Question about JVC AM FM CD DET FACE CAR STEREO
Amplifier Issues hey i have a sony 500 watt amp and for some reason it keeps getting hot and shutting off really fast if i turn it up... if i keep it down it works fine but as soon as i proceed to turn up the volume it will last a minute or two and shut off. then the amp will not return to its normal state until the truck is shut off and turned back on.( im assuming letting the amp reset.) i had the amp in a different car before and it worked fine. i could crank it all day and it was cool... what do i do!?!?!
  • 2 more comments
  • chuck4sho Jan 21, 2009
    it is a sony x-plod XM-504z amp on a chip foose arc audio 10".
    i think it is a dual voice coil....
  • blueextc3221
    blueextc3221 May 11, 2010
    dual or single voicecoil?
  • blueextc3221
    please reply with the speakers attached to the amplifier and the model # of the amplifier so I can be of some assistance.
  • 15,935 Answers
HERE is the manual for your amplifier.
It is listed as being 4ohm STEREO stable Bridged.
Meaning the lowest impedence possible on (2) bridged channels is 4 ohms.
If you have a Dual Voicecoil Subwoofer, chances are - it is wired in parallel - resulting in a 2 ohm load.
This low resistance causes rapid heat buildup, and is causing your amplifier to go into protect mode.
There are many reasons the amplifier is doing it NOW as opposed to the prior vehicle...
If you alternator is not giving your amplifier 14V, it must work harder to produce the same amount of power. WORK = HEAT!
If the head unit is not the same, the signal voltage also has an effect. If the voltage is lower, the amplifier has to work harder to keep up at the same "volume" setting.
In any case, you are over-driving the amplifier, and it is shutting down with its thermal protection circuit.
Either lower the gain on the amplifier, or purchas a mono channel amplifier made to drive subwoofers.
Your Subwoofer is craving power, and you're giving it 60W !!
Thank you for using FiXyA - A FiXyA rating is appreciated.
If you have more questions or need clarification - let me know!
Posted on Jan 21, 2009
Will the amp blow my speakers?
If you bridge the amp and get 1000 watts RMS and that is split going to two speakers then you will get 500 watts RMS at each speaker. If you have your amplifier on maximum gain it may blow your speakers, not because they are overpowered but because you might run into "clipping" issues running the amp at maximum capacity. Just to be safe I would dial the amp's gain down to 3/4 of the way to full gain. That should give you ample power and keep your amp from clipping and running hot.
Aug 11, 2015 | MTX Car Audio & Video
My amp cuts out when it gets really hot. any reason why it would cut out or get real hot. is it cuz i have it hooked from the battery that powers the car too should i get a bigger battery or a second...
I had a Pioneer amp that did this too. There is no easy fix to it. Just try to keep it cool.
It shuts itself down when it gets to hot so it doesn't have a catastrophic failure. (melt)
There shouldn't be any issues with being wired to your car battery.
Make sure its got plenty of open space(if possible) add a fan maybe.
Or take some of the load off of it by 1. Adding an amp. 2. Turn it down
I would take option 1 You have the amp so you can turn it up in the first place
Good luck
Dec 09, 2010 | Jl Audio 1000/1 Car Audio Amplifier
I have an spl 1440 watt amp model st2-1440 that i cant get to turn on without 15 volts to the remote wire and then it gets really hot really fast. Any ideas why or how to fix it?
Generally a battery puts out 14.1 volts to the amplifier. The only way your amp would get really hot really fast is if the amp was configured to run at to low of an ohm load.
That amps spec is to run at 2 ohm stereo. But I do see an option to get 1400 watts with 2 ohm mono, but that would require 2 dual 2 ohm subs using only one voice coil bridged to the amp. If you run both subs with both voice coils in parallel you'll get a 1 ohm load and that will overheat your amp.
Reference: http://www.sweetwater.com/forums/archive/index.php/t-2193.html
Ohms are the units that impedance is measured with. You can kind of think of impedance as the measure of how hard the amp has to push to get current to flow. The lower the impedance, the more power will be output from your amp. Unfortunately, the amplifier circuit wants to push against something, so that if the impedance is too low, the amp can perform badly, and even overheat and burn out.
Hope this helps!
Aug 01, 2010 | Car Audio & Video
Amplifier turns off for no reason...while driving. If I restart the car it works again. Turn on lead is still hot (12V) when I test it and yet the amplifier just cuts out for no reason.
if your amp keeps shutting off, it means that you r overworking it, and it's getting hot without minimal time to cool off. my solution is, and i've done this. i bought four mini fans and wired them to the heat vents, two of them to the vents on one side to **** in cool air, and the other two on the opposite to **** out the hot air. this does work, and keeps your amp cool, or buy an amp that comes equipped with a built in fan, you may pay alittle more, as they say you get what you pay for. hopes this works for you
Feb 10, 2010 | Alpine Car Audio & Video
Amp turns off.
your drawing/pulling too many amps. Is it a mono(one speaker), two way(two speakers/can be briged to one), or a four way(four speakers/can be brigrd to two). don't put too many speaker to that one amp if it's only a mono, or a two way.
Sep 24, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Keeps shutting off at the lowest volume setting.
Check the switch wire connection. It's the one that turns the amp on when you turn the head unit on.
Jun 02, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I have a crown ce 2000 watt amp. channel 2 keeps turning off
Do you get any Fault indications?
Have you swapped the speakers around to eliminate them as external causes?
When the channel dies is the unit very hot and is the fan turning very fast (it should be if hot)? The fan could be defective, slow or airflow may be restricted.
Turn the amp off and examine the fan guard on the rear to make sure it is clear of dust and debris. Vacuum it out if necessary. With a small thin non-metalic object reach in and test the fan for free movement by trying to rotate it. It should coast.
Apr 27, 2009 | Crown CE2000 2-Channel Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
Amp overheating
wire size depends on source, not load capability. your amp can provide 500 watts, so gage should be about 8, provided your speakers are 2 ohms each... you can measure them with ohmmeter. If you have 4 or 8 ohm speakers, you should get impedance matching transformers. Also, you should use a supply capacitor on power feed to amp of about 10 Farads...these are large and not cheap, but they provide "backup" power for heavy bass loads.
Jun 08, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
JVC AM FM CD DET FACE CAR STEREO Logo
117 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
