Question about Desa International Blower Glow Warm Wall Heater
Motion Sensor Light won't come on but works fine on "Test"
I have a Desa Motion Sensor light that has worked fine for 5 years now. We thought a light had burned out so we replaced it but now it won't come. We put it to the "Test positon and both lights work fine. Then we set it to "Dawn to Dusk" and "Max" position for "5" minutes. Exactly where it was before the bulb burnt out.
However, we have tried everything and it simply doesn't come on anymore.
  • belindablack Jan 25, 2009
    I do have the same problem. Purchased two lights for each side of my front door in spring 2006. Thought light bulb had burned out, but won't come on at all, even in Test position. I have looked at the manual which came with my lights and can't figure it out. Don't want to have to purchase two more lights so that they will match. They are Portfolio lights from Lowe's, but the manual tells me to go to "desatech.com" for more information, but that website doesn't even show any lighting fixtures. HELPP!
  • 3 Answers
Found this link to the owners manuel
http://12.153.20.74/manuals/124011-01B.PDF
Posted on Feb 05, 2009
  • rondnor Nov 07, 2010
    you will find the manual herehttp://www.heath-zenith.com/servsup_manu...
    you need to reset the lights by turning it off for one minute and then switching it to on. Toggling the lights on and off moves it from Auto to manual and thus the problem. good luck.
Why is the LED light completely off after the walk test and lockout time?
Yes, it works normally. Things have evolved in the technology of security systems and now it is standard to have any LED turned off on any motion detector (the LED's are now used for walk-testing only), the standard DSC and Honeywell wireless motions also do the same thing.
  • This is a normal function for your motion detector. It's also a great power saving function since most of the current draw on the batteries is when it's transmitting a detection signal so if you're home and moving around it will only transmit every few minutes instead of every second, saving on battery life significantly (up to 5 years on average) but after the 3-minute lockout the passive infrared scans continuously until it transmits another motion signal.
Reason: most burglaries are done by someone who has been there before, if they see the LED then they know the motion will catch them moving in that given spot, then they can "map-out" where it's safe to walk (where the LED doesn't light up) for when they plan to return for a robbery.
You can also make this device "more sensitive" by moving the jumper pin position by the right side battery and having the back mounting plate mounted using the bottom screw presets so it faces slightly downward instead of straight forward.
Helpful tip: Change the batteries every 4 years if you're using Alkaline (dead or not) since the detector was engineered "too energy efficient" and the batteries actually leak and corrode the interior PCB at about the 5-year point on about 15% of the detectors with factory original duracell batteries (from what I've experienced in field service).
Apr 06, 2015 | Interlogix GE SAW Wireless Indoor PIR...
I have motion sensor flood lights that are not turning on. I put it on test & it does turn on. But when switched over to 1, 5 or ten minutes it won't turn on. The red light on the sensor does turn
April, you didn't mention whether you did the test at night. In addition to motion sensing, the flood light also detects darkness before allowing the bulbs to light up. If it is night, check also that some other light source is not illuminating the sensor. If so, that could fool the sensor into thinking it is daytime.
Mar 03, 2014 | Electrical Supplies
My journeyman motion light just quit working for no reason. The bubls are good. As mention it was working fine then just stop working. What could be the problem?
The motion sensor unit shorted to due to rainwater infiltration, if its like the last half-dozen motion sensor units I opened up. Take the unit down, open up the sensor unit head, and if its got moisture inside, you know why it quit. If not moisture, then they sometimes do what all electronic devices eventually do, they fail due to 1 of the components reaching its failure - every sensor has an MTBF
(mean time between failure).
Jan 05, 2011 | Heath Zenith Journeyman 270 Degree Motion...
Model 5316-A lights do not turn on even when there is motion in the area of the lights. Red light is blicking, The lights do turn on in test mode.
Sounds like a problem I had recently where the sensor was detecting it's own light and shutting off thinking it was daylight. I repointed the lights a bit and it resumed working normally.
The problem is described on page 4 of the manual: http://heath-zenith.hcents.com/data/manuals/595-5109-13.pdf
Oct 27, 2009 | Desa International 240 Deg. White Twin 150...
Put light in test mode, it works great. Put in 2 min or 5 min setting and it won't come on at all. What's the deal?
Could be similar to a problem I had recently where the daylight sensor was being triggered by the light itself. Try re-pointing either sensor or light to keep the sensor in the dark when the lights are on...
Oct 26, 2009 | Desa International 240 Deg. White Twin 150...
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Motion sensor light stay on
Hi, You don't say what the make or model is, so I will give you the best advice I can. Most motion sensor lights today have a switch or two on them for "on", "test" and then some time like 3 minutes, or 5 minutes. The switch is tiny so it or they are easy to overlook. The "on" position will keep the light on all of the time. The test position does different things on different models but you will want one of the time settings. If this doesn't work for you get back to me with a little more info and we'll keep on it. Good Luck!
Feb 06, 2009 | APC Electrical Supplies
Desa International Blower Glow Warm Wall Heater Logo
2,331 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
