Question about Watches
Ideas on how to remove back to replace batteries on citizen aqualand duplex c506
Watch back does not have screws on it, but does have 5 notches which are set asymmetrically to one another. Is it a screw back or a lift off back, suspect the former. Suggestion on how to remove with out jeweler specific tools?
  • Watches Master
  • 18,402 Answers
It is a screw on back, you can get the tool off ebay verey cheep or you can use a pair of pointed nose pliars, this link is the manual for C506,,,
http://c5602631920d46a2508a-8d72983753baa190ad1811b919e590cc.r52.cf1.rackcdn.com/calibers/321_abbr_instructions.pdf
Posted on Jan 11, 2013
  • 373 Answers
SOURCE: Replacement battery for Philippe Starck Fossil watch
can you check on web site
Posted on Jan 31, 2009
  • 101 Answers
SOURCE: Citizen watch secondhand not moving
its a solar watch meaning you have to completely charge the watch under artificial light for 24 hours or full sun for 6 hours
Posted on Aug 19, 2010
  • 73 Answers
SOURCE: Instruction manual
Go to this link and follow instructions for finding your particular watch movement and then lookup instructions.
http://www.citizenwatch.com/COA/English/settings.asp
Posted on Dec 31, 2007
SOURCE: Can't set the hour on my Aqualand Duplex
i followed the instructions on the Citizen website for a system reset and it worked. Unfortunately, the regular way of setting the digital hour does not. Maybe a technical problem? The movement number for the Aqualand duplex is C506.
1. unscrew the analog adjustment crown and pull one click
2. press and hold the other 3 buttons for 3 seconds and release.
3. push the analog crown back and adjust the digital time.
this is a system reset so you will have to set the date. You will lose your settings and your dives. good luck.
Posted on Apr 02, 2008
SOURCE: removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
Posted on Apr 23, 2009
Tutorial on battery change
These Aqualand watches have three separate batteries and are not meant to be changed by anyone but citizen repair person. It is best to send back to ensure it is water proof. It's not real cheap though
Sep 28, 2013 | Citizen Aqualand Duplex JP1074-58E Wrist...
Battery number for citizen divers watch c506
I just opened my Aqualand Duplex Titanium C506 and the battery is one CR2016.
Sep 08, 2012 | Citizen Aqualand Duplex JP104009E Wrist...
My citizen aqualand duplex watch has the word "chek" on the lower screen and it won't go away. What does this mean?
It turns to "chek" if the moisture sensor that triggers dive mode when you go in the water is exposed to water and you don't dive for more than an hour. The sensor is very easily triggered by sweat, so all you got to do is wipe the sensor between the crown and the upper right button with dry cloth and "chek" will go away.
Feb 21, 2011 | Citizen Aqualand Duplex JP104009E Wrist...
I have a citizen promaster watch that let in water the main module is now us citizen says it needs a new module but it is very expensive any ideas where i can buy module?
mcdevito 75 here, I understand by your question, Citizen itself says you need a new module, did they see and examine your watch? if so then your stuck, if not, the watch may be able to be dried out but you"ll have to remove the module from the watch. Best bet, look for a small watch repair shop in your area, have them remove the module and see if it can be dried out.
Aug 07, 2010 | Citizen Aqualand Duplex JP104009E Wrist...
I have an aqualand duplex and the protective glass is
HI
So is the glass cracked? or do you have an watch protector on it which is broken (usually a rubbery type protector which slips on over the glass)?
Kind Regards
Shenlun
Jul 12, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
Battery Number for Citizen Diver's Watch
Energizer 371/370 It uses 3 of them. Careful when opening. Make sure you put the screws back tightly. unit has a gasket. lightly treat with vasline before putting back gasket and screwing cover on.
May 03, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
Citzen Aqualand 1997 Divers watch..Great condition!!
the alarm works by a spring rubing on the back of the base plate of the watch if this spring is bent or not in the right place the alarm will not work
Nov 02, 2008 | Citizen Aqualand Duplex JP104009E Wrist...
Mar 10, 2008 | Citizen Aqualand Duplex JP104009E Wrist...
Old Citizen Divers watch
Found this on the web for fixing Citizen dive watches:
http://www.hurleyrobertsservice.com/v2/web/index.php
You can also buy new and older ones at Ebay.com and Nextag
for around 250 USD. Might be easier/cheaper than fixing old ones.
Jan 10, 2008 | Citizen Aqualand Duplex JP104009E Wrist...
Instruction manual
Dec 05, 2007 | Citizen Aqualand Duplex JP104009E Wrist...
Watches Logo
117 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
