Hold to start button stuck - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
If the button itself is stuck, and not the actual switch inside you could get some WD 40 or CRC spray and lubricate it from the front. Then try to exercise it to move freely. If, however, the button is connected directly to an internal switch, the panel will have to be opened to see if the contacts are welded or corroded. If they are, the switch needs to be replaced!
Posted on Jan 11, 2013
My ipad is stucked.
This tutorial will explain how to force your iPad to restart if it gets stuck or freezes up.
Forcing your iPad to restart will not cause any loss of data - with the possible exception of any work you were doing at the time the iPad and/or App froze, forcing you to restart it.
Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom). Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
Feb 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
How to perform key stuck closed button test
To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink
Aug 14, 2012 | Frigidaire Electric Dryer
Android vimicro logo stuck on screen
ANDROID Tablet Freezes at Android startup screen
For Superpad VI - 10.1" Android Version 4.03, this worked for me!
1. Press & hold START button
2. When "VIMICRO" appears, Then Press & Hold the MENU button
3. The Android System Recovery <3e> Menu should appear
4. Scroll down using the Volume Key to "wipe data/factory reset"
5. Press HOME Button
6. Scroll down to "Yes - delete all user data"
7. Press the HOME Button
At this point the system will do a recovery and hard start, and will be on "reboot system now
8.Press the HOME Button
Your system should reboot normally, but you will need to enter all new data, as it has been wiped clean.
Apr 03, 2012 | Tablets & eReaders
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
Oct 08, 2011 | Maytag MDB7100AWB Dishwasher
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Just makes a buzzing sound when you turn the start button on.
that is the motor!try this,open the door,with one hand push in the door switch button and hold it in,as you hold in the button spin the drum with your other hand and have someone else push the start button and see if it starts,if it does you have a bad motor,if the drum doesn't spin by hand you could have something stuck in the blower wheel,let me know what you find
Feb 05, 2011 | Frigidaire FEQ1442ES Electric Dryer
A dvd has become stuck in my macbook and when i reboot, the screen remains blank and will not start up
If it is physically stuck, you will need to take it in for service.
If you just need to eject it, hold down the eject button or the trackpad button as you power on and continue to hold it down until the disc ejects.
Dec 29, 2010 | Apple MacBook Pro Laptop Computer with...
I tried to reboot my iphone and when it started up its just stuck at the Edit Home Screen. I'm unable to dismiss the screen and move on. Its just stuck. Pls help
Hold down the power button on top and the circle button for about 30 seconds or more. Hold them both down until it reboots and you see the apple.
Oct 19, 2010 | Apple iPhone Smartphone
Iphone 3g 3.0 stuck on iphone apple logo loading screen
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Aug 27, 2009 | Apple iPhone Smartphone
TV Stuck in Demo mode
In the tv and with the set turned on press and hold the ACTION and CHANNEL UP buttons at the same time for more than 5 secons.Let Us know how it goes.
Oct 16, 2006 | Panasonic CT-34WX54 34" TV
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
