Question about Executone IDS 42 EXPANSION CABINET (23200) Serial Adapter
Ids 42 port configuration
Need to find Owner's Manual to setup system properly. Specifically the IDS 42 Port Configuration software menus, and options. I have the software installed and it can recognize the hardware, but I don't have the settings to properly setup the system.
Port forwarding
In your router's setup menus, click Advanced Setup, then click NAT, then click Virtual Servers.
That's the port-forwarding configuration page for Primatel routers.
Feb 10, 2014 | Computers & Internet
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
HOW DO WE open the port of this modem
Outgoing traffic isn't blocked normally on routers unless someone specifically blocks them in the configuration menu.
Dec 02, 2012 | Computers & Internet
Asus p5gc-mx erorr on all usb port, sometimes on bootscreen appear text 'usb port error' system will automaticly shutdown' help please
Hi again newbie7,
1.enter your bios setup >>> Advance >>> Usb Configuration >>> USB Controller mode >>> HiSpeed
2.enter Chipset section >>> Southbridge Configurations >>> Usb 2.0 Controller >>> Disable
3.save and exit
If problems exist,ask me for more
akee_akee@live.com
Aug 16, 2011 | ASUS P5GC-MX/1333 Motherboard
Why is is there is no internet connection using d-link router? i already installed it. but the internet cable has an absolute connection. but when i connect it to the d-link router, it says, no internet...
hi my name is rui here is a guide in properly installing you router.
Before you begin any installation project, always make sure you have all of the parts that are supposed to be in the box. Normally, you will have the router, an installation disk, an Ethernet cable and a power adapter for the router. If anything is missing, be sure to return the router and get a replacement.
D-Link Router Setup- Courtesy D-Link
To begin, plug the router into the wall using the power adapter that came with it. You should see the D-link's Power LED turn on. You'll next want to make sure your cable or DSL modem is unplugged. Next, you will take the Ethernet cable that came with your D-Link router and plug that into the WAN port in the back of the unit. The other end of the cable will go directly to the modem's Ethernet port.
Power up both the cable or DSL modem and the router by plugging them back in. The modem may have a power button you need to press. Both units should have green lights. You should see the activity light on the modem flashing, and the WAN port on the router blinking, as well. This indicated activity and communication between the two. The modem is sending IP information to the router.
Depending on your computer and router, you may automatically be able to connect wirelessly to yuor new router to begin configuration. However, it may be necessary to patch into the router with a nearby computer via an Ethernet cable, which will plug into the LAN port. Whichever method you use, you'll need to reboot the computer.
To configure the D-Link router, you will next need to open a web browser and type http://192.168.0.1
You should see the administration screen of the D-link router. Type in admin and leave the password filed blank.
A setup wizard should appear, prompting you to first change the router's password. Pick something you can remember.
You will next have to setup a time zone, you will then be given option as to how the router will handle IP address on the network. Most users will opt for the Dynamic option, which means the router will act as a DHCP server and supply all computers on the network with an IP address. If you select DHCP, you will need to Clone the IP address of the machine your ISP has already had contact with. For instance, if your ISP has been giving IP address to a certain computer before you put the router between them, you will need to clone the MAC address of that machine.
If you opted for Static IP Addresses, you will be brought to a screen that you will need to contact the ISP to get IP numbers from.
You will next need to setup the wireless connection. You will change the default SSID to match the workgroup ID of your LAN computers. The SSID and the Workgroup IDs must match. You will also be able to configure encryption at this point. If you have the ability to use the newer WPA encryption, you will want to use this. But we don't recommend setting up encryption until you confirm that all PCs are able to connect properly.
Lastly, you will be asked to reboot the router.
Jul 21, 2011 | D-Link Wireless N 150 Home Router 4Port...
I'm not getting communication from the RS-232. Is there a setup I need to do or something?
To setup connection first find serial settings by:
Hold feed button whilst switching on label, will then print configuration and do a calibrate.
from the configuration print find settings for serial port format is something like " Serial port : 9600, N, 8, 1 "
set your PC to the same settings. This should work just fine.
Jun 18, 2011 | Zebra TLP 2844-Z Thermal Label Printer
I can't get email to connect. It doesn't seem to like the selected port number (995). This is for a new archos 7 home tablet
When setting up email each provider has its own configuration. It would help to know specifically what provider you are trying to setup. Port 995 is usually designated for a secure connection. Most providers do not support this kind of configuration unless under very specific circumstances. Try using port 465 for SMTP. Let me know if that helps, and be sure to respond with your provider info as well.
Good Luck,
NOLA Tech
Feb 08, 2011 | Computers & Internet
Security device not found wilcom help me
dear sir /madam
i have taken a new dual core 64 bit motherboard computer but my wilcom softare version is not installing it is showing me the error that SECURITY DEVICE NOT FOUND what should i do in that case plz help me my id is
thisis_vits@yahoo.com
Aug 24, 2009 | Computers & Internet
I don't no how to hook up my Adsl Gateway
See if maybe this will help. You didn't say what type of router(wired or wireless). Yhis should give you some idea. Hope this helps. Thanks
LinkSys Router Setup Physical Setup of a LinkSys Router Each model of LinkSys router will differ slightly, but the general design is similar across all models. Therefore, the setup is similar across all models.
  1. Attach the antennas to the router (if your LinkSys router support wireless)d
  2. Plug the Ethernet cable from your broadband Internet provider into the port labeled "Internet"
  3. Plug another Ethernet cable into one of the available ports
  4. Plug the other end of that same cable into an Ethernet port on your PC
LinkSys Router Configuration LinkSys routers now ship with a Setup Wizard which is intended to simplfy basic configuration tasks.
We do not recommend the LinkSys Setup Wizard for two reasons:
  1. The Setup Wizard is not significantly easier that the regular configuration menus
  2. If you use the Setup Wizard, you will end up learning two interfaces for your LikSys router instead of just one
Instead, we recommend simply starting your web browser and jumping into the configuration.
Once your web browser is open, go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password.
Logging in to a LinkSys Router
The username is either blank or "admin" and the default password is "admin".
Once you are past the login screen, you are able to access (and change) a plethora of configuration options for your router.
Don't be worried by the enormous number and variety of options, your LinkSys router ships with default settings that enable it to work right out of the box in most environments.
From here the configuration options that you choose are largely up to your own personal preference.
If this is a wireless router, we recommend that you consider setting an SSID to identify the router as your own and configuring WEP to encrypt your wireless traffic.
Feb 18, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I need a driver for a digital video recorder camera. the model is sony dcr-trv10.
Sony's website says: "Some digital camcorders must be setup to output a signal through the i.LINK® port prior to being connected to a computer. Consult the instruction manual of your camcorder for specific information before continuing with the steps in this solution. Instruction manuals are available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Ensure the i.LINK cable is connected securely to the camcorder and computer.
  2. Ensure the camcorder is turned on and being powered by the supplied AC power adapter.
  3. Ensure the video capture card and software are configured properly to receive the i.LINK signal from the camcorder.
  4. NOTES:
    • Depending on the video capture card and software you are using, you may need to manually configure the capture card and software to receive a signal from the i.LINK port. If applicable, check the Help files of the software or contact the video capture card or software manufacturer for further information.
    • Sony® digital camcorders are not provided with and do not require special device drivers for i.LINK connectivity. The device drivers that allow i.LINK connectivity should be provided with the video capture software. If the software you are using does not appear to have the required drivers, you will need to contact the software manufacturer.
Likely this is the case where the camcorder needs to be setup in order to connect to the Firewire port. This is done inside the menus. Windows XP and Windows Vista will detect a camcorder connected to a Firewire port automatically. Make sure your camcorder is powered up and configured before connecting it. Does your PC have a Firewire port? Many do not, PCI cards with firewire ports can be bought online or from local retailers. Some sound cards come equipped with one.
Nov 18, 2007 | Sony Handycam DCR-TRV110 Camcorder
Executone IDS 42 EXPANSION CABINET (23200) Serial Adapter Logo
24 people viewed this question
Top Executone Computers & Internet Experts
David Payne
David Payne
Are you an Executone Computer and Internet Expert? Answer questions, earn points and help others
