Maintenance required message - Office Equipment & Supplies
  • 35 Answers
Most office equipment has that. when you replace your drum assembly, it resets a counter. It is possible that it will still work for some time. Good idea to think about getting a new one now because it could go out soon.
Posted on Jan 11, 2013
Need help for maintenance on Sharp AR208D copier
It is time to call the telephone number and request maintenance. When the copier gives you a message that it needs maintenance, the machine needs a trained technician to perform maintenance on it. Don't just keep using the copier as you can permanently damage the machine.
Aug 05, 2014 | Sharp AR-208D Printer
Perform printer maintenance message
You need to follow the instructions given in the LaserJet 4300 User Guide which can be found at http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=84041&targetPage=http%3A%2F%2Fbizsupport1.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fbpl12546%2Fbpl12546.pdf - go to page 93 of the PDF which describes how to "Perform preventative maintenance". . . The message you are seeing occurs after 200,000 pages have been printed and may require you to purchase and install a new printer maintenance kit to solve the problem.
Dec 22, 2011 | HP LaserJet 4300 Printer
Maintenance Required message on. Purchased
this light can come on even thought service is not actually due. if the service was performed and the light was not on at the time, sometimes you cannot reset them if they are not actually lit, or 99% of the time the technician forgets if the light was not on. stop by your shop and they can reset it for you in just a few moments, and for no charge. good luck!
May 06, 2010 | 2007 Lexus RX 350 FWD
How do I reset the maintenance required message on
With ignition off, press and hold "SELECT" and "RESET" buttons on dash and turn ignition to the "ON" position. Continue to hold until lamp resets.
Dec 15, 2009 | 2005 Acura RL
What is "Maintenance required. Code: AA"
Maintenance timing display The message of maintenance execution timing is displayed when each counter reaches the set value. The relationship between the messages and the counters is shown blow. Maintenance counter AA WhenThe maintenance counters (both of total and color) reaches 90% of the set value of SIM21-1 (When the setting of SIM26-38 is ?print stop?). When The maintenance counters (both of total and color) reaches the set value of SIM21-1 (When the setting of SIM26-38 is ?print allowing?). Enable ? After completion of the maintenance, execute SIM 24-4 (Maintenance counters (total, color) clear).
Aug 29, 2009 | Sharp MX-2700N Color Copier
Ar 5631 showing maintenance required error
Press the :
( #/P ) key --> ( * ) key --> ( clear ) key --> ( * ) key
reset the maintenance counter: 24 start --> 4 start
Apr 07, 2009 | Sharp AR-5316 Advanced Digital Imager...
Read the Manual that came with the car. It will tell you how to turn the maintenance signal off. Cant remember, been a while since ive done it. But i know 100% its in the manual.
Feb 23, 2009 | 2003 Infiniti FX35
Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
We have a Phaser 8560 Printer and we are getting the message "maintenance kit low" message. What does this mean and how do we fix it?
This will require servicing:
The maintenance kit contains a maintenance roller that keeps the surface of the Imaging Drum clean and oiled.
NOTE: Order a new maintenance kit when the Display Screen displays a message that the maintenance kit is low. Replace the kit when the Display Screen prompts you to replace the maintenance kit. Both a Standard Maintenance Kit and an Extended Maintenance Kit are available for the Phaser 8550 and 8560; however, only a Standard Maintenance Kit is available for the Phaser 8500. An Extended Maintenance Kit will not be functional with the Phaser 8500.
WARNING: The printer's interior may be hot! Do not touch the hot surfaces.
Once you have the part: instructions:
  1. Open the door on the right side of the printer.
  2. Grasp the maintenance kit (labeled A) from the maintenance kit slot and pull the kit completely out of the printer.
  3. Insert a new maintenance kit and push the kit completely into the maintenance kit slot. Follow the illustrated instructions included with the maintenance kit for full installation and disposal information.
  4. Close the door.
This will be on the right side of the printer.
This will need to be replace every 10,000 sheets of paper.
  1. Close the door.
Apr 03, 2008 | Office Equipment & Supplies
13 people viewed this question
k24674
jasbo
jasbo
