Question about Acer TravelMate 2300 Notebook
Cracked front cover at hinges
I have had my acer 3610 for a year and a half now, and at the hinge on the front of my laptop there is a large crack that just continues to grow, the more I use it.
Is anyone else having this problem?? Acer Travel Mate 7510
Same problem, left hand hinge is gone - I hate it that you spend good money and then no return! The screws are soooo tight, the cover casing has cracked round the hole and now I can't shut it, and i need to do a presentation tomorrow, but how can it travel open?
Even the few postings here should alert Acer that there is a common theme! These big companies are so untouchable.......i wonder if trading standards would take them on in the UK?
Broken left hinge on my Acer Aspire 7100 laptop
do an ebay search you might be lucky.
AndystUK
Aug 30, 2009 | Acer Aspire 3610 Notebook
Acer laptop crack at the back of LCD near the hinges.
In my experience, I have been able to replace the LCD Bezel to fix the crack. You can order this from any online parts store if you are a Do-It-Yourself type or any computer support company could help. Good Luck
Frank
Jul 27, 2009 | Acer Extensa 503T Notebook
The cover broke at the left hinge, lifting it from the base
u could buy a new screen or mayby for a quick soluition u could super gule it but i got no other ideas
Jun 24, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 9410 z cracked cover around Left hinge
Try a Google search on the Internet for parts for your Acer.
Also try this WEB site for parts.
Use this link.
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=2839
Jun 14, 2009 | Acer Aspire 3610 Notebook
Cracks near hinge Acer 3613 laptop
Apply a lubricant to the hinges themselves - not a ton of lubricant, as you don't want anything running down into the laptop proper.
What sound like has happened is that the display has somehow been in a bind, and therefore the hinges are in a bind. This makes it harder to moved the hinges, and thus when you open the lid it is making the cracks.
You may also want to unseat / unscrew the hinges and re-tighen the little screws that hold them in place.
Mar 12, 2009 | Acer Aspire 5050-3242 Notebook
Acer 3610 crack by hinges on monitor
Unfortunately the LCD back cover is not readily available but you can find it here http://www.computercare.ca/product.php?productid=18048&cat=1648&page=
I bought this part and replaced my back cover for LCD. be careful while replacing LCD inverter you might be needing a new one.
Aug 19, 2008 | Acer Aspire 3610 Notebook
What does work is this-
Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly.
Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
Feb 18, 2008 | Acer Aspire 3610 Notebook
Cracks in case around hinges.
Replace bottom plastics. Find them by doing a Google search. Use keywords 'laptop plastics for make/model.
Jan 06, 2008 | Acer Aspire 3610 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
