Question about Engines & Components for Hyundai Accent
Hyunday 2003 1.5 head and rockers rack bolts torque
    Champion:
    Scholar:
  • 227 Answers
For 1.5L engines head bolts, tighten the bolts 51-54 ft. lbs. Start at the top bolt on the transmission side of the engine, next one will be the very front bolt at the bottom of the engine, then go back to the bottom bolt at the transmission side of the engine and do the same for all the remaining bolts until you finally tighten the middle two bolts.
I like to go over all the bolts one more time just to be sure they all remaine tight, sometimes you find one that worked loose.
Posted on Nov 01, 2013
Torque specs 2003 olds silhouette rocker arm 3.400
Here is a suggested updated torque spec for this engine's rocker arm bolts;
Rocker arms
Step one: Torque to 11 ft lbs then tighten an additional 90 degrees of bolt head rotation. Some guys don't fuss with the torque specs and just get them good and tight. Either way, be careful, as the heads are aluminum. You do not want to over tighten these bolts
Oct 07, 2016 | 2003 Oldsmobile Silhouette
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
Rocker arm pivot torque for olds cutlass 1987 307
Oldsmobile Torque Specs - GbodyOlds.com
www.gbodyolds.com/forum/showthread.php?754-Oldsmobile-Torque...
Feb 7, 2013 - 2 posts - ‎2 authors Oldsmobile Small-Block Engines Cylinder Head Bolts (1/2in. bolt) 130 ft. lbs. Cylinder Head ... Rocker Arm Pivot Bolt 25 ft. lbs. Rod Bearing ...
Rocker Arms - AutoZone
www.autozone.com/...Cutlass...1987.../Rocker-Arms/_/P-0900...
AutoZoneGM Cutlass RWD 1970-1987 Repair Guide ... To remove the rocker arms from the shaft, the nylon arm retainers must be removed. ... 7: Engine valve system, 260, 307, 350, 403 Oldsmobile built engines ... Unfasten the two bolts that attach the rocker arm pivot to the cylinder head. ... Torque the retaining bolts to 25 ft. lbs.
Dec 01, 2015 | 1987 Oldsmobile Cutlass Salon
Torque specs for rocker arms
The 12mm head bolts torque to 15 ftlbs.
the 10mm head bolts torque to 9 ftlbs.
crosshatch pattern for the sequence.
Jul 02, 2014 | 1992 Honda Accord
Torque specification on a 2003 alero cylinder heads 3.4 liter
3.4L Engine To Remove:
  1. Remove the lower intake manifold.
  2. Remove the exhaust crossover pipe.
  3. If removing the right cylinder head, remove the catalytic converter from exhaust manifold.
  4. If removing the left cylinder head, remove the engine oil dipstick and tube.
  5. Remove the rocker arms and pushrods.
  6. Remove and discard the cylinder head bolts.
  7. Remove the cylinder head.
  8. Clean the mating surfaces on the following items:
    • Cylinder head
    • Cylinder block
    • Intake manifold
  9. Clean the cylinder block bolt threads.
NOTE: During disassembly, keep the valve train components together for proper location during assembly.
To Install:
NOTE: Coat the cylinder head bolt threads using thread sealer.
  1. If removed, install the following components:
    • Exhaust manifold
    • Accessory studs
    • Spark plugs
  2. Place the cylinder head gasket in position over the dowel pins. Ensure that the THIS SIDE UP note is showing.
  3. Install the cylinder head. Cylinder head torque sequence ’99-‘00 gmpc_v6_14.gif
  4. Install the new cylinder head bolts.
    • Tighten the cylinder head bolts a first pass to 44 ft lb (60 Nm).
  5. Tighten the cylinder head bolts in sequence an additional 95 degrees.
  6. Install the intake gasket.
  7. Install the pushrods and rocker arms.
  8. Raise and support the vehicle.
  9. Install the catalytic converter and dipstick tube and indicator if removed.
  10. Lower the vehicle.
  11. Install the exhaust crossover pipe.
  12. Install the intake manifolds.
  13. Connect negative battery cable.
  14. Fill the cooling system.
Jul 03, 2010 | 2003 Oldsmobile Alero
I need the engine torque specs for 99 chevy malibu. like the head bolt torque sequence and rocker bolt torque sequence
99 chevy malibu v6 3.1 engine, head bolt torque is-- 98 through 2001 is step1- 37 foot lbs, step 2- rotate an additional 90 degrees (1/4 turn). the rocker arm bolts are 168-in. lbs.
Mar 12, 2010 | 1999 Chevrolet Malibu
I need rocker torque for 2003 pontiac with 3.1liter
Left side:
To install:
  1. Lubricate all the valvetrain components with engine oil.
  2. Install or connect the following:
    • Pushrods and the rocker arms and tighten the bolts to 14 ft. lbs. (19 Nm) plus 30 degrees
    • Rocker arm cover using a new gasket and tighten the rocker cover bolts to 89 inch lbs. (10 Nm)
    • PCV valve to the rocker arm cover
    • Coolant tube with the thermostat bypass hose and tighten the bolt to 98 inch lbs. (11 Nm) and the nut to 18 ft. lbs. (25 Nm)
    • AIR check valve pipe and torque the adapters to 22 ft. lbs. (30 Nm)
    • Engine mount strut and torque the bolt to 35 ft. lbs. (48 Nm)
    • Spark plug wires
    • Negative battery cable
Right side:
To install:
  1. Lubricate all the valve train components with engine oil.
    • Power brake booster vacuum pipe to the plenum
    • EVAP solenoid and ignition coil assembly
    • Spark plug wires
    • Alternator bracket and torque the bolts to 37 ft. lbs. (50 Nm)
    • Alternator and torque the bolts to 37 ft. lbs. (50 Nm)
    • Accessory drive belt
  3. Start the vehicle and verify no leaks.
Feb 06, 2010 | 2003 Pontiac Grand Prix
Blown head gaskit need to remove head and replace with new ong
2.2L (VIN 4) Engine
  1. Before servicing the vehicle, refer to the precautions section.
  2. Relieve the fuel system pressure.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • Air cleaner outlet duct
    • Engine mount
    • Intake manifold
    • Exhaust manifold
    • Engine Coolant Temperature (ECT) sensor electrical connector
    • Power steering pump
    • Radiator inlet pipe
    • Spark plug wires
    • Rocker arm cover
    NOTE Whenever valve train components are removed, keep them in order for installation purposes.
    • Rocker arms and pushrods
    • Lifters
    • Alternator rear brace and the alternator
    • Ignition coil assembly
    • Accessory bracket
    • Spark plug wires
    • Cylinder head bolts
    WARNING Two sizes of bolts are used; note the location of each.
    • Cylinder head
  5. Inspect the cylinder head and block surface for cracks, nicks, heavy scratches and flatness.
Cylinder head torquing sequence—2.2L (VIN 4) engine
  1. Install or connect the following:
    • Cylinder head with a new gasket and new cylinder head bolts. Torque the long bolts, in sequence to 46 ft. lbs. (63 Nm) and the short bolts to 43 ft. lbs. (58 Nm) plus an additional 90 degree turn on all the bolts.
    • Lifters
    • Pushrods and rocker arms. Torque nuts to 22 ft. lbs. (30 Nm).
    • Rocker arm cover. Torque the bolts to 89 inch lbs. (10 Nm).
    • Spark plug wires
    • Accessory bracket
    • Power steering pump. Torque the bolts to 22 ft. lbs. (30 Nm).
    • ECT sensor electrical connector
    • Exhaust manifold. Torque the nuts to 118 inch lbs. (13 Nm).
    • Alternator. Torque the bolts to 37 ft. lbs. (50 Nm).
    • Intake manifold. Torque the bolts to 17 ft. lbs. (24 Nm).
    • Engine mount. Torque the bolts to 55 ft. lbs. (75 Nm).
  2. Refill and bleed the cooling system.
  3. Start the vehicle and inspect for leaks.
Oct 08, 2009 | 2000 Chevrolet Cavalier
Need torque specs
I presume that you are connecting your Intake manifold to the cylinder head after replacing your intake gasket, if so they are 30ft lbs, and 360 in pounds. Hope that helps
Jan 31, 2009 | 2003 Chevrolet Venture Passanger
Engines & Components for Hyundai Accent Logo
63 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
