Question about Fisher Paykel Fisher & Paykel AquaSmart WL42T26DW1 25" Top-Load Washer with 3.1 cu. ft. Capacity, 7 Wash Cycles, Load Sensing, Dual Washing Modes, 3 Dispensers, Auto-lint Disposal, Smart Drive System and LED Control Panel
Fisher and Pakel WL26CW1 code 246
Code 246
Fault code 9 fisher and paykel
With the board replacement, did you program this board for this unit? If not, thats the problem you have now. Good Luck
Aug 04, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Fisher and paykel washer
Here is the service manual.
Start on page 35 to get to "Settings menu" and read thru to page 37 (scroll down to factory default).
Fisher and Paykel WL26CW1 Manual
Hope this helps to reset the machine.
Aug 03, 2014 | Fisher and Paykel Washing Machines
Fisher & Paykel WL26CW1 - Error Code 49! can i swap the hot and cold valves to make it work and disconect the hot valve?? and love this site very informative, Thanx Guys..
The most common problem with AquaSmart is the pump
not the water valves
The pump has gone bad and blown some parts in the motor controller board and the fuse to the water valves.
Some AquaSmart machines display the wrong Error code (49)
witch is not the correct code for this problem.
Pump and motor controller board need replacing.
Maybe cheaper to buy a good secondhand machine.
Mar 19, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
Replaced computer in fisher and pakel top loading washer and still does not work. what is wrong??
does it beep at you? is it dead? if some lights are on while it's beeping, they are an error code, can you relay them to me?
Oct 11, 2013 | Fisher and Paykel Washing Machines
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Fisher & Paykel AquaSmart WL42T26DW1 25" Top-Load Washer with 3.1 cu. ft. Capacity, 7 Wash Cycles, Load Sensing, Dual Washing Modes, 3 Dispensers, Auto-lint Disposal, Smart Drive System and LED Control Panel Logo
37 people viewed this question
Top Fisher Paykel Washing Machines Experts
marlin siecinski
Greg Stephen
Greg Stephen
Paul P
Are you a Fisher Paykel Washing Machine Expert? Answer questions, earn points and help others
