Thanks for using FixYa. From what you have described it seems to be an issue with Y board however, Z and the logic board should also be checked. These boards are located on the right side of the unit and to check them you'll have to open the back of the unit. Once you have opened the back also check for any blown/bulged capacitors. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position.Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 08, 2010
Tip
Drivers for Fujitsu Plasmavision 42" Display
At http://www.plasmavision.com/tech_faq.htm the following answer is not exactly true:
Q: I'm running Windows XP on my Plasmavision display. Can you please send
me, or tell me where I can download, the video drivers for this model?
A: Video drivers are part of the video card installed in your computer, rather than the monitor showing the computer's images. Please check with your video card manufacturer. All Fujitsu displays are Plug-N-Play devices, so there are no drivers available.
For the PDS4203-WH circa 1999, there was an optional video card based on an S-3 ViRGE chipset that allowed you to connect your computer to the display and get the best use of the 852 (H) x 480 (V) display. Without this, almost all video cards fail to display fonts so that they are perfectly legible, which can be quite problematic, lol. Hopefully, this problem was resolved in later models, and they truly are Plug n Play.
Back in the day, this was a great monitor for playing video games. Outcast, from Infogrames, was gorgeous.
on Sep 20, 2010 | Fujitsu Plasmavision 42" TV
Is 9 year old Fujitsu Plasmavision TV worth fixing?
Hi
Can i please know yout TV model number to assist you better.
Thanx
Jul 22, 2010 | Fujitsu Plasmavision 42" TV
Fujitsu Plasmavision 42 42'' TV 4209 picture last for 5 minunets then black ??? Power supply ???
No not power supply, it's the X and Y sustain boards. These boards have to be replaced as a pair.
Contact Fujitsu for a repair of this unit.
Feb 16, 2010 | Fujitsu Plasmavision PDS-4209 42 in....
Picture goes out and red power light flashes
Up , i also encountered the same problem 3 days ago. 42" Fujitsu Plasmavission. I'll try to call an expert, i hope its not a digital board again for me, it will cost around $2,000usd so better buy a new Korean made LCD for better and cheaper parts. I guess you also experiencing trmendous heat at the back of your plasma right?
Dec 19, 2009 | Fujitsu Plasmavision 42" TV
Fujitsu p42hha30ws
Black vertical line indicates horizontal deflection section not working. Change horizontal linearity coil the problem is fixed
Jul 24, 2008 | Fujitsu Plasmavision 42" TV
Turns off after awhile
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Apr 12, 2008 | Fujitsu Plasmavision PDS-4214 42 in....
Fujitsu plasma went blank
Need to have the power supply checked by a qualified technician.
Feb 12, 2008 | Fujitsu Plasmavision 42" TV
Fujitsu plasma tv
See Fujitsu Service Bulletin on this problem. -see link below
Jan 25, 2008 | Fujitsu Plasmavision P42VCA30EH 42 in....
Fujitsu Plasmavision 42" TV Logo
41 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
