Question about LG Washing Machines
ZANUSSI zwf1421w delay lights flashing
When i put on a load of washing the machine will wash the clothes but i have noticed the delay lights and the lights to select the length of time to delay the wash by start to flash during the wash cycle could someone help with a solution
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
I have a zanussi zwf1421w its not spining out the clothes properly. Yet its not vibrating badly to indicate its off balance. Also not always draining the water away and I have noticed the lights on the...
Assuming your pump is now ok could be the motor or brushes more to the point that is making it not spin too well. Brushes on this will last about 5 years after that well worn......
Apr 06, 2010 | Zanussi ZWF1420W Front Load Washer
My Zanussi ZWF1421W has stopped taking the fabric conditioner through in the wash cycle - it remains in the drawer....
Zanussi ZWF1421W
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 30, 2009 | Washing Machines
Zanussi zwf1421w washing machine makes a rumbling/rattling noise when spinning.
Motor is kicking on and off making that noise....so far for us this has been a motor issue 9.5 times out of 10
CLICK THE LINK DIRECTLY.http://www.youtube.com/watch?v=EqeGv3B-3xw
May 05, 2009 | Zanussi ZWF1420W Front Load Washer
Zanussi ZWC1300W Front Load w'Machine
is it spinning during spin cycle
your timer may have gone
Jan 18, 2009 | Zanussi ZWC1300W Front Load Washer
ZWF1421W Zanussi Wasing Machine
Unscrew filter body and gently, using a pair of mole grips, wiggle and pull the filter body.
If this doesnt work the best option is to replace the whole filter assembly. You do not need a new pump though!!.
PS Cleaning the filter on a regular basis will help prevent this!!!!!
Nov 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi Washing Machine
At bottom left of machine there is a small metal flap where you can drain off water. Next to that is a grey pipe you can keep pulling and pushing i have done this quite a few time and it has let out sludgey stuff put washing machine is now spinning and draining. Good Luck.
Aug 29, 2007 | Zanussi ZWF1420W Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
